Bike grease vs. marine grease
I use marine grease for all grease applications. Pro-tip, use a light gray or other light color. That way you see when it gets dirty.
The only special grease I bought is the Shimano friction clutch grease since I feared generic grease not working perfectly under all temperatures.
At this point I have more types of lube than I know what to do with. I have wet lube, dry lube, wax based lube, spray lube, bio-lube, graphite, silicone, but I have only one grease: PTFE, picked it up at the hardware store.
I grease threads on everything I assemble--such as a squat rack for my back from college son a couple weeks back.. A habit from bicycle maintenance--I figure it can't hurt.
Quoted: 252 Post(s)
Liked 67 Times
Friction clutch... isn't that what you put on seatpost where aluminium meets aluminium or carbon fiber and it helps holding your seat tube in place? I checked the seat tube on the bike I just bought secondhand and it has this 'rough' grease on it. That further confirmed my guess that the previous owner had the bike serviced in a bike shop. Wonder if it could still be the original grease from 2007 when the bike was new.
It left a smell on my hands which was rather pleasant. Maybe scented grease?
Agreed. I learned that when I was a wrench at a bike shop doing new assembly. When I got trained, the owner/bosses mantra was "every threaded fastener get lubricated." Grease, oil, he didn't care. A lubricated fastener and a light touch on the wrench, not too much torque, and the fastebe would never come undone, until years later when you were taking the part off, it came out easily.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I have a tub of marine bearing grease, a tube of Parks, and I've used Phil's in the past. I can't tell any difference between them. If there is any, I suspect that it's just the packaging.
Yeah, those ring-ringers would even rattle your teeth loose. But they were fun. The power to displacement was fantastic But you had to be careful. the power band was very narrow and very high up on the rpm range. Below the band, 2 strokes were absolute dogs, but once you hit the power band, watch out. If you weren't paying attention, you could easily wheelie over backwards.
1988 Ducati 750 F1
1988 Ducati 750 F1
I bought a tube of Phil grease in 1980. I'm still using it and it is only grease I've ever used on a bike. The more surprising thing is I've kept track of it over these years.
Anti-seize may or may not count as a lubricant depending on formulation, but they often provide torque modification guidelines.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
You have to be careful here, Grease changes the coefficient of friction on the fastener and therefore can have a sever impact on the torque-tension relationship. Lubricated fasteners reduce required torque by 30-50%, so you could be over-tightening them by ~50-100%, Which in some cases could be catastrophic.
Or.. by not greasing you could be under-tightening your fasteners. This is the conundrum -- ie. good luck whether every bolt/clamp on your bike has an associated manufacturer instruction manual that defines whether torque value is based on wet or dry. IMO if a bolt should be or is greased in normal practice, then the torque value provided should be based on such.
As someone that occasionally specifies fastener torque, people that apply rules such as "grease all fasteners" raises a red flag. The answer is "It depends..."
I just wanted to bring up that blindly applying lubricant to fasteners is a bad idea. Most things it probably doesn't matter but some times your are out a broken fastener, a couple million dollars, or worse...
All greases are not the same:
while not directly applicable to our use-case, it is a clue that quality grease makes a difference.
Likes For MadKaw:
Or this one:
We spend gazillions of dollars to shave grams or watts... why use cheap, untested grease?
Or this one:
https://www.youtube.com/watch?v=EJfe8FvQUQg
Sure, greases are vastly different, but the usual generic sales blurbs leaves you none the wiser as to what product to choose and why. Even Park fails miserably at explaining the difference between HPG-1 and PPL-1 and distinguishing when to use what product, in the above video. Also lots of "bike specific" lubricants are garbage formulated or selected to carve out a niche in the market, rather than provide proper performance. Then again, if you get a tin of wheel bearing grease from some reputable company, you be fine. Its not the grease that destroys your bike. Its the LACK of grease, ie lack of maintenance or "over maintaining" with harsh degreasers and the like.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Likes For tyrion:
Likes For Lakerat:
