Who really likes 50-34?
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Just here to soak up the info, I have no compact cranks. Just very high geared road doubles, and a couple interesting triples.
I know. But my knees are a disaster. If I don't keep my cadence up, I can't ride at all due to the pain. And I like hills. So gearing had to be chosen appropriately.
Last time I was in for a fit, the fitter had to video my pedal stroke so he could slow it down to see what was going on. :-/
Some sort of pithy irrelevant one-liner should go here.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I run a 50/36. I used to do 50/34, but got stronger, and wanted nicer front shifting. With a 12-27, I spent most of my time in the 50t and only use the 36t on the serious climbs.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Thanks for all the great advice guys. Good conversation. A brief point in response to top end gearing. I am not racing or trying to speed too fast down hill. The reason is pretty simple. To me riding much above 30 mph in bike traffic on road I don't know is Russian roulette...my opinion. I am in no hurry to crash. That is why a compact makes the most sense to me in spite of small ring flexibility with 110 BCD. With 50/12 I have all the speed I need if I spin the crank fast which I can downhill in particular. In a paceline in particular I want to see pot holes when flying down the hill. Kinda dangerous to ride over 30 mph in these circumstances. Solo or riding abreast on a know track...no problem. But don't need to go faster than 35 mph for a good rush and start to the next hill.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
So do you guys feel 42/52 is too high of gearing for chain rings?
Liked 8 Times
Gearing is gearing. I suspect your observation has more to do with the people in question than their gearing. And observation bias.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6800 Post(s)
Liked 5,511 Times
50/34 - 12/27 works well for me but then I don't race and have nothing to prove. More efficient than a triple.
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
Standard is all I've known before until recently I decided to put on a compact just to experiment and to my suprise, I love the the sucker. With the low cadence (in the 60s) going up a steep hill with a standard, my legs takes much longer to recover or don't recover completely at all. But witht a compact, the cadence can stay at least above mid 70s and the legs can just keep going and going. Yes, you shift more with the front but I don't know what the big deal is. It's there for a reason.
Throw the stick!!!!
I don't feel that there is a right or wrong answer. Different chainrings work for different people in different areas. We have a lot of 20% - 25+% in my area (plus I'm fat). Compact works for me. I am regularly passed by riders with easier gearing that I have and harder gearing than I have. Who am I to tell them what they should be riding.
I may be fat but I'm slow enough to make up for it.
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Bikes: 2013 Synapse 4
Quoted: 70 Post(s)
Bikes: 2014 Felt F2 2015 Specialized Tarmac Sport
I REALLY LIKE MY 50/34 and 11-25 set up, seems to work for me. I often think a standard crank set would be a great set up as well. I just hate triples. Good for some, just not my cup of tea.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
I like 50-34 on a friction shifted bike, where you spend most of your time on the 50, and only drop to the 34 in a significant climb.
I like 53-39 on an index shifting crank, because the shifting is crisper (14 tooth vs 16 tooth jump). It, IMO, makes the front crisp and fast, with less overlap and less reluctance to use it.
I liked a 50-36 crank I had, to get the crisp shift between rings, but ended up using the 36 so rarely that I went to a single 46 tooth chainring, and loved the 1x9.
Mostly I ride a single speed now, 47x16, and have done all of the same rides that I did with 9, 18, or 20 gear combinations with 1. So I guess that I am gear agnostic.
So, long story short, I don't think anyone can recommend gearing for anyone else, at least in a meaningful manner.
Bikes: Roubaix / Shiv
Quoted: 12 Post(s)
I'll be buying all my future road bikes with 50/34 as long as I live in Southern California. It seems like the perfect gear combo for hilly and mountainous areas. The 50/11 combo has higher topend than the old tried and true 53/12 that was the de facto standard not very long ago, and the 34/28 combo is nearly mandatory on some of the climbs around here. I never see the small chainring on flat or lightly hilly rides, the range I get with the 50 up front seems perfect for the flats, but 53 would probably be fine too.
SuperGimp
Me neither. I just know riding around here with a standard crank was painful. 52x36 was a huge improvement, as was going from 12-26 to 11-28 but there were still enough nasty hills near my house that I felt the need to go to a compact up front. YMMV. I went riding up a local mountain road a few weeks ago with a pal who has a standard crank and what may have been something along the lines of an 11-25 and he pretty much torched me up the road, so I guess rider strength and preference plays a huge role in gear selection.
Portland Fred
I don't know about your assertion relative to the cassette being even more widely spaced...I guess a matter of philosophy...as I like as small and tight a rear cassette as possible to tune cadence...but an astute point about increase gear overlap between large chainring spacing of a compact.
12-25: 12, 13, 14, 15, 16, 17, 19, 21, 23, 25
12-27: 12, 13, 14, 15, 16, 17, 19, 21, 24, 27
Note that they are exactly the same except the last two cogs which you should only be using when you're in the small ring. Chances are that if you want the 25, you want the 27. So you suffer no penalty for getting a lower gear.
11-23: 11, 12, 13, 14, 15, 16, 17, 19, 21, 23
11-25: 11, 12, 13, 14, 15, 17, 19, 21, 23, 25
11-26: 11, 12, 13, 14, 15, 17, 19, 21, 23, 26
With the 11-25 and 11-26, you lose the 16 which is useful but you'll notice that the width really only comes at the bottom of the range which shouldn't get used that often.
11-28: 11, 12, 13, 14, 15, 17, 19, 22, 25, 28
If your rings allow you to use the mid and upper ranges of your cassette, everything is still one tooth apart. In the cassettes above, we see that riders that predominantly use their top 5 cogs won't notice any difference from the 11-23 and those that predominantly use the top 6 won't notice a difference from the 11-25. This is still definitely a hill cassette but wider spacing is not as much of an issue at the low end when you're grinding up a hill.
Of course, maximum selectivity would be with a triple and a corn cob. You'd have tight ratios anywhere you wanted them.
Bikes: 2011 Trek 8.4 DS hybrid; 2012 Felt F-75 road bike; 1990 Specialized Stumpjumper MTB; 1992 Guerciotti road bike (inactive)
50/34, 11-25 good.
I live in a hilly area, don't race anymore, do challenging 30 - 45 mile rides at 14-15 mph avg for fun and personal fitness, no longer ride just to hang with fast groups, and, as someone already said, don't have anything to prove to anybody else anymore.
Bikes: custom caad9
I ride 50/34 11-28. I'm 27. My knees/legs/back are in great condition. I only bring the latter two points up because I don't really understand why people have to justify their gearing combination with their age/condition.
Coming of standard gearing, it took me a handful of rides to get to know what I was working with but I have come to love this combo in Southern San Diego.
Bikes: custom caad9
Awesome attitude. Pretty much the boat i'm in but still participate in fast group rides with no issue.
I ride a 50/34 and either an 11-32 or 11-28 in the back. If there's stuff that's more than 7% for any stretch I'll go with the 11-32, but for say a long climb that is pretty constant grade (like mt hamilton) I'll use an 11-28 and be fine. I don't like killing my knees grinding up 10%+ grades even if it's for a short time. With an 11-32 I can downshift to stand on really steep stuff. Living next to the Santa Cruz mountains you end up climbing a lot, so you don't see many people riding standards out here.
I'll ride the inner for a lot of riding and if I need to just use the smaller part of the cassette. I find myself in the big ring at the top of a hill. I didn't like shifting between rings because you get that weird gap you have to cover with 2-3 shifts in the back but with electronic shifting it's pretty fast to pull that off.
Liked 8 Times
Consider these cassettes:
