Which Quill Stem looks best?
Edumacator
Quoted: 2444 Post(s)
Liked 3,140 Times
My post upstairs didn’t display the pictures.
ITM Eclypse and the 3TTT prochrome can really be made to stand out. Cinelli Pincchio (is that the Grammo?) is pretty cool as well.
I have a few of the the two latter ones that I removed the stickers and the shine like the sun. And they are stiff and strong as heck.
Quoted: 2326 Post(s)
Liked 5,012 Times
I remember strangers on various forums giving me crap for riding this bike. "Your bars are too high", "Your fit is all wrong", yada, yada, yada. Like they could know about the 5 blown discs in my lower back and the constant pain I was in for couple of years.
As the back got sorted I was able to be quite comfortable with the bars lower and lower up to where even this bike wasn't an issue.
Then I had the wreck that jacked up the AC joint in my one shoulder. Add in age and a little more cushioning in the belly and I tend to start heading back up on some of the bikes. My fit is still pretty precise for handlebar reach amongst all the bikes but I vary a fair bit on the saddle to bar drop. I need to get some rides in on each new setup to feel things out and see what I like best.
Weirdest thing about the jacked up AC joint is that I feel like I'm always shrugging with my opposite shoulder when I ride now. LIke I'm compensating or something.
Anyway, looks come in a long second to being comfortable on the bike. Rant over, LOL!
Steel is real...and comfy.
Likes For jamesdak:
Liked 5,012 Times
Quoted: 1110 Post(s)
Liked 1,204 Times
Ah the voice of reason!
*I do understand the "hot or not" threads with photos, because they are obviously focused on style not function, although I often disagree with peoples' aesthetic taste. I like looking at those bikes. I also have made a decision on component "a" or "b" based on aesthetics, assuming they both serve the function. I do like the seat post, stem and crank, even the rims, to match - silver or black - but that only comes into play if I happen to have the functional matchy parts available.
Likes For Camilo:
Cinelli is the nicest look/fit
For the bars stuck in the Cinelli stem remove the bolt and try gently driving a wedge (either a flat stubby screwdriver or a chisel (V-wedge)) into the split to expand the opening up.
The Cinelli Grammo stem is really nice but it's really flexy as it's thin light titanium. Also make sure to keep track of the stem cap because you will never be able to find a replacement
I've found that Cinelli stems (1/A, 1/R) are often a tight fit in the steering tube. On more than one occasion I've had to have the inside of the fork's steering tube reamed out a slight amount to fit a Cinelli stem. In contrast, 3ttt and Nitto stems would drop right into the fork without fuss. (Columbus steering tube.)
I've found that 3ttt handlebars often slipped in the stem. The bars rotated down, towards the front. I had significantly fewer problems with Nitto or Cinelli.
I've also found that a traditional quill stem with bars to match (~26mm diameter at the clamp) feel a bit too flexible when used on a more modern frame with oversized tubes. This is more of an issue when standing ("dancing") on the pedals. So I prefer 31.7mm/31.8mm bars to use with an oversized tube frameset.
For a quill stem, I recommend Nitto, with Nitto bars to match. The Nitto quality is top notch (in my experience better than Cinelli) , and there is a great range of handlebars available, with various reaches as noted per each model's specifications. Otherwise you may want to consider a threadless stem with a quill adapter. Nitto makes some silver finish bars and stems in 31.8mm diameter. Ritchey also makes a stem and bars in silver finish.
For stem diameter, I think the stem looks 'right' when the diameter of the horizontal part of the stem is about the diameter of the top tube.
Quoted: 3515 Post(s)
Liked 2,929 Times
It may be hard to see from the photo, but the Cinelli stem pictured is a 1R--the binding mechanism is internal, and there is no "split" into which one can force a screwdriver.
Likes For smd4:
Liked 2,929 Times
Quoted: 1609 Post(s)
Liked 2,216 Times
My personal favorite at the moment is the XA. I like the transitions and the hidden bolt. this one is a bit long and was replace with a 1R, which has a lot of appeal but subject to poor clamping and failure.
P1020201 on Flickr
P1020201 on Flickr
Liked 5,012 Times
Bingo! And repeated soakings with PB Blaster did no good which surprised me.
Liked 5,012 Times
Ahhh......I'll take a Nitto Pearl over a Dura Ace anyday. Just something about the look and finish of the pearl. I'm pretty sure I saw a long Dura Ace in my stash when I was looking but if it doesn't fit my need it has no purpose this time.
Liked 5,012 Times
Nitto Noodle is a bar I use a lot too but I've just come to like the Soma HWY One better.
Liked 2,929 Times
I guess they're fine if you like a giant bolt/clamp system hanging below your bar! (and if I wanted that, I'd get a Cinelli 1A). And I think I'd put the Dura Ace finishing over the pearl any day!
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 165 Post(s)
Liked 102 Times
IMO the Profile goes best with that frame, but whatever fits best is best.
I also have a Cinelli 1-R that won't release the bar. Luckily the bar is where I want it!
Liked 5,012 Times
Liked 2,929 Times
I believe we're all in agreement that the stem should fit, be the right length, etc. I can only assume that jamesdak has stems in his collection that fit this bill, and that he knows what size to get if he has to purchase outside his stash.
Of course, proper stem size was not the question posed in this thread.
Liked 2,929 Times
Liked 5,012 Times
Liked 5,012 Times
But I diverted the thread as much as everyone else.
Quoted: 380 Post(s)
Liked 541 Times
I should have mentioned that the only reason the Cinelli isn't my favorite is that I can't get it to release the handlebars. I can take that hidden bolt all the way out and the bars are locked in place. I've soaked it repeatedly with PB Blaster with no luck. I'd just hate to use it and suddenly have something go wrong like the bars come free or something. I mean that shouldn't happen with the bolt all the way in but I just feel uncomfortable trusting a stem I can't fully service.
Likes For Steel Charlie:
Liked 2,216 Times
@jamesdak Hard enough to get the 1R tight enough to keep the HB from rotating even with the correct HB diameter. The cap screw pulls down on a piece that has a ramp matching the ramp of the wedge. By taping on the cap screw lightly while it is loos will move the wedge up and should release the clamping force.
I have a 1A in 80 that I don't need.
Liked 5,012 Times
Anyway if not for your suggestions I probably would have tossed this back in the handlebar box and forgotten about it. Thanks!
Liked 2,929 Times
Check you guys out! I just went to grab this to test out your method and as soon as I loosened the bolt it came free. I guess sitting a year or so in the stash after I last messed with this let the PB Blaster do it's stuff. Feel sorta stupid that I didn't even check this yesterday.
Liked 5,012 Times
