Cholesterol and riding
Really like the suggestion to make more meals at home... the big problem with "processed" food is that it's way too high on the sweet and the salty (not good for cholesterol concerns). Then we fall into a trap where we expect a certain level of sugars and salts and crave the excessive amounts of it. Preparing meals from scratch seems to be one of the best approaches to end this cycle of bad eating.
No clue what "organic" has to do with anything, that's just a bit of a side tangent imho.
The organic thing is more of an environmental concern than it is nutritional. Now a lot of farmers, not tree huggers, but red necked John Deere jockeys, are embracing organic. As one of them told me once, more of them are feeling had by the chemical companies, like junkies are dependent on their pusher. The whole GMO thing amplifies this. By patenting the very food the farmers plant, the farmers are losing their freedom to grow their own seed stocks, and the dependence intensifies.
I'll toss this link into the discussion:
Cholesterol: How much is too much? US removes limit
Clouding and confusing the issues...
You are correct. It is all confusing. Now the food industry, in reaction to public demand caused by revelations about those products have shifted their marketing, and trans fats are out, though other hydrogenated oils are in just about all packaged foods.
Cholesterol in food mostly passes through you. High blood cholesterol is cased by genetics, and aggravated by a diet too high in saturated fats. Saturated fats are not bad for you, but in the last hundred years the ratio of Omega 6 fat (saturated) to Omega 3 (unsaturated) in the American diet has shifted from higher in Omega 3 to higher in Omega 6. This is the result of hydrogenated oils, and the massive drop in price about eighty years ago of beef, thanks to corn feeding feedlots. Cattle fed high protean corn, which almost none of them were a hundred years ago, produce a higher ratio of Omega 6 to Omega 3 fats.
I have radically cut back on my beef consumption, and only eat grass fed, which can be found mostly at farmers markets and some specialty stores like Trader Joes and Whole Paycheck. It is more expensive, another reason I eat, and my great grand parents ate, less of it. If you buy your meat at a chain grocery, there is likely a 99% chance it is corn fed. Most of the stuff at Trader Joes is feedlot stuff to. I have seen some of it cynically labeled as "vegetarian fed" beef. That stuff is still corn fed from a feedlot, and pumped full of antibiotics to keep the cows from getting sick in those unsanitary conditions.
I highly recommend a book called The Omnivores Dilemma by Michael Pollan. He doesn't totally clear up the confusion, but does a good job of chronicling where the confusion comes from
Quoted: 550 Post(s)
Liked 325 Times
Need some advice on getting it DOWN. Spent spring training for century with 250 plus miles a week. Century went well and annual check-up weeks later my cholesterol was at lifetime high. I want off the statins - period. Total 210, LDL 112 and HDL 77. I must be doing something wrong. What did you do to get lower cholesterol?
Mine dropped from 244 total / 166 LDL / 61 HDL to 185 / 131 / 55 when I lost my first 20 pounds exercising more and eating less of the same things.
I'm guessing it'll be lower after loosing 40 more and will find out in May.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,572 Times
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
Agreed, the science on the effect of dietary cholesterol on serum cholesterol levels is pretty clear. This is a classic example of how poor government guidelines are hard to update even when the science clearly supports the change.
What works for me;
Breakfast-Steel cut oats-1/4 cup before cooking, 1 tbsp honey if eaten before a hard ride (80-150 Cap)
Mid Morning Snack - Apple, or Clif Bar if on a ride (100-250 Cal)
Lunch- Two small chicken tacos, al carbon style found at one of the ubiquitous taco shops around here (300-400 Cal)
Mid Afternoon Snack-Banana-(100 Cal)
Dinner- Some crap my wife likes to eat, often eaten out since she doesn't like to cook, and won't eat "that healthy crap" I cook- (500-1000 cal) (I did get her to kick the Margarine)
Other than the dinners, the weight would be coming off much faster. but my cholesterol is down. Eating out is a real challenge, but doing it healthily can be done. Mexican restaurants can have some pretty heavy stuff, but the better ones will substitute whole beans for refried. Refried beans are traditionally made with lard, but I suspect many places use Crisco, which is worse than lard. Soups are also a good way to avoid some of the worse stuff found in restaurant food, especially the big chain joints.
Bikes: Surly LHT, Novara Flyby, Seven Odonata, Trek beach cruiser
Could you explain in terms of nutrients: what are you consuming more or less than before (saturated fats, cholesterol...)?
One of the best ways to lower LDL cholesterol is losing weight regardless of the diet composition.
Exercise alone, without weight loss, probably does not significantly lower LDL.
