how often & how well do you inspect your tires?
I check my tiers daily, as there is glass everywhere on my commute. Then at lest oncie a week I clean them then squeeze Shoe Goo -in the cuts.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Superficial inspections all the time, mainly looking for bulges, cuts or something obvious stuck in the tire. Really close with a magnifying glass or reading glasses, I'd say practically never. Except when I'm fixing a flat that I can't explain otherwise.
After every ride. If i sense i went over something sharp, later that day I would deflate the tire to take it out. It probably makes no sense but i'm kind of ocd about flats
Quoted: 5224 Post(s)
Liked 3,585 Times
was topping off my tires w air last night, cuz I rode to work today. noticed the tire rub from a few weeks ago (6-14-19) (as a result of a broken spoke) caused some excessive sidewall wear, creating a flat spot & exposing some underlying cords/threads! disappointed I didn't notice it before yesterday & that the LBS owner that replaced the spoke & trued the wheel, didn't either, or did, but didn't mention it? anyway, put on a thin layer of Powerflex Ultra Control Gel Super Glue 3g by Loctite (rubber infused formula) & ordered a replacement tire. I can swap that on this weekend. but I really did want to ride today & it was fine
when I noticed it
after a layer of super flex glue
after 22 miles to work this morning
when I noticed it
Liked 3,585 Times
This note came w the replacement tire
Virgo
I put a couple thousand miles on some Kenda Kwests, they have a light tread and were always getting little sharp rocks stuck in them that would eventually wear through. I was checking them almost every day. I swear I get less punctures running light, flimsy sidewall, slick or file tread, non-armored tires. “Supple”. I haven’t had a flat in several months, maybe 1,000 miles. Since I mention it now I’m sure I’m due for one, and my mini pump is currently out of commission. Hmm.
Likes For Phamilton:
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Almost never unless I am changing something or adding air.
I see this as an opportunity for improvement for me
Quoted: 7353 Post(s)
Liked 2,481 Times
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I suspect it would be fair to say the same is true for the vast majority of cyclists, including, even, bikeforums folks. We don't check our tires well enough or often enough. I already do an ABC Quick Check every time I get on. The habit is so ingrained that I don't notice I'm doing it, so maybe I can make a habit of tire checks, though I don't think it's necessary to do on every ride.
Quoted: 626 Post(s)
Liked 701 Times
When checking my tire pressures once a week (on my commuter Velomobile) I check my wheels for trueness, check and clean my tire treads of debris, and check my spokes for breakage or looseness. On my mountain bikes or regular road bike I rarely check the tires for debris, they are tubeless and rarely get a flat.
