Park tools worth it
Falcon fan
I reckon so
I have a few Park Tools and a number of cheaper ones.
Best ones I have used so far, the cable cutter. Cuts brake and gear cable inners and outers and inners without crushing or causing fraying, and has a crimper for the ferrules. Works perfectly every time.
Also the crank puller. I removed 2 square tapered cranks that hadn’t been off the BB axle for 40 years
first time with the Park Tool one.
I always choose Park Tool as a preference now when buying bike tools. Slowly building up my collection as I need them.
Quoted: 19 Post(s)
Liked 11 Times
Park now falls short of the quality they used to be. Cyclus or Birzman/Lezyne seem to be a better option now. TIP: Search ebay for NOS Tacx or Park, usually the same price or less than buying current tools but better quality.
Quoted: 668 Post(s)
Liked 529 Times
My limited experience with Harbor Freight tools are I bought a leak down tester and really only needed it once... it didn't work right out of the box. I saw a HF floor jack not hold pressure and almost drop a car on someone. And the just had a big recall on their jack stands that collapse.
Having a tool break on you can leave you with a broken hand or dead when the car drops on you.
You may not get what you pay for, but you always pay for what you get"
Also never get under a car being held up by a floor jack, doesn't matter who made the jack.
Likes For Pop N Wood:
Quoted: 3352 Post(s)
Liked 1,056 Times
Title says it all. Are park tools work it for the home mechanic to wrench on a bike from time to time? I've got some park tools and I've purchased some "pro bike tool" tools on Amazon. Seem to work the same... I often feel that if I'm going to spend a lot of money on a tools it should at least be made in the US and I can go with something like wolftooth.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
https://www.nhtsa.gov/press-releases...ht-jack-stands
"Harbor Freight Tools is recalling more than 1.7 million Pittsburgh Automotive 3 Ton and 6 Ton Heavy Duty Steel Jack Stands. The jack stands may collapse under load, which can increase the risk of injury to people near or under a lifted vehicle.
Owners of these jack stands are asked to immediately discontinue use due to safety concerns. Injuries have been reported due to this issue.
The rate of return on many specialized bike tools is very low for me, negative actually. The only ones I have are tire levers and a cassette lock ring socket which was $10. I have normal household tools that suffice.
On Your Left
Liked 2,434 Times
I service my 2 bicycles fairly regularly. The money saved by doing it myself along with the time saved dropping it off, waiting for it to be done and going to get it is well worth it. Also knowing it's done right the first time by me is worth it alone.
It would be nice. I could put the stand in the kitchen 🤣
Quoted: 645 Post(s)
Liked 797 Times
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 339 Post(s)
Liked 230 Times
My bikes never see the lbs again after I buy them, and most of my work is done in the family room facing the tv. Tile floors come in handy sometimes.
I did get in trouble for cleaning the chain inside the house with orange solvent.
Likes For Wileyrat:
Likes For billnuke1:
On Your Left
Liked 2,434 Times
Quoted: 668 Post(s)
Liked 529 Times
FYI:
Read the reviews
I live in building that was built in 1902 and has landmark status using orange cleaner would get me written up with the CO-OP board. However in the basement the Super has a pretty big work shop. I clean the bike down there.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Some of their tools are quality/value, some not so much, some worthless misses (though they have higher quality version of the same tool in most cases). I have lots of park stuff, bike work stand, truing stand, spanners, etc, but I have other brands where I feel the Park quality/durability is not what I expect, such as Effeto Mariposa torque wrenches, Proto large hex bits, Silca hex wrenches, Enduro BB tool.
I guess I would say if it is not a bike specific tool like hex wrenches, torque wrenches, etc., then there are better choices like Proto, Snap-on, Effeto Mariposa, Silca, etc. that you might consider instead, and there are good bike specific choices as well.
Bikes: Jamis renegade, surly big dummy, giant talon 29er
Quoted: 62 Post(s)
Liked 42 Times
I guess I'll just continue on my current course of buying bike specific tools from park and continue to buy general tools from hardware stores. Although I've never been one for HF but I do find myself in there from time to time.
