A Randonneur Build Around a 1977 Peugeot PRN10
Tell me about the wheels. What rims are those, VO PBP?
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 118 Post(s)
Liked 614 Times
The rims are Sun Ringle M13-II polished aluminum rims. I got them by mail order from Carson City Bike Shop. They are about $36 each. They look vintage but are recently manufactured with a really good braking surface. (I did peel the Sun Ringle sticker off and put RigidA decals on them to complete the retro look.) They are laced with stainless DT Swiss straight gauge spokes to Normandy Sport hubs that I polished before the wheel build. Tires are folding 700/28 Panaracer Paselas. Since the rims are newer, they are hooked so it is safe to run tires without wire beads. I would not run a folding tire on an old clincher without hooks because there is a danger of them unseating and failing at over 60 psi. pressure or after a hard hit.
Below is a link to the rims. Prices are good but their website is very hard to navigate.
https://carsoncitybikeshop.com/rim-s...sl-pol-msw-pv/
Likes For Sactown_Albert:
Quoted: 118 Post(s)
Liked 614 Times
They have the same rims in 27 inch too
Quoted: 118 Post(s)
Liked 614 Times
How the Sun Ringle 27 inch rims look built up
They have the rim in 36 holes in a 27 if you really want to stick to a C&V tire build. I Did this with my Peugeot UO18 because of brake reach issues. It worked out well. Here is a link to the 27 inch rims.
Last edited by Sactown_Albert; 10-12-22 at 03:35 PM. Reason: Forgot to include picture
Yes, the more upright the riding position (flat bars), the more plush you want the tires to be. A sprung saddle also helps, a bunch.
Likes For Bad Lag:
There are plenty of good 27 inch tires available so if you have a C&V bike that was originally built up around 27 inch rims, you can consider sticking to the original configuration rather than doing a 700c conversion. This bike has Sand Canyons (Built by Panaracer) on it and they look great and have a nice ride quality.
Quoted: 118 Post(s)
Liked 614 Times
Quoted: 118 Post(s)
Liked 614 Times
Nitto Choco Bars are very similar
