Want to dabble in gravel riding but not get a second set of wheels
#51
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
I have ridden gravel roads around me with 28mm tires, 32mm tires, 38mm tires, 40mm tires, and 43mm tires.
Ill give you a hint as to which I like most- its the odd numbered tire.
That isnt based on marketing, its actual experience. I can ride faster, more confidently, and more enjoyably when I have a quality and light wide tubeless slick with lower pressure.
Everyone is different and gravel is different depending on location. If someone finds a 28mm tire to be perfect, its their body- cool if they use that for their gravel. It isnt buying into BS marketing if you prefer some gear that is designed to excel in one area of cycling.
I will absolutely say that sometimes the marketing is just laughably BS- a gravel helmet that looks the same as a brand's road helmet? A gravel jersey that looks the same as a brand's road jersey? But that is pretty easy to push thru and ignore.
But rail trails? Yeah ride whatever.
