C&V Silca Pump - Next?
Bikes: 1986 Cannondale SR600
Quoted: 20 Post(s)
Liked 7 Times
You could also try e-mailing Silca with pictures of your chuck and gasket. I'm sure they can either tell you definitively, or would be interested in figuring out the answer to update their product description.
Quoted: 1608 Post(s)
Liked 2,216 Times
The rubber "gasket is 13mm OD and about 9mm deep(best guess) Of course it has the standard hole for a Presta vavle
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Love these pumps - usually can be had at church sales for a buck or two.
The blue one is my daily driver. The others need a "vaseline job" and hose work.
Liked 2,216 Times
I tried mine again today, the older one. I discovered that I was not pushing it on the valve far enough. Once I had a good engagement, I was able to pump it up to 125 with the gauge indicating 120. The check valve isn't working well so I will have to check it out.
I was surprised how easily it pumped to that pressure
@ Thinktubes If you find another one for a couple of bucks, buy it and lets talk!
Likes For SJX426:
Quoted: 20 Post(s)
Liked 7 Times
The barrel of your chuck appears to have threads on both ends. I'm curious - are both ends identical? Some related chucks are reversible - you can flip the barrel to go between presta and Schrader, with the cap having threads letting it screw on a Schrader valve. The hose barb actually swivels within its cap, sealed by an O-ring. Mine came without lubrication for that O-ring and it I had it for years before realizing the barb and cap weren't a single solid piece!
Liked 2,216 Times
@luns - The barrel does have threads at both ends.
P1040805 on Flickr
The gasket is 8mm long in its present form I suspect it was a bit longer new, before being compressed by the cap. hard to get good pictures lately, may need a new cameral.
P1040801 on Flickr
P1040804 on Flickr
P1040803 on Flickr
Here is the interesting part, the opposite end of the barrel. The barrel is not a straight through bore but has a partition with a small hole in the center with this gasket on the other side.
P1040806 on Flickr
Know idea how a shreader valve is accomidated.
This is the end piece on the hose
P1040811 on Flickr
P1040805 on Flickr
P1040801 on Flickr
P1040804 on Flickr
P1040803 on Flickr
P1040806 on Flickr
P1040811 on Flickr
Quoted: 20 Post(s)
Liked 7 Times
I haven't used the current replacement 323, but did recently replace the 242 on my '03 Pista. The new red material works very well, and was day and night compared to the worn and hardened old black rubber.
The cap on the hose end looks much like the part on my reversible chuck. The seam between my barb and the cap fit so precisely the seam was literally invisible. If you try twisting the cap relative to the hose, does it move? It may take a fairly firm twist, and it may feel like the barb actually twisting in the hose instead (this is what I thought I was originally doing using the old chuck on Schrader), but you can take a sharpie and draw a radial line on the inside face of the cap to see whether that's actually the case or not.
Quoted: 20 Post(s)
Liked 7 Times
Ditto the handle: the stock oval plastic is the worst thing about these standard Silca floor models, I would replace with a more comfortable and LARGER wooden handle: you won't be able to source a metric threaded insert (easily) in US, so I do as many of the Super Pista pumps: drilled through wood, washers on top/bottom and a lock nut on top.
https://www.amazon.com/Z-Threaded-In...dp/B07V8ZS86N/
Unit cost seems very reasonable to me, but I'll be forever looking for things to do with 24 spares.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,063 Times
This insert appears identical to the one in my early '00s Super-Pista handle.
The oval plastic has a brass threaded insert and it's molded in place.
Personally I would look for a screw-in insert that was also brass (or steel) because these cast zinc jobs do not inspire confidence: that's the (soft) metal you find used for very soft substrates like MDF. Seen too many things like that crumble (looking at you, IKEA).
I would want stronger metal cause I'd use a harder wood for replacement handles. YMMV of course!
Why I oughta 😉
You motivated me to dress-up my 2x8 drop with a piece of scrap Australian Blackwood as a veneer to the old fir base.
Leftover scrap from an acoustic guitar build that went awry...
This is the Silca pump mentioned by Juvela. I asked Silca for dating and they told me around 1960; to me i think it is older than that with a brass tube beautiful Cast Aluminum foot rest and the hose is special stainless steel webbing i believe. Like motorcycle heavy duty hydraulic brake hose.
Likes For madscrambler:
Liked 1,063 Times
As I promised (or threatened?) I took a pic of two of the Silcas I have at home with wooden "extra bases" I made and added. They are both black Super Pistas but the one in foreground with the typical base has the "capsule" shape I made most often. I added this to Regular as well as Super Pista pump bases. The one in background has the later "triangle base' so I tried something different shape-wise, but didn't want to try to follow the base outline cause I wanted the footprint to be closer to that of the capsules. Tho mostly I use scrap plywood this "capsule example" happens to be a solid plank; the other is plywood with an exotic wood veneer, I think it's teak (or something "close" they now substitute since real teak is endangered). Maybe I'll snap pix of the others at "the shop" but they are just variations on the capsule, only with different veneers on the plywood or perhaps a nicer close-grain solid pine plank.