Quoted: 482 Post(s)
Liked 151 Times
HF has pretty poor quality IME. I have a workbench and ultrasonic cleaner from them, but I wouldn't buy any of their tools.
Likes For GeneO:
As a former bike mechanic, I say Park tools are excellent. They are well-designed, well-made, and a good value for those who use bike tools regularly. You can get no-name tools very cheaply from places like Amazon, but the quality is hit-and-miss. Some of these cheap tools are made well enough for regular use, and some break the first time you try to use them. A few years ago Park had a tire pump manufactured for them in China, and these were quite bad, half of those sold from a friend’s shop ended up being returned because they stopped working after only an few uses.
Quoted: 1062 Post(s)
Liked 665 Times
For bike specific tools, I've found that Park's prices are competitive enough with other reputable brands, that choosing their stuff won't break the bank. Also, because their stuff is more widespread, it's easier to find information about things like compatibility, e.g., which of the 50 different spline tools will fit my ancient freewheel? And, I don't mind supporting them for the amount of useful tutorial info that they provide.
However, I try to limit the number of bike specific tools that I need, because I'm supporting 3 hobbies (cycling, music, electronics) plus home maintenance and a small business, in a relatively small house. If I were to buy a complete set of "professional" gear for each thing, my house would be full and I'd be bankrupt. Also, truth be told, splurging a bit on a more reliable bike lessens the need for tools that can withstand daily or weekly use, or that shave minutes off of a repair job. Just being able to do your own maintenance shaves a couple hours off each repair job, by not having to schlep your bike somewhere.
elcraft
I have a variety of tool brands in my bike tools. Park Tools are the majority of the specialized tools; freewheel/freehub tools, crank pullers, and their laser cut spanners for headsets, bottom brackets, etc. Their products are a fair value to quality proposition. Park also stands behind their stuff in a remarkable ( at least for these days) way. They have sent me emplacement parts at no cost a couple of times.
While I have seen and used a couple of VAR tools, their cost and rarity essentially makes them unobtainable for me. I have a few Hozan Tools; they are robustly made. I like Pedros, as well- they seem to have worked on improved designs; their tire levers are a testimonial to that. Pedros also made a threaded “retainer” for securing a Shimano cartridge bottom bracket Tool from slipping out of the splines while in use. Something that should have been included with that type of tool, IMHO. When I needed to replace a long lost Stronglight crank extractor, there was only one option: J.A. Stein Tools. While they are expensive, the quality is superb.
As for Harbor Freight, I find the Taiwan made stuff to be excellent. The wrench sets and sockets are more than enough for bicycle work. The Mainland Chinese made stuff varies in quality, but is superb for making modified tools or special tools like an cotter extractor for cottered crank sets.
Indeed, I find myself creating modified tools for various projects now. A thinned out Park cone wrench that fits the Cones in the full ball bearing Pulleys of a vintage Huret Jubilee derailleur or a specially ground cone wrench for Sturmey Archer IGH work.
On a recent thread about cable housing and cable cutters, I suggested an electrical tool sourced from Home Depot. I find that the bicycle intended tools In this category are neither the best for the job nor the cheapest cost option. But I am really a weekend warrior, not someone who is using these tools day in and day out. I suspect that were I in that position, I would be looking at VAR and Stein and Park Tool’s professional grade stuff more.
Park, meh...
IMO Park are a bit hit and miss. I want my tools to be portable for when I take cycling vacations....which is all of them, amiright! They're stuff is meant for shops, which means its heavy and overbuilt. I've switched a lot of stuff over to Feedback because it's more portable - they often do multi-use tools, which reduces space and weight. Plus, their stands have proven amazing, so assuming my tools will last just as long.
That’s a matter of opinion. I have drawers of Williams ratchets, sockets, and wrenches. They make those tools for Snap-On then put their own name on them and sell them for a third of the price. They’re indistinguishable. Japanese and German screwdrivers put Snap-On to shame. They last forever and actually fit.
Bikes: Kona Dew, Gary Fisher Paragon, Salsa Campeon
Quoted: 120 Post(s)
Liked 128 Times
I'm in the hit and miss camp. I wouldn't part with my Park Tools pedal wrench, or chain stretch checker.. But my Park Tools bench stand is a first rate POS.
