Bike storage..which is best..
Quoted: 212 Post(s)
Liked 202 Times
Just wondering what is best way for bike storage
Hang on hook?
Or upright in a stand?
Not a work stand
Will hanging bikes on hooks do any damage long term?
Appreciate any and all help
Thank you
Hang on hook?
Not a work stand
Thank you
Mad bike riding scientist
Quoted: 6284 Post(s)
Liked 4,324 Times
If I ever see any damage from hanging it by the front wheel on a hook, I’ll tell you. Considering that I’ve been hanging them for close to 40 years, I doubt that I’ll see any in the future.
Stuart Black
Stuart Black
Likes For cyccommute:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
This is going to have lots of opinions! I'm looking forward to evaluating each and every one!
I have a stand, on casters, with a padded bar where I have 6 bikes hanging by the front wheel. The spacing is kind of tight and you run the risk of scratches, plus I have to move at most two bikes to get to the third.
I have another stand with padded cradles that I use for the two cruisers because they're the bikes I reach for to take a quick spin with the kids.
Hanging by a wheel has the advantage of bypassing frame geometry, so mixte frames, ladies frames, modern MTB frames will all fit fine. I have no experience with hydraulic systems, so I'm not sure if hanging vertically is acceptable. I also like that the tires won't get crushed as they lose air. The displays in bike shops are probably ideal, but maybe not for long term if you're just storing them.
Quoted: 1467 Post(s)
Liked 1,495 Times
Many bike shops use hooks and hang bikes upside down from one or both of the wheels. I have two bikes and hang one (aluminum frame) on the wall upright, with a hook that holds the top tube. My other bike (carbon frame) just gets leaned up against the wall below it. I also have a set of hooks in my basement and sometimes hang the aluminum bike by both wheels from those.
I've read on the internet that hanging carbon fiber bikes from the frame is a bad idea, so I've avoided doing this... but I also see people (and some shops) do this all the time so who knows? I've also read on the internet that hanging bikes with hydro brakes upside down cause issues with brake lines losing fluid (or something like that). My instinct is that hanging a bike by the front wheel only might cause issues with the headset, so if I were to one-wheel-hang a bike I'd probably do it by the rear wheel.
My guess is that the only potential damage here is from the actual hooks scratching or scuffing the finish of the wheels or frame. Rubber coatings should solve this.
Likes For msu2001la:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
I hang my from hook in the garage. In the 10 years i've never had an issue. Maybe wrap them with tape to prevent scratching the paint.
Quoted: 583 Post(s)
Liked 1,028 Times
Suspension forks could leak out if upside down.
Quoted: 212 Post(s)
Liked 202 Times
Thanks
Appreciate the many opinions.
I have bikes on a coated hook and in a stand.
And ..as mentioned above...bike shops hang bikes on one hook. Sometimes for years !!!
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
If a bike is hung upside down, blood from the fork can run into the headtube and cause a headtubeache.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2732 Post(s)
Liked 6,056 Times
There are 5 in my garage hanging like bats and they love it. Really like that they don’t take floor space. Even my wife’s 50 lb e-bike is suspended on from the ceiling using a pulley system. Woe if the rope snaps and it comes down on her car. (Insurance agent: You mean your car was hit on the hood by a falling 50 lb bicycle? Me, well it actually is 53 lbs)
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Clark W. Griswold
Quoted: 4509 Post(s)
Liked 4,198 Times
My current set up for some of my bikes is the https://www.minoura.jp/english/storage/multiple/ds-4200.html however I am waiting for stock of the additional cradles so I can set up a second one in the basement for other bikes since I bought two stands and used cradles from the other one. It is not a bad set up but a little fiddly and not great for a bunch of drop bar bikes of the same size but not terrible. I would love to remove the book shelves near that rack and convert that wall to bike storage with some sturdy hooks and plenty of space between them with a few Willworx stands in between as needed.
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,548 Times
I try not to overthink this.
Over the years, I've stored them during the Winter season several different ways depending on the number of bikes at the time and the available space. Hanging from padded hooks has been the go to method. IMHO I believe that hanging upside down from two hooks is the best arrangement as it leaves more useable space below the bike (to store more unnecessary stuff ). Currently tho, the majority of my functional bikes hang on a padded hook by the rear wheel. I used to hang the front wheel from a separate hook but have recently started to simply hang the front wheel over the pedal. That does make for less useable space below the bike but does allow for more bikes to hang in the storage shed.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
The OP asked which is best. Best is indoors, elevated, climate controlled clean and resting in a padded cradle and suspended by the top tube.
On Your Left
Liked 2,434 Times
stored in the original unopened box
As long as it's not left out in the rain, does it really matter? With Covid, i've seen bike in the LBS for repair that have been sitting for 20+ years in the back of a garage. Most just need a tuneup and oil the chain. Some have dry rotted tires and maybe need new cables. As long as they're not rusted, all will work like new.
that's the bottom line.
Advanced Slacker
Liked 2,548 Times
Zip tie Karen
Liked 1,542 Times
Quoted: 1111 Post(s)
Liked 1,050 Times
From there, anything goes as long as its dry.
OP, I like hooks since they take the least amount of space. Once I leave this position in a few more years I plan to buy my own place. At that point the best will be a shed dedicated to bike storage and equipment. Tall enough to hang the lightest bikes by the front or rear wheel with room for other bikes to sit beneath and a ramp for easy in and out.
Quoted: 604 Post(s)
Liked 1,064 Times
Depends, I think it’s whatever system gives you more room, to obtain more bikes.
Tim
Tim
Likes For tkamd73:
Randomhead
Liked 3,798 Times
I might end up with three levels in my garage. Hooks are really annoying to me unless the bikes don't touch the wall. And I don't have room for that.
Zip tie Karen
Liked 1,542 Times
I have three types of bike storage in my garage. The previous owner had installed a Saris sliding bar adjustable rack with inverted hooks. This holds four bikes. Our two mountain bikes are on pulleys for ease of raising and lowering (they're tougher to handle overhead), and the pulley permits my wife to easily retrieve her MTB if I'm not home to do it for her. Third, we allow two bikes to floor stand on either side garage, nearest to the door opening, one for my wife (her daily) and the other, whatever I choose to have handy to ride that day.
So many bikes--
You gonna eat that?
So you're going to hop on the bike weighing.... what 200 pounds or whatever, ride the bikes over pavement, curbs, rocks, ditches, if it's a mountain bike, all that and more, and you're worried about what the weight of the bike hanging from a hook will cause to the bike?
Get some perspective.
perspective
When I bought my first "10 speed" back in 1974 or -5, the bike shop was selling my hard on some French brand, which was way more expensive and nowhere near as simipatico as the Univega I favored. The salesman was arguing really hard that this French bike weighed 1 1/2 pounds less than the Univega. On a long bike trip, that 1 1/2 pounds was a huge drag. I was almost convinced. And then the light went off and I said: "Wait a minute. I weight 250 pounds (or whatever). That's way less than 1% of my weight!" And I bought the Univega. Never looked back. Its second owner was my older son, back in around 2000 or so.
I think we get caught up in specs when we should be taking a step back and--as you suggest--thinking about whether these things make a practical difference for our use.
You gonna eat that?
