Just Acquired - ‘74 Masi Gran Criterium (mostly, if not all, original condition)
Quoted: 226 Post(s)
Liked 1,118 Times
Updated - ‘74 Masi Gran Criterium (mostly, if not all, original condition)
I just picked up this beautiful GC off of eBay (from a great seller BTW) and would greatly appreciate any insight anyone would care to offer. I believe it only had one owner and was kept indoors. Everything looks original but there are a few minor deviations from what I’ve read in other threads (handlebar tape color, plugs, cable ends etc.) Now that I can finally post photos after 7 years as a forum member, I hope that I’m not overdoing it. The first group of photos (in this post) were part of the auction listing and the last ones (in a following post) are some detailed shots that I just took.
I would like to experience the ride from time to time after a refresh. As I mentioned in another thread I exhumed, I plan to build up another set of wheels and preserve the originals. Suggestions? Also, I plan to replace and preserve the seat, pedals, brake pads, jockey wheels and whatever else to make it rideable; however, I want to make sure that I can always return it back to the original set-up.
I like the tire keeper and valve adaptor the original owner attached under the seat. I remember seeing those wire thingies hanging over the tires from the brake mounts back in the day but I’m not sure exactly how they would actually do anything. Also note the “motorcycle” style brake cable routing. All in all, this is way nicer than I ever expected - it looks more like a new bike rather than a “time capsule.” I would love to learn more about it from the knowledgable members here.
Montana, where men are men and sheep are lying little tramps.
Quoted: 226 Post(s)
Liked 1,118 Times
More photos.
Quoted: 4556 Post(s)
Liked 6,513 Times
Very nice.
That front tire saver is on backwards, you never want to see one grab the tire and wad up under the brake/crown.
Likes For majmt:
Liked 6,513 Times
Likes For merziac:
Quoted: 226 Post(s)
Liked 1,118 Times
The the seller was asked by relatives to help clear out the residence of the deceased original owner who was an engineer (in the Bay Area I believe.) He also had an impressive collection of Hasselblad and Nikon photo gear and darkroom equipment as well as very nice high-end hi-fi gear according to the seller. Really sounds like someone I would love to have met - so there’s another reason to do my best to conserve this bike. The seller told me that there was another bike in the same room as where he found this one but it looked like a “Sears” bike to him and showed much more use so he left it. I wonder if the other bike was a commuter/trainer and this one was just used to go to church on Sundays and parades. It really is in as fine condition as one could reasonably expect. This bike could really shine - all of the schmutz that you can see in the photos (even on the BB) is easily wiped off.
Quoted: 3466 Post(s)
Liked 2,839 Times
Ditch the front tire saver- there really is not enough room to flip it around.
in general tire savers in my view are for the rear if at all- one can steer clear often of debris but the rear wheel “follows” and will catch the junk most often.
i think a gloved hand is better.
you know of course this is a Carlsbad Masi.
after Falerio went home but Mario was running the shop- probably he brazed the fork.
buy American, Buy a Masi
original pump, original toe straps and pedals.
i would exchange the seat if it is a Suede #2 ( sticker underneath) Those matt down very fast and until fully matted down look meh.
missing are the little cuffs crimped flat and painted yellow for the cables, the top tube cable clip fasteners also got dabs of yellow paint. And the excess portion of the fastener snipped off.
wheels are probably original, maybe the tires, most came with Clement Criterium Seta 250’s.
don't see the ALE masi waterbottle, all white.
Original bar tape was yellow or white cloth, original plugs were Hunt-Wilde white molded vinyl. The American contribution.
replacement jockey wheels are around.
original freewheel and chain were Everest.
very good example of a near original bike.
great color.
has the original pump.
lose the reflector.
if you want to o be seen place a flashing LED light on the spare tire pouch.
I have four Carlsbad bikes.
things I don’t worry about-
i use Cinelli bar plugs
i have Martano wheels and clinchers
most have Binda Extra straps
( I did rivet them as shown like your bike)
later Campag lined housing- in grey.
great color.
lose the reflector.
Likes For repechage:
Liked 2,839 Times
Check the integrity of the tire adhesive.
Liked 2,839 Times
Get some grease between the shift cables and the painted guides!
grease the cable at the stainless housing too.
repack all bearings
repack all bearings
That's quite a time capsule. I haven't seen one that mint since they were making them new. Was this stored in a freezer? Those Del Mondo's look mint. Normally I wouldn't ride vintage tires, but silk tends to hold up and those look well preserved, at least enough to try them out around the block. Do they still hold air? Might need to be re-tubed.
If you want to build a set of new wheels, I'd suggest sticking with sew ups, but something with ferrules at a reasonable training weight. For example Mavic Championnat du Monde. You'll never get the full experience with clinchers IMHO.
I concur on losing the tire savers and reflector. Also, the rear wheel is all the way forward. It's a bit extreme. I'd adjust the adjusters to place the axle more in the middle of the dropout.
Liked 6,513 Times
Somebody needs to investigate to find out who clamped that reflector onto the seat stay and administer the proper amount of justice.
Likes For merziac:
www.theheadbadge.com
Quoted: 2446 Post(s)
Liked 4,466 Times
A time capsule of both the bike and the norms of the time.
-Kurt
Liked 6,513 Times
I see a rubber pad. Someone did their due diligence installing it and it'll probably come off without issue. The original owner likely put too much belief in the 1977 CPSC reflector mandates when they came out.
