Pedal came off during my ride
slow on any terrain
yesterday, Oct 16. LBS guy said he didn't tighten it enough during assembly. Does this happen very often?
the bike in question
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1596x918/sella_ronda_at_homex_2ea5788fb6145563f6e83d0ce3f6bdda8d7d68a1.jpg)
Quoted: 4896 Post(s)
Liked 4,067 Times
Often happens when the bearings are in poor shape. With good bearings, the torque you apply to the pedals gets reversed and tries to tighten the threads. (That's why left side pedals are left-hand thread.) When those bearings aren't working, your torque is now trying to unscrew the pedal. (On a fix gear, if that pedal actually freezes up, you better either have no foot retention or hope that mechanic didn't give the wrench that last tug because you will be unscrewing the pedal with the bones in your foot.)
Likes For 79pmooney:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 149 Post(s)
Liked 327 Times
Not a pedal but once snapped a crank arm with basically the same result: planting my clipped in foot on the pavement going at speed. Do. Not. Want. Again.
Agree it must have been frozen to the axle for some reason, as the threading is reversed to prevent inadvertently coming off.
slow on any terrain
Quoted: 4227 Post(s)
Liked 2,491 Times
This isn't supposed to happen...It's obvious that whoever installed the pedals didn't tighten them enough.
slow on any terrain
slow on any terrain
slow on any terrain
Thanks to all of you who responded!
Quoted: 1649 Post(s)
Liked 1,875 Times
Just get a some Allen wrenches or a pedal wrench and put it back on yourself. Pedal installation is not something you need to go to the bike shop for.
Likes For icemilkcoffee:
hello
The bike shop guy was completely swamped with work--his single employee had just quit when I brought the bike in for assembly--so it's evident to me the guy didn't act with due care. On an earlier ride, the rear wheel slipped out of the drop and rubbed on the frame. Also, derailleur adjustments were not done right (2nd opinion from another LBS). Don't think this guy will see much of me going forward.
Also, with the collection of bikes you have, you should be wrenching yourself…
Likes For roadfix:
Quoted: 2748 Post(s)
Liked 493 Times
Happens all the time, really freaked me out when I was a kid and it happened the first time, I thought the bike was falling apart! All it takes is someone who doesnt know how to properly tighten the pedal and installs it anyways. Heck, last time I put pedals on it took me a while to figure out how to use the other as a “backing wrench.” If I had to do it again, I’d have to figure it out again. I’m sure the Walmart employees are trying their best but it’s an easy mistake to make. It’s easy to figure out how to screw the pedals on lol.
Sunshine
Quoted: 11104 Post(s)
Liked 7,712 Times
As for the pedal issue, no idea what brand those pedals are, but if they are junk then buy some higher quality ones that have smooth bearings and a quality spindle that tightens reliably.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1267 Post(s)
Liked 341 Times
That bike looks nice. But you need to check EVERYTHING regardless of price. Likely the only thing wrong was being not tight on the crank. Did the pedals feel grindy? Some now have crazy 1/16" loose balls. If so, do NOT use them.
4 years ago I bought a discounted new roadster IGH bike for $1000, from a very good LBS that sells midrange bikes of all kinds. Nobody else wanted to buy it for 2 years. LOL. I knew I would want to switch almost all the parts too.
>> Threaded headset was poorly set and half lubed at the factory, so it wouldn't ooze out I presume. Was a year before I got around to getting a 32 mm wrench to look at it.
>> Cruiser pedal loose bearings were tight, I took them apart OK, but needed better ones with pegs anyway. At least they had proper size bearings, 5/32" I think.
>> Spokes were not tuned. I straightened them out and rode them awhile until I switched the wheels for a diff SA IGH and dyno hub.
>> The Nexus 7i had tight bearings as well. Plus horrible roller brakes impossible to not have drag.
>> The bare alu rims looked like they were put thru a belt sander. OMG.
>> The grips were stupidly tight, to put my bells and mirror on. I cut them off and garbaged them. Slimy rubber like tires anyway. WTF
>>>> I ALWAYS ALWAYS have tools with me.
Bikes: Lemond Poprad, Cervelo Soloist, Cannondale F4, RANS Velocity Squared
Quoted: 42 Post(s)
Liked 67 Times
You bought a bike online or something and brought it to a shop (overworked and understaffed). I am assuming there was a charge for this service. Also, 10 different mechanics will have 15 different adjustments to said derailleur.
I am not justifying poor work. I would and have bought from the LBS directly. But as you said, if they do poor work, take it somewhere else.
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 629 Post(s)
Liked 942 Times
Finding a consistent, reliable bike mechanic is like finding a good barber.
My hair/beard look great!! So far, I've only found one of the two.
I check everything after getting the bike back from the shop - even things on the bike that weren't supposed to be touched.
And the shop only sees the bike if it's a problem I can't fix myself.
Take the bike in for a wheel repair, sit on the seat and it bottoms out... they for some reason moved the seat and didn't re tighten it the seatpost.
I've found just about everything to be loose, not shifting properly, chain blobbed with mass amounts of lube, things over tightened...
Likes For Jughed:
Quoted: 377 Post(s)
Liked 446 Times
I had a pedal come off on a ride, but it was 20+ years old and had 10's of thousands of miles in it (my first clipless pedals, purchased ca. 1992). The pedal body came completely off the spindle - it just wore out. It wasn't a big issue, I only found out when I tried to unclip at a light and had to use my other foot. When I moved my right foot outboard the pedal body slipped completely off of the spindle, still attached to the cleat. I slipped it back on, and finished my ride. I had to focus (1) on clipping out with my other foot, and (2) on keeping my right foot inboard so the pedal didn't slip off.
I agree with others who posted above, that you need to find a new LBS. There's no excuse for not doing a proper job when the consequences can be serious injury (or worse) for the user. I don't care how "swamped" he was, that is simply inexcusable.
(Gorgeous bike, by the way.)
Quoted: 583 Post(s)
Liked 1,030 Times
This could potentially upset me. Anyone building a silver bike with Campagnolo has to care about a scuffed crank from the get-go due to the builder's obvious neglect. How bad is it?
Bikes: Kona Dew, Gary Fisher Paragon, Salsa Campeon
Quoted: 128 Post(s)
Liked 140 Times
I had this happen with a high end mountain bike from probably the most reputable manufacturer out there. Stuff happens!
Quoted: 8449 Post(s)
Liked 9,408 Times
Happens all the time? I can't recall seeing a pedal come off, ever. Was following a guy through a turn and his crankarm came off and I ran over it.
Had 3 pedals snap off and I crashed twice. Had a Look pedal unscrew from the spindle while climbing a canyon. Suddenly my foot was out by the front wheel.
Friend snapped an Ultegra crankarm and crashed. Another snapped a Campagnolo crank and also crashed. I was following a big guy down a singletrack trail and when he landed from a small jump his BB spindle snapped off and he made a cloud of dust when he went down.
Was rolling my bike around the garage and a pedal fell off. Another Look pedal which came unscrewed from the spindle. I put Loctite on them now.
Likes For big john:
slow on any terrain
So I am trying to understand this situation...
Being impetuous, I bought a third bike, a Tommasini Tecno from Italy about the same time as I bought the Bertoletti. When it arrived, I decided to take it to the other LBS I deal with and it turned out to be a great decision. Set up right the first time. Here are the Kirk and the Tecno:
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/kirk_no_wheel_decals_c460227b9e2f89f0f58ad283f4edb1463c7a01c7.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1124/techno_portrait_3c41c62314f8e96e031fb54f5c850c597860edcb.jpg)
Quoted: 18596 Post(s)
Liked 16,098 Times