From what I've managed to found so far, high saturated fat intake in combination with low unsaturated fat and high cholesterol intake can increase LDL (but not total fat intake alone or maybe even not high saturated fat intake alone until you get enough unsaturated fat).
A large cup of organic oats (bought in bulk). Too that I add a little honey and cinnamon. Not in a wrapper from Quaker.
Organic banana
Organic mandarin orange
Large tervis tumbler of tea. I prefer Yogi brand, either decaf green tea or echinacea.
Mid-morning snack will be medjool dates and/or dried apricots and almonds.
Lunch is usually salad and/or soup that I've made. I will occasionally go to Panera for their soup/salad if I can't get home for lunch. Pizza on occassion.
Afternoon snack can range from another orange to more almonds/apricots or pistachios
Dinner can be anything from whatever I feel like cooking or what our little market has. We have a really good lebanese restaurant close so we tend to eat a lot of veggies with hummus/baba and tabouleh.
I've continuiously refined my vegetarian diet over the past couple of years. The further I get from eating meat, the less I miss it. I am also having a problem eating fish. I guess you could call me a dirty vegan because I eat honey. On vary rare occassions I still have scrambled eggs if tofu eggs are available.
What else can I answer for you?
I was trying to understand which exact nutrients helped you to lower LDL cholesterol. As I understand you reduced saturated fats and cholesterol and probably increased unsaturated fat intake.
Bikes: 1989 Greg LeMond Le Vanquer, 2005 LeMond Zurich, 2010 LHT, Marlboro Fuji Folder
Double smoked bacon pieces dipped in coconut oil mayo are relentlessly improving my well being
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
However, that theory may now conflict with the (soon to be announced) recommendations of the USDA that will say that dietary cholesterol does not increase serum cholesterol and is therefor not a problem. So if that is true, then decreasing its absorption should not be effective it either.
Also, 'plant sterols' have been shown to decrease the absorption of cholesterol and are usually taken as a supplement or added to fatty foods like margarine.
For myself, I found that the plant sterols lowered my cholesterol (both total and LDL) by about 10% when I take 1mg before meals... I don't know if it makes me any healthier. But it does make my cardiologist happier...
p.s. I resisted taking the Plant Sterols (called Phyto Sterols) because, since I eat very little dietary cholesterol (actually none), then reducing its absorption should not do anything. But it did. So, I think the process may be that your body takes cholesterol from the blood stream to make bile acids -- and the intestine later reabsorbs and reprocesses that cholesterol. So, my theory is that the Phyto Sterols lowered my cholesterol by preventing my intestine from reabsorbing the cholesterol from the bile acids it made from the cholesterol and simply passing them out with the rest of the waste...
Statins (Crestor) and a mostly high dairy, vegetarian diet got that down to 169 total and an LDL of 90.
Switching to a Whole Food, Plant Based diet along with the Crestor got that down to: total 125 & LDL of 56
When I stopped the Crestor but stayed on the WFPB diet, it increased to: total 175 & LDL of 106
When I added PhytoSterol supplements to the WFPB diet, it dropped to: total 168 & LDL of 88
But, one additional thing that may have decreased it from its highs (aside from the statins and the diet) was a 60 pound weight loss...
Liked 2,572 Times
Aside from avoiding saturated fats, the only foods shown to lower cholesterol are soluble fiber rich foods such as oatmeal -- supposedly because they help to speed the process of pushing the bolus through the intestine and decreases the absorption of cholesterol.
And like you mentioned in the next post, just losing excess weight (however one does it) is one of the most important things to do.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I lost weight.
My Dr confirmed today ... I'm one whole point down.
I was 5.2 ... I'm now 4.2. She is thrilled.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bicycle Repair Man !!!
Cholesterol readings need to be taken with the understanding that there are more than two kinds of cholesterol... HDL comes in several types and there are two types of LDL.
The small particle LDL is the kind you don't want as this leads to inflammation and clotting issues, the larger particle LDL (light and fluffy) is relatively benign and can elevate LDL readings without causing you any harm.
After that it is interesting to note that in studies, half the people who have heart attacks have high cholesterol and the other half have normal cholesterol so one has to look further.
Triglycerides are a type of fat and high levels of these are a marker for metabolic syndrome and diabetes and indicate a higher risk for heart issues... if this number is high then one needs to take a serious look at what is causing this.
Another interesting fact is that saturated fat does not increase the risk of heart attacks or stroke and although it raises LDL, it increase the (benign) second type while lowering triglycerides.