-Kurt
-Kurt
Quoted: 1871 Post(s)
Liked 670 Times
-Kurt
-Kurt
Liked 6,513 Times
Liked 4,466 Times
Liked 670 Times
I would reverse the brake cable sides, readjust the dropout screws, turn around the front tire saver, repack headset, wheel bearings, and bottom bracket. If I had Campy grease I’d use it. I don’t get obsessive about replacing the balls, there’s a real good chance they are all fine. I would clean them all and measure their diameters. If they y are all measuring the same they are probably good if not discolored.
great find!!!!!!! Mine is a little too small for me.
Nearly 2022 edit: repack all the bearings, and pay special attention to the bearing race and cone running surfaces. If you have a great local frame builder, have the frame aligned to original specs and the bb and headset installation surfaces chased and faced, as long as you have it all taken apart. If you drop the mirror but still want one (not the worst safety idea, attach it to the seatpost so as not to affect the paint. I would not be afraid of the old tires. If the rubber is not badly cracked or dried, the sidewalls are intact and have no broken threads, and the tires hold air well for a latex sewup, I’d take it out for a local test ride. Check the wheels for trueness and even spoke tension first.
Crawlin' up, flyin' down
Quoted: 1056 Post(s)
Liked 2,612 Times
Absolutely gorgeous bike. I'm very glad it has found its way to someone who clearly appreciates such a treasure.
Those Clement Criterium Seta 250 tires were absolutely top drawer BITD and were priced accordingly - $40 or more in 1970s dollars, IIRC. But they haven't been made in decades, so I would be wary of riding on them. They might - might - be okay of they were stored properly, but I would be careful.
On the other hand, @repechage didn't call them out. I see he (wisely) said to check the rim glue, but didn't warn about the tires themselves. He knows his stuff and I would trust his judgment, yea or nay.
Likes For bikingshearer:
Quoted: 226 Post(s)
Liked 1,118 Times
I really appreciate the observations and recommendations so far.
Quoted: 226 Post(s)
Liked 1,118 Times
I’ve been a bit confused about a few things but just had few thoughts after seeing the comments. First, per repechage, the bikes leaving the Carlsbad shop would have had Everest freewheels and chains, had yellow dabs of paint on the top tube guides and cable ends, probably different tires, and had yellow or white handlebar tape with different plugs. Salamandrine pointed out the extreme forward position of the rear wheel and you can even see that the original position was further back in the drop out. Yet, looking at the overall condition of the bike, I would guess that it was barely ridden enough to warrant replacing anything - everything really does look original.
It looks like the original point of sale was in Concord CA from the shop decal on the bottom of the seat tube and that coincides with the bike coming from the SF Bay Area. I’m thinking that the modifications may have been done at the bike shop before it ever hit the road. It makes sense that the original freewheel may have been swapped for the 14-28T Regina with a wider range for riding in SF. That may have required a different chain as well as moving the wheel forward to reduce interference. Also, the original owner may have requested that the bike shop reverse the brake routing which could’ve required modification or even replacement of the rear brake cabling along the top tube explaining why the routing guides are different than when it left Carlsbad. Maybe they rewrapped the handlebars in the process too.
Does any of that make sense?
Likes For majmt:
Liked 6,513 Times
Here’s a shot of the reflector mounting. Looks like it clamped over rubber or vinyl tubing to protect the paint on the seat stay. Hopefully, no need to seek retribution. Also someone applied a rubber wrap on the seat tube to protect it from the frame pump.
Liked 2,839 Times
Most Masi frame fit pumps had the flare filed flat at the point where it would contact the seat tube, done prior to painting which was done at Silca. if this one does not have that then I would consider doing that after some touch up paint was secured.
The rubber barriers may not be of help not as that often rubber outgasses and will leave a brown witness to its placement.
the bar plugs could easily be from an early exchange of stem length, most of these left with 10cm stems- anything could be ordered if the shop knew prior what to use.
this bike would most likely left with Giro bend bars.
the top tube cable clips are later- they look like the stainless steel versions- the bikes had the chrome plated type with the cadmium plated fasteners.
not surprising at all that they were replaced.
to not remove them for cleaning would invite rust. Once removed at the time they were inexpensive enough that replacing with the current version was no big deal. Reusing the original snipped top tube cable clip screw was often not a viable option.
almost every Masi the shop I worked for sold had something with the bars and stem changed, position of the levers, etc upon purchase. Bikes that came through with the 3ttt saddle almost universally had the saddle exchanged, there are plenty of UO8 level bikes with Masi M decorated saddles running around, purchased cheap, better than an Ideale 39.
we ordered #3 saddles often as the suede had a reputation for getting grungy fast.
the bikes left the factory with the rear wheel set as near as far as possible forward- minimal extension of the adjuster screws.
using a 14x28 might have required a longer chain AND shifting the axle back.
as a second set of wheels - I would look at one of the modern clincher rims and a nice set of tires.
my guess the pedals have never been serviced. The Campagnolo dust cap wrench won’t work with the strap in place. Maybe set those aside and upgrade for riding to a pair of SL pedals as many owners did. Straps were a consumable. There was a shoe cobbler near the shop I worked for that could fix the Masi style rivets in the era before toe strap buttons that detail did ease the grabbing of the strap to cinch.
Liked 2,839 Times
Masi was able to completely ignore the CPSC regulations when they came in. They were Race bikes. ( probably just a bit of low production volume luck )
Sunshine
Quoted: 11061 Post(s)
Liked 7,622 Times
Fantastic color and condition for its age!
I love the spoon stays too- the look works well on this bike.
