Resonance danger
Quoted: 2748 Post(s)
Liked 493 Times
Resonance danger
Hey guys, have you ever had your bike start to vibrate rhythmically? Normally I’ve seen this when riding without hands, and the handlebars start to shake and can quickly escalate into something dangerous. I think of this as resonance, and was very happy that my carbon road bike doesn’t seem to exhibit it, but after a few trips to the shop it now has developed a resonance.
Can someone who knows what I’m talking about expand on the phenomenon and suggest recourse, other than holding onto the handlebars?
thanks.
thanks.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 894 Post(s)
Liked 1,250 Times
Likes For Barry2:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2750 Post(s)
Liked 6,105 Times
The times it has happened to me, I was going over 40 MPH. Certainly gets your attention.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
On motorcycles its called “death wobble.” I’ve experienced it on both motorcycles and bicycles, and it can be a little hair-raising. There are some things you can do to minimize risk, make sure your headset isn’t loose, the axle bearings aren’t too worn, and balance your front wheel. Wheel balancing is easy. Put your bike in a stand and rotate your front wheel, let it turn freely, and see if the same side always comes to the bottom. Take a bicycle computer magnet, the kind which attaches to a spoke, and put it on a spoke on the opposite end. You can move the magnet up or down the spoke to change its effect on balance. The wheel is in balance when you can spin it, and it stops in any position randomly.
Likes For 50PlusCycling:
Quoted: 4079 Post(s)
Liked 7,666 Times
Putting your fingers in your ears should stop the resonance.
Likes For tomato coupe:
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Quoted: 697 Post(s)
Liked 911 Times
Is this the same bike with the tire where the bead has separated from the sidewall?
Likes For wheelreason:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 77 Post(s)
Liked 132 Times
Likes For awac:
Quoted: 575 Post(s)
Liked 619 Times
Was this on the bike you said on 4/8/24 "My back tube popped (tire is worn out so not going to try and replace tube) right as I was leaving work, I have to ride 6.5 miles home and then another 6.5 miles back to work before I can realistically fix it. I don’t think I have a narrow enough tire at home. It feels like a bucking bronco but it’s nothing unmanageable if I keep the speed down, luckily it’s just the back tire."?
Likes For easyupbug:
Likes For Bald Paul:
LR÷P=HR
Quoted: 894 Post(s)
Liked 1,250 Times
Likes For Barry2:
Likes For Steel Charlie:
Quoted: 4343 Post(s)
Liked 1,413 Times
Hey guys, have you ever had your bike start to vibrate rhythmically? Normally I’ve seen this when riding without hands, and the handlebars start to shake and can quickly escalate into something dangerous. I think if this as resonance, and was very happy that my carbon road bike doesn’t seem to exhibit it, but after a few trips to the shop it now has developed a resonance.
thanks.
thanks.
Did you know there are ways of searching for stuff on the intertubes?
https://velo.outsideonline.com/road/...-to-stop-them/
Klaatu..Verata..Necktie?
Quoted: 10659 Post(s)
Liked 12,328 Times
I got that once years ago my my Ritchey, coming down a short but fast non-technical descent. I hit 40 and the bike started wobbling and scared the hell out of me. I think it was the first time I'd gotten over 40 on it. I had only had the "5 Minute Fit". I took it in for a professional fit, where he dropped the bars, raised the saddle and moved it forward, which balanced my weight better, and it never recurred. I always credited the fit for solving the problem, but years later I read that wobble can be more of a random thing.
Quoted: 4895 Post(s)
Liked 4,067 Times
Speed wobbles. 13ollocks describes them well. It is an oscillation caused by a driving force (that can be as simple as road vibration) and a system (Bike, wheels and rider) with a resonance of the same frequency (or harmonic of it). And it can vary from a minor scare to terrifying and high speed crash causing.
The cause is usually a combination of a particular bike and a particular rider. Sometimes simple changes are a permanent fix. Two things a rider should be aware of, one as a frequent cause of the wobbles and the other, usually a quick fix - the death grip on the handlebars; back off! Firm but NOT rigid! And the preventative/quick fix; place your knee on the top tube. That usually has a very large damping effect on the wobble.
I have one bike with the issue. Sadly my best custom that fits and rides like a dream. Recently I did a fast descent that while not absurdly fast, I have had to back off for the wobbles on the past. Tried lifting my butt a little off the seat with my legs a little more tensed, hands firmly in the drops with real weight on them and the bike stayed quiet. Haven't yet gone to the really fast hills trying that but I see that experience as encouraging.
Likes For 79pmooney:
climber has-been
Quoted: 3605 Post(s)
Liked 3,795 Times
I think there are any number of factors that can initiate a speed wobble - road surface ruts, loose headset, unbalanced front wheel, etc - however, whether or not this relatively small input propagates/amplifies into a full-scale wobble is due to different factors, like F/R balance, "death-grip" on the bars, frame flex etc - factors that promote system resonance..
Likes For terrymorse:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 432 Post(s)
Liked 1,027 Times
Muscle tremors from other causes (nerve-related or due to exhaustion) are suspect too.
Climbers sometimes suffer from what they call "sewing-machine leg", which is no fun, either.
Liked 4,067 Times
Yup. And aging. Or, one of the best preventions is confidence. My bike that wobbles - only showed up once early on. On a cold ride with rain. Now, out of my early 50s and into my 70s, it is far worse. I carry warm clothes and stop and put them on for big descents even though I'll be on nice warm level ground in 10 minutes. On my other, non-wobble bikes I dress the compromise between comfort and convenience.
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 271 Post(s)
Liked 1,173 Times
One of my road bikes is particularly susceptible to speed wobbles. I attribute it mostly to the 50mm wheels, as it will only start to pick up a shimmy at speeds above 40mph, with battling winds present. In dead calm conditions, I've confidently had that bike nearly to 60 w/o issue. I've tried changing my contact points when it starts to happen and keep a light touch on the bars, but nothing seems to fix it other than dropping below 40. Oddly enough, my other road bike with different 50mm rims, doesn't have the same issues. I can feel the wind pushing the bike, yet it doesn't develop the shimmy.
Quoted: 688 Post(s)
Liked 761 Times
A Resonance Cascade occurs when a Negative Mass Crystal is scanned by an Anti-Mass Spectrometer.
Although I will admit that the possibility of a resonance cascade scenario is extremely unlikely, I remain uncomfortable with the...
Quoted: 1012 Post(s)
Liked 1,713 Times
So... Speed Wobble...
Front Brake or Back Brake?
As I remember on a Motorcycle it was feather the back brake...