Likes For unworthy1:
Liked 2,216 Times
Interesting to add a base. I would not drill a hole in mine.
In addition, mine is slightly bent, and trying to bend it back may brake it. Looking at the bottom, it looks like it should with most of the wear on the non gauge side.
My suspicion is that it was used on grass, gravel, or soft dirt that caused the bend over time.
P1040756 on Flickr
P1040756 on Flickr
Liked 2,216 Times
[QUOTE=luns;21964588]Not that I would actually do it, but I'm imagining decal A below (from Cyclomondo):
[/QOTE]
Hmmmmmm.
[/QOTE]
Hmmmmmm.
Liked 1,063 Times
I took some snaps of one (Standard not Super) that I made a replacement wooden (white oak in this case) handle with an "experimental shape" to replace the lousy black plastic "oval". It was a choice as much dictated by style as by ergonomics, but I can say it is far more comfortable than the "oval". And the base is my go-to "capsule" shape, this time plywood with an oak veneer. This handle has a steel threaded insert (M10) I filed down a little: worked out fine, and not expensive when you buy 25 of them!
Have to figure out some elegant "hose-caddy", the rubber band ain't doin' it!
the steel threaded insert
Liked 2,216 Times
I rarely use mine. I still have not found the correct gasket for the head. It goes on and I am able to pump a tire up to the desired pressure, but the valve has to be forced deep in to the head.
The oval handle is not comfortable unless you use one hand!
What I find a bit puzzling is the brass piece with the gauge and out put of the hose. It looks like it was meant to be used with the left foot. I have been using the right one.
This pump is more of a show piece for me than a commonly used pump. My compressor is used to take the tire up to its max pressure then finished off with the white pump.
I am reluctant to drill holes in the base or replace the handle given the challenge of the head. It will remain fully original, otherwise.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Otherwise I just replaced my hose and head with this. It's a bit sacrilegious but I use the pump plenty.
Quoted: 246 Post(s)
Liked 338 Times
My pump for reference.
I've had a couple of classic Silca's one was black exactly like the OP'rs, but lost it while supporting a Leadville 100 team as a mechanic somewhere.
This one had a bad leather washer which I replaced and a bad hose, which I replaced with this dual head Sunlite thing which is my favorite chuck head. Way more functional but these pumps are better for 28c tires and smaller to dial in the exact PSI needed.
Liked 1,063 Times
The example I just posted above with the oak handle had a warped base and when I screwed it to this wooden base it flattened out without cracking (maybe I just got lucky).
You can sometimes re-orient the gage so it's right-side-up in the position you use the pump (I like my gages on the left, but sometimes they are upside down in that case), and sometimes that won't work. No idea why I have examples of same pumps with "original, factory" gages in both orientations: it's not like they sold them in "left-hand or right-hand" versions. Apparently Silca didn't think it made a difference, and when I can't flip the gage and still have it seal I just adapt to reading it upside down.
Quoted: 469 Post(s)
Liked 2,443 Times
Slight drift here. How do you determine what model you have and what the differences are between them?
I bought this off of Craigslist several years ago. I use it , but my Park pump gets the most use.
Liked 1,063 Times
That one is a Super Pista due to longer (taller) body (which you have to compare with the Standard to see) plus the larger wooden handle, top cap with built-in hose "caddy", this also is a more modern Super Pista due to both the Trangular base AND the gage "shroud" plus the larger graphics on the barrel. Earlier Supers came with the same base as the Standard Pista (and was extra-unstable due to that) plus these wooden handles were both drilled thru with curved washers and a top Nylock nut or with a threaded insert (as yours has).
And my slight side-bar: I think every OEM wooden handle I have seen has been Beech, and even tho I think I'm good at wood species ID I could be wrong. Did not think of Beech as a common lumber in Italy, (EDIT: wrong! Beech is a common wood in Italy, especially for furniture. Interwebs sez so, BUT now revising my opinion to allow it may be Boxwood) so any of you woodworkers out there who want to go down a tangent....
Liked 2,216 Times
Is this the gasket for the head you need?
Sunlite twinhead pump hose kit
I don't know. Just ordered one. I sent measurements to Silca and they tole me I needed the 272 which is way too big. I can still upgrade my other chuck with it.
Likes For SJX426:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I know that the original Silca Presta chuck is a wonderful thing, but I finally got tired of dicking around with it. Stuck one of these on it. Works fine, and I put the old chuck in a parts drawer labeled "pump".
Apparently Tpeak has stopped making and selling these, and now sells something similar (but not identical) in a silver metal version. I can't vouch for those, because I've never used one.
