Oxalic Acid
I agree that more dilute is better. A little elbow grease with weaker solution works well. Neutralizing with baking soda not a bad idea. But remember that when the rust is gone the underlying metal is happily waiting to oxidize. My solution to this on chrome is to immediately polish with Simichrome. Good product, repeat on chrome parts occasionally to keep them shiny.
"It's a fine line between absolute genius and sheer stupidity"
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 167 Post(s)
Liked 150 Times
Reasonable approach. Another being simply to use a hard paste wax every so often to give the shiny bits a protective layer that prevents water vapor and oxygen from getting to the reactive iron underneath. That's the reaction you want to avoid, iron just loves marrying with oxygen to create rust.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 992 Post(s)
Liked 658 Times
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 167 Post(s)
Liked 150 Times
Quoted: 765 Post(s)
Liked 660 Times
This has been my experience, too, The "before" and "after" pictures look dramatic, but within a few years of normal use, you're pretty much back where you started (at least in my case, where I live in a relatively damp climate and store my bikes in a n unheated and non-climate-controlled shed). Maybe regularly wiping down the frame with Boeshield or some such would help, but I've never tried that. Waxing doesn't seem to prevent rust from recurring, at least in my experience. Bottom line, I doubt that I'll ever go to the effort of dipping another frame, either with OA--which I don't like for other reasons--or Evaporust, which I do like and continue to use for derusting components.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 992 Post(s)
Liked 658 Times
Never heard of THAT stuff 'till you posted this, thanks!
Wow, in late 2020 it was only $19.99 per bottle. I am getting low, perhaps I need to shop around!
Quoted: 992 Post(s)
Liked 658 Times
Good info in this topic. Wish me luck! EDIT: Checking every 1/2 hour. Somewhere between 2 hours and 2.5 hours, somewhere have a tiny leak. This is going to be a mess! I wonder if there something better to line the box in? The spray version of Dip-it?
Quoted: 1959 Post(s)
Liked 2,050 Times
Two layers leaked
One layer good for 3 uses so far.
Mine leaked too. I’m using a piece of poly tarp now that works great.
Likes For Classtime:
Bikes: '53/'54 Bianchi CDM, '62ish Altenburger Cinelli Mod B, '69 Rene Herse Competition, '72 Motobecane Grand Record, '73-74 Colnago Super,, '73-74 Cinelli SC, '78ish counterfeit Confente, '82 Medici Gran Turismo, '67ish Mondia Speciale, Eddy Merckx Pro
Quoted: 90 Post(s)
Liked 275 Times
Likes For bibliobob:
Quoted: 1113 Post(s)
Liked 1,335 Times
You have to be a bit careful not to poke a hole in it with a pointy bike bit.
And out-of-doors is probably a good idea in any case.
Quoted: 992 Post(s)
Liked 658 Times
If I keep the box long-term for future bikes, I think I need a petcock or sillcock to drain it once done -- scooping with a bucket was tedious and a lot of splash out, etc.
Likes For tiger1964:
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 680 Times
Did an oxalic acid demo at the co-op tonight. That stuff is unbelievably good at making completely worthless chrome parts shine. The 11 ounce stamped-rolled-and-bashed Murray stem probably did not look that shiny when it was brand new.
It also works for nice chrome parts, but those aren't super common at the co-op.
Bikes: Indeed!
Quoted: 1513 Post(s)
Liked 3,489 Times
A word of caution. Don't dump the neutralizing baking soda into the acid bath while the frame is in the bath. The reaction that takes place may discolor paint and damage fragile decals.
Better to remove frame from bath, dump in baking soda, wait for reaction to subside, then return frame to bath to neutralizer the acid still remaining in frame tubes. Yes, I learned this lesson the hard way.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Likes For obrentharris:
Quoted: 992 Post(s)
Liked 658 Times
A word of caution. Don't dump the neutralizing baking soda into the acid bath while the frame is in the bath. The reaction that takes place may discolor paint and damage fragile decals. Better to remove frame from bath, dump in baking soda, wait for reaction to subside, then return frame to bath to neutralizer the acid still remaining in frame tubes. Yes, I learned this lesson the hard way. Brent
Bikes: Indeed!
Liked 3,489 Times
Educate me on that? You put baking soda (how much per gallon?) in the water that already has the acid? Hmmm, I have a special challenge -- I am doing three frames, my plan was to dunk each one in succession in the same bath, I presume up to 24 hours (?); this would mean each bike would be out of the oxalic bath for up to 48 hours before I could re-immerse in a neutralizing bath. Bad idea? Alternatively, I re-mix the acid each time; I guess that means I'll be going through a lot more oxalic acid -- sure would not mind avoiding that.
Brent
Quoted: 167 Post(s)
Liked 150 Times
After all these baths it's A Good Idea I think to give each frame a decent rinse with plain water before proceeding with the next steps in your plan of action, then thorough dry-out. Gets rid of any remaining contaminants, leaves a clean surface for whatever you might have in mind for overcoating (lacquer inside, or oiling) before re-assembly.
Quoted: 992 Post(s)
Liked 658 Times
OK, two frames (and forks of course) have spent 24 hours each in the oxalic acid, and rinsed upon removal. Third one in there now -- and now it's lightly raining, not pleasant being out there but I'm "committed". So, once all three are done, I add a box of baking soda -- and how long each in that? And does that leave residue that I should remove with, say, soapy water?
And additional concern -- one frame is bare metal after soda blasting, and hope to take to a paint shop soon. Should I be worrying about "flash rust" or anything else, post-OA but pre-paint?
Bikes: Indeed!
Liked 3,489 Times
Reading a bunch of topics, not running into info on how long to leave the frame in the neutralizing bath. An hour? 24 hours? And I presume the "reaction" will be obvious in its appearance.
Yes, new rust is a concern after the OA treatment. My approach is to treat the dry frame with zinc phosphate and store it indoors until I can paint it. The product I use is POR 15 Metal Prep.
Brent
Quoted: 992 Post(s)
Liked 658 Times
I leave the frame in the baking soda bath for only a few minutes, then flush with clean water.
Brent
Brent
Bikes: Indeed!
Liked 3,489 Times
Brent
Quoted: 992 Post(s)
Liked 658 Times
Today, the third frame came out, then the baking soda (yeah, it swirled/fizzed a bit, pretty obvious), then a short soak for each frame in that, then a cold-water rinse outside, then inside and a quick wipe down with microfibers to minimize drying on the frame. That took the last "film" off the frames, they look pretty good. Still awaiting the zinc phosphate. Meanwhile, frames in the house and the pellet stove on which can bring the humidity in the house down to about 30% so hopefully no flash rust.
Dang it, I swear there's still a little leakage from the soaking box despite the three cans of rubberized undercoating and then the coats of Flex-Seal. Not sure what I need to do the get a 100% leak-free vessel.
Still have some frame-prep steps, like Frame Saver and touch-up paint. Whew!