Processed oils and excess fructose in the North American diet increases triglycerides... fructose does not metabolize like glucose and gets turned into fat. In excess it can cause non alcoholic fatty liver disease so this should be limited and only be sourced with fresh fruit.
My doctor has always been impressed with my annual checkup results and will admit I was probably dealt a good hand... after I started eating more fats and less carbs my already excellent numbers just got better.
We eat loads of vegetables (most of our carbs) as well as grass fed beef, butter, cheese, bacon, lard, coconut oil (lots of this), range fed chicken and pork, fish, nuts, and organ meats.
My wife was flirting with diabetes before she went on a carbohydrate reduced diet and added more healthy fats... now her numbers are nearly as good as mine and she also lost 80 pounds of post surgical weight after making this dietary change.
Our physician will only prescribe statins to people with hypercholesterolemia, he is also aware that higher cholesterol readings are not an accurate indicator of risk and that the side effects of statins are worse than the "problem" they were designed to manage.
In Real Life
Bikes: Lots
Liked 596 Times
Further to my post above ... my HDL, the "good" cholesterol, went up ... while my LDL, the "bad" cholesterol, dropped.
All good.
All good.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 75 Post(s)
One thing to remember is that in cholesterol screenings, the LDL is a calculated value. Your triglyceride level is part of the formula. If you are doing a lot of endurance work and watching what you eat, your triglycerides go down which causes in inverse rise the the calculated LDL. You can get a test that actually measures your total cholesterol, HDL, LDL, and VLDL among other things. Your insurance might not want to pay for it but I had it drawn just yesterday and it cost me about $75. I'm still waiting for the results. Don't expect vastly different numbers, but if your triglycerides are in the low normal range, both my doctor and the lab person told me that you may find that your actual measured LDL is lower than the calculated LDL.
I am supposed to be on statins as well, but don't tolerate them, even at low doses. I'm working to improve my cholesterol numbers and changing to controlled carb (not low carb, just cutting way back on high glycemic carbs) and a mix of both HIIT and steady state training on the bike, along with dropping 20+ pounds, has cut my triglycerides in half, lowered my total cholesterol, slightly increased my HDL, and kept my calculated LDL in the normal range.
Quoted: 4227 Post(s)
Liked 2,489 Times
The real enemy is refined sugar and too much added sugar in our diets combined with refined processed oils/fats , and not the saturated fat from animal foods.
He suggested that I take 2g/day of phytosterols (sometimes called sitosterols) which I tried. They are the ingredient added to some margarines to make them more cholesterol friendly as they block the absorption/reabsorption of cholesterol from the gut -- but they can also be taken in pill form as a supplement. Actually I take 2 gram before meals so that is more like 3g a day. It brought my LDL down from 106 to 88 -- which made him happy. And, I have not experienced any side effects from them.
Best of luck with your cholesterol test!
I have not yet read it, but I understand that that is the underlying premise of the "Blue Zones": whole communities that foster and support a multitude of healthy living habits -- from daily routine 'exercise' (which is NOT going to the gym but walking, doing manual chores, etc) to healthy eating habits to strong social mutual-support structures that support their members throughout their lifespans.
In Real Life
Bikes: Lots
Liked 596 Times
+1
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 454 Post(s)
Liked 164 Times
FWIW, with statins (at 40 mg - about as high as they recommend these days) at my last checkup my total cholesterol is 313. But my HDL is 108. My doctor calls my lipid profile 'fascinating'.
I believe that our family has 'lost' the cholesterol DNA lottery. My brother has readings higher than mine. He was finally able to get it down significantly with what he called a "grass clippings and oak leaves diet". It was very extreme and not sustainable (by his personal judgment). But it dropped his levels over 100 points (don't recall the details). Moderate and 'reasonable' diet changes had a limited effect.
Right now I am kind of a 'Atkins oriented' eater (probably eat refined sugar and/or refined grains once per month). About all that I have noticed is that exercise will bounce my HDL a whole bunch (lots of that now, so a high HDL). Diet (within my personal limits) seems to have a small effect. Since I tolerate the statins well, they cost little, and it makes my doctor and wife happy, I take them. I have serious doubts about them doing anything useful for me.
dave
dave
just another gosling
Quoted: 3911 Post(s)
Liked 1,960 Times
dave
dave
Quoted: 454 Post(s)
Liked 164 Times
While it is true that some people have a naturally high cholesterol level which has no health consequences, it is also true that the best way to reduce overall cholesterol seems to be to reduce one's BMI. It seems that few people with BMIs below ~24 have overly high cholesterol levels.
dave
