How Fast Does Your Chain Wear?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Liked 193 Times
My Trek Verve E-Bike is roughly roughly 0.6% worn, according to my chain wear checker after 1400km. I plan to replace the chain once it can easily slip through "0.75". At this point, I can push it all the way through when using some resistance.
I figure that, while it's not drastically worn out or anything, it's getting fairly close to the point where the rest of the drivetrain will start to wear much quicker. I changed my rear cassette to something with different ratios about 400km ago.
Does this sort of wear give any indication to how much stress the chain has been subjected to throughout its use? What sort of mileage intervals can you expect an average chain to endure under different riding conditions?
As Kerry Irons says "How long is a piece of string?"
Likes For cxwrench:
Liked 797 Times
*The first and last one I bought - a Park, told me that my new chain was at 0.75%
Likes For Litespud:
Guest
I get 1500-2000 miles out of a chain most of the time -- maybe more, but that's when I change them. To me, a new chain is cheap drivetrain insurance.
Drip, Drip.
Liked 193 Times
It seems to me like chainrings and cassettes wear slower than the chain. As long as your drivetrain is all equally worn out, you can get a ton of useful service life from the three parts without causing extra wear on one part versus another .
My e bike is either being thrashed, climbing hills, hauling groceries or any combination of the three, along with being regularly subjected to conditions which are downright horrifying for the drivetrain. Rain.. mud, lots of sand, etc. I do try my best to keep the drivetrain clean or at least properly oiled, but id expected the wear I got after just 1400km to be on the extreme side .
Drip, Drip.
Liked 193 Times
Litespud I tried my Amazon chain wear checker on four different bikes, including a brand new chain. I seem to have gotten very accurate results with it.
I agree that the ruler method would be the most accurate way to check. But neither methods would account for side to side wear of the chain.
Drip, Drip.
Liked 193 Times
As the drivetrain started to wear, I noticed that I constantly have to tighten the barrel adjustor on either the shifter or rear derailleur to get the bike to downshift properly. Otherwise it will lag a few seconds or not shift at all. Its very difficult for me to get the line tension dialed in for both up/downshifts for very long. I'll see if replacing the chain will help with it.
Also, my e bike downshifts rather roughly under power, even though it's designed to detect gear shifts and cut power. This will definitely put extra wear on the rear cassette as well as chain.
SE Wis
Liked 3,704 Times
From my machine shop and surveying experience, I prefer a 14 or 15" as then you can "cut an inch" and run between 1 & 13" to line things up better and get more accurate readings.
https://www.officedepot.com/a/produc...E&gclsrc=aw.ds
Heft On Wheels
Liked 561 Times
Yep, I use a ruler and just measure. Being I am a wax user I have a two or three chain rotation for use on my road bikes. So the 2-3 chains I have on the bike take me about 5 or 7 years to go though. I average 2-3 thousand miles per year on my trainer bike and maybe 500 miles on my "superbike". Another 1000 on the gravel bike.
Few things I do to maximize life out of chain - avoid riding in the rain if you can. Maintain consistent cadence which means shifting as often as needed to maintain cadence. Because if you're using just one or two gears all the time, those cogs will wear faster. A worn cog will accelerate wear on chain and you'll be replacing that cassette sooner too. And finally, keep your chain clean. If using wet lube, wipe the chain down with rag after every ride.
Liked 5,486 Times
Moisture My previous bike I had to replace the chain when only 4500 to maybe as much a 5500 miles on it. That was the soonest I've ever replaced a chain. I'm thinking it might have been because I did ride that bike up hills in the big/big combo quite often. But no other catastrophe that the Cross Chaining is Evil people seem to allude too. I run my current bike with Di2 in full synchro mode so it never gets into a big/big or small/small situation and the chain seems to be well on it's way to exceed the previous bike's chain by a long distance.
On an e-bike, I might suspect that you are pulling off from stops or accelerating hard when in too high a gear ratio. The additional help an e-bike motor provides seems like it could easily hide the fact you are in too high a gear ratio and putting a lot of stress on things that can't handle thetruth stress! <grin>
don't try this at home.
I have the Park Tool adjustable chain checker, with the sliding pin and % readout. It's quick and easy. But it's measuring roller wear more than elongation of the chain.
I also use this machinist ruler. It's stamped "D. B. & S. Prov. R I." It could easily be 120 years old or more!
It's hard to keep a ruler aligned with the chain. I have to look at it straight on at both ends to be reasonably accurate. I measure against the edge of a pin, not the side plate. I pinch the chain against the ruler at the 1 inch mark and read the 13 inch area.
To speed up the process a little, I put tape markers on the ruler at 1 inch and 13 1/16. The ruler is in 32nds.
2/32 = 0.52% ( the math: 2/(12*32)=0.0052 )
3/32 is 0.78%
So just 1/32 is a significant amount of wear. The ruler method needs careful accuracy to be useful.
3/32 is 0.78%
Likes For rm -rf:
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Liked 1,314 Times
Lots of folks have answered you question so I’m not going to comment on that. My local bike shop tends to have sales on chains every couple of months on different brands so when KMC goes on sale I buy 5. Since I ride all winter I just replace the chain at season change a 15-20 chain is far cheaper than 50-150 chainring and/or cassette. I do the same thing with brake pads and the like
Mother Nature's Son
Liked 1,580 Times
I get a lot of miles on all the drivetrain components. I live and ride in a mostly flat area on paved roads that are in good shape, overall. I throw in a mix of off-pavement, occasionally. I am usually around 155 lbs.. do not mash and do not do all that much braking. I keep my bikes clean and properly lubricated. My bikes usually get a lot of grit and grime only on windy days with sand and dirt blowing, wet pavement, or on the occasion I go on gravel or cinder roads or paths. When any of that happens, a quick cleaning is done right away. Pretty sure all that helps the mileage.
Drip, Drip.
Liked 193 Times
So I just replaced the chain today.. and the new one is about 3 links short too short even with the master links added in. I will contact my LBS and ask them for some spare links.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Liked 895 Times
I seldom get 4000 miles from a chain. My wife seldom gets less than 5000 miles from a chain. We ride a lot together and we have the same chains. I will occasionally ride in rain, she will not. I often have to wait for her on climbs, and I do more climbing when cycling alone. Those few differences matter. From what I've seen of some e-bike riders, I wouldn't be surprised if their chains would wear twice as fast.
Likes For andrewclaus:
12 Speed SRAM chain waxed and ridden in dry conditions? 10,000 miles easily
I have almost 7000 miles on my current chain and it still measures dead on. But, I am certainly not the strongest guy in the peloton.
My tandem chain was recently replaced with maybe 1500 miles and it was so sloppy that the timing chain fell off a few times.
So I guess that means that there is no answer to "how long does a chain last," any more than "How long do tires last."
Important to note that the OP's bike uses a mid drive system. Mid drives put a lot more strain on the chain than ebikes that have motors located in the wheel hubs which actually reduce chain wear
Likes For alcjphil:
It seems that
Sit and spin: long chain life.
Bigger riders with big watts, sprint starts and/or steep hill climbs: shorter life.
OP's admitted inability to properly adjust his rear derailleur may hasten chain wear.
Drip, Drip.
Liked 193 Times
Shifting performance has improved dramatically up and down the cassette, particularly when downshifting under power, approaching a hill This suredly will put much less strain on the rear cassette as well as chain.
Well, if anyone could bend a pulley I suppose it would be you! As so many others have, I encourage you to build a relationship with a shop that has even a minimally competent mechanic. Your bike will love you for it.
Likes For shelbyfv:
