Three cool scores, three stuck seatposts...
Thrifty Bill
Quoted: 1241 Post(s)
Liked 984 Times
In the world of stuck seat posts, everything works "SOMETIMES". Do enough of them, and you will end up cutting one out. Its just how it goes.
Endless threads on how to get stuck posts out, probably over 1000 of them.
Likes For wrk101:
Quoted: 1088 Post(s)
Liked 1,206 Times
Wow, this is when it pays to be a tinkerer -- lots of good parts on each frame. Great score!
Likes For noobinsf:
Quoted: 1959 Post(s)
Liked 2,050 Times
NICE IM. Friction shifting and non-aero brake levers make it a 85.
Likes For Classtime:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
I'm absolutely certain one of these is going to need serious stuff done. Maybe 2. I am considering drilling to a big enough diameter that I could use my kind of dull seat tube reamer as a big time fall back position. Thing is the trek is fine now and ready to build so I am waaaaay ahead.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4691 Post(s)
Liked 5,839 Times
Good job on the Trek!
Likes For gugie:
Bikes: old ones
Quoted: 26464 Post(s)
Liked 10,420 Times
...yes, mix it 50/50, and you need to mix it in an acetone resistant plastic bottle, not just any ole plastic bottle. Also it has a tendency to separate out when not in use, so you need to shake it regularly. I think I'm using Dextron right now, but anything will work that is labeled ATF. It works better than any of the commercial products. People don't believe this, until they try it.
If you keep a small, used Trifow bottle with an application straw in the nozzle handy, old bicycle things come apart much easier. So you don't damage as many little component bolts and machine screws, which makes your life easier. Mostly.
Likes For 3alarmer:
ambulatory senior
Liked 3,664 Times
Quoted: 607 Post(s)
Liked 792 Times
Patience is the best practice for the challenging corrosions ...
My latest battle was approx one month battle to remove a seized seat post that was stuck in metal frame seat tube.
AL Nitto seatpost.
Start using PB Blaster spending one week applying to post from bottom bracket and from top of seat tube.
Flipping frame and using rubber mallet to hit / twist seat tube from top.
Next using KRoil spending one week applying to post from bottom bracket and from top of seat tube.
Next using CRC Freeze-off spending one week applying to post from bottom bracket and from top of seat tube.
Next cut off top of seat post and drilled holes on both side to insert long screw to be used with longer metal poles.
Used this to gain max torque for twisting seat tube.
After many attempts to twist off over one day and adding more penetrating lubricant between attempts, the post finally twisted free.
Victory !
AL Nitto seatpost.
Victory !
Likes For joesch:
ambulatory senior
Liked 3,664 Times
Still got two to go....
Klaatu..Verata..Necktie?
Quoted: 10499 Post(s)
Liked 12,028 Times
The Ironman is at least a 62. And if it's the original seatpost, that baby is LONG, like 230mm (okay, that isn't really long, but I'm used to 190 posts on C&V). Pity some short person got a huge frame and slammed the seatpost on it! Probably thought "the bike fits me really well, and I'm 5'8"!"
Likes For genejockey:
Disco Infiltrator
Quoted: 3131 Post(s)
Liked 2,112 Times
This is going to start being a problem again with dropper seat posts. People tend to get the longest extension they can and slam it in the frame. That means it never gets moved and there’s nothing to grab on. Aluminum in aluminum, too.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
ambulatory senior
Liked 3,664 Times
I had pb blaster in the centurion for weeks upside down and none made it through the seat tube. Radical measures will need to be taken.
ambulatory senior
Liked 3,664 Times
Seatposts are so long nowadays, whenever I buy a new kalloy for a project I cut it down to a reasonable size just because.
Bikes: 2020 Lynskey GR300, 1987 Diamondback Ascent, 1991 Skykomish Marble Point, 1994 Specialized Stumpjumper FSR, 1996 Specialized Stumpjumper M2 FS, 1992 GT Karakoram
Quoted: 69 Post(s)
Liked 226 Times
I usually walk away from stuck seatpost buys but couldn’t resist. PB Blaster, wrenching and turning it in a vise didn’t work. Not enough seat post exposed so it only the stripped the post from the mounting bracket. Now bracket spins independently of the still stuck post. Next step is a hacksaw to cut the bracket off and pour caustic soda down the tube. Good times.
Likes For Wilbur76:
As a last resort yes, it is possible to drill out a stuck seatpost. See this thread, The down side is the cost of the drill and extension.
I.C.
I.C.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 584 Post(s)
Liked 704 Times
On a recent 85 Torpado, I passed on a stuck seat post. I got a call back from the seller that his son in law got it out. Crank removed and coka cola poured in. Big wrench on post and twisting then. Post a bit scarred up, but usable. As others said, different methods work sometimes. I was surprised actually.
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Got my first one out with a hacksaw. Haven't tried the second yet, which also has a frozen stem.
Quoted: 1624 Post(s)
Liked 2,655 Times
Maybe a lag bolt and impact gun if you end up cutting it off?
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,447 Times
And if you need additional leverage, stand away from the head tube and feed an eight-foot 2x4 between the head tube and the seat tube. Leaning on that will multiply your force so tread carefully. You might need a volunteer to brace the frame at vertical during your efforts.
Likes For thumpism:
Edumacator
Quoted: 2492 Post(s)
Liked 3,225 Times
Seatpost blaster
Drop the cocktail of looseners then hope the seat tube doesn’t shear...
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
ambulatory senior
Liked 3,664 Times
After trying pretty much everything except caustic soda I decided to start removing stock. I figure if I can't get it all out that less caustic soda would be needed eventually.
I carefully drilled the center of the seat post and then
started with a 3/4" stepper bit. I eventually needed an extension but now have a 3/4" hole completely through the seat post. I have a 25mm stepper on order. The cool thing about these bits is they follow the previous hole. If I can get a 25mm hole without damaging the seat tube my adjustable reamer will fit.
Likes For 52telecaster:
ambulatory senior
Liked 3,664 Times
27.2 seat post in place
3 inches of seatpost removed.
my son says he will shorten a stock modern seatpost to give him a French fit with 3/4" showing. At least this bike will get used
Quoted: 564 Post(s)
Liked 422 Times
Yup, good old fashioned mix.
Yet perhaps the cheapest penetrant is standalone diesel fuel. It really is an oil, not a gas, does not evaporate. Buying it in jerry cans allows me to fill up entire tubes and stays with it.
And when I drain it, I catch it all and store it for future use again.
PB blaster is just too expensive to use in quantity.
ambulatory senior
Liked 3,664 Times
Here is the running iron man. My son prefers a bit of a French fit. So glad two of the three got running. The Peugeot is next winters project.
