Surrogate Stem (Spacer) For Bike Shipping?
Hello,
Here is an interesting challenge (or maybe not if you have been here before).
I will be shipping/carrying my bike on several tours this summer. To get the bike into the box the bars and stem will have to be removed. When this happens I would like to find something that I can put on the steerer tube to take up the height of the removed stem so that I can hold the fork and headset bearings in proper position during shipping.
So far I have spent considerable time at the local hardware and home improvement stores looking for various plumbing and similar supplies that I could make a spacer from without success. Common sizes go from just under 1 1/8" (too small) to over 1 1/4" (too big). I have also considered regular stem spacers but I really need about 42mm worth which would require many small and easily lost individual spacers.
For those that say to just leave the stem on and take the bars off there is a complication. The bike has an Ortlieb clik-fix? handlebar bag mount which blocks access to the handlebar bolts and is a real pain to take on and off which I would rather not have to mess with.
Any thoughts on where I could get or make a suitable headset spacer?
Thanks,
Steve
Thanks,
Steve
Clark W. Griswold
Quoted: 4496 Post(s)
Liked 4,180 Times
Why? Just get a locking headset spacer and done. Problem Solvers makes one: https://problemsolversbike.com/produ...headset-spacer and it is designed for exactly what you are doing. No need to futz around with anything just throw that on underneath your stem and done. Remove your stem as often as needed with no problems.
Likes For veganbikes:
Quoted: 4236 Post(s)
Liked 3,963 Times
A piece of PVC plumbing pipe, many wraps of masking tape, more headset spacers, custom machining a piece of metal, an old stem all can work. As could many other methods.
There's no real need for the headset to be preloaded during shipping. keeping the various parts in their proper order is more the issue and that's really only for convenience during reassembly. With good packing a slightly loose fork won't cause any problems.
BTW headset spacers have been made in more then 5mm thicknesses. the 40mm+ height would take fewer spacers with 10 or 20mm ones and a zip tie for keeping them with the packing stuff when on the riding part of the trip is easy too.
I've packed a lot of bikes over the years for customers and myself (including that really important person, the wife) and I don't sweat this detail too much. It's not rocket science and a perfect solution that allows preload adjustment is overkill. Not a bad result but IMO not worth too much effort and not needed. Andy
AndrewRStewart
AndrewRStewart
Quoted: 863 Post(s)
Liked 1,105 Times
I have also used a zip tie cinched up tight with no issues of loosening. A few rubber bands made from old inner tubes and stacked on each other can also work. veganbikes suggestion of a locking spacer above is probably the best idea though as you don't have to mess around with getting the proper preload when re-assembling your bike.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 891 Post(s)
Liked 1,242 Times
That locking spacer is very interesting.
Although I love the Get Outta Jail free card in the instructions….”If your fork features a carbon steerer, consult the fork manufacturer to confirm compatibility, ”
I think I’d rather tie my all carbon fork into the frame with string or small bungee cord.
Barry
Barry
Quoted: 568 Post(s)
Liked 425 Times
Locking spacers were common for mtb's cantilever hangers, this allowed a rider to change stem angle and height without needed to re-seat a headset, but it was mostly to keep brake cables fixed.
Quoted: 4585 Post(s)
Liked 1,740 Times
When I box bikes for shipping, I cut a strip of cardboard the height of the stem and wrap it around the steerer and then tape to form a cylinder. Then put the cap on. You can slide it off and reuse it, or replace in in 2 minutes.
I like the locking spacer thing for travel, though. Especially if you aren't great at getting a nice headset adjustment.
Likes For Kontact:
As others have mentioned I am not quite ready to put a metal clamp around an unsupported carbon steerer tube. Normally stems are clamped against an expanding plug inside the tube which equalizes forces and prevents crushing/damage to the steerer tube.
Liked 1,740 Times
Good idea for a temporary fix.
And plenty of carbon steerers, which are all the same wall thickness, have been used for decades without compression plugs inside the stem clamp. People talk about that sort of stuff like it's a time bomb, but really it is just additional steps manufacturers specify to prevent improper stem torque causing a failure. Because people overtighten their stems.
Likes For Kontact:
SE Wis
Quoted: 2755 Post(s)
Liked 3,427 Times
Quoted: 716 Post(s)
Liked 807 Times
Have a 3d printer or know someone who does? Designing a surrogate stem would take about 10 minutes and printing it might take an hour or two. Simple would be just designing a tube with the right internal diameter and length. More complex would be designing that same tube with a clamp that can be tightened around the steerer.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 681 Post(s)
Liked 766 Times
If there's a bike co-op near you, they'll have a bin full of old stems they'll practically give away. The shop I volunteer at has a full bin and we just recycle them now.
I found this on amazon and ordered one.
https://www.amazon.com/dp/B0868JQV9Y...hk_typ_imgToDp
I'll have to cut it down to length. The same seller also has this in silver.
Quoted: 1636 Post(s)
Liked 1,844 Times
The beauty of this clamp is that you can put your stem off and on as often as you want and never have to worry about adjusting headset tension any more.
Quoted: 863 Post(s)
Liked 1,105 Times
Far too much worry about this clamping spacer on a CF steerer. You don't need to torque it to the same tightness as your stem. Snug it up so it stays in place and all you have to do is add your stem when assembling the bike out of the box, no switching around special spacers or whatever for shipping. Not really an issue but if it worries you just loosen up the clamp bolt after you have installed/tightened the stem and you will just have what is plain spacer. Any properly made CF steerer will have no problem with this spacer and much easier to live with.
Quoted: 5960 Post(s)
Liked 2,869 Times
If you want something cheap and light, take your fork to the hardware/plumbing store. Shop either PVC pipe or vinyl tubing. Cut off a piece as long as your stem is tall, plus a bit more. Then you use your top cap and spacers to keep the fork and headset secure.
Personally, I prefer to remove the fork to make the package more compact, and to ensure it won't get bent if the box is dropped or crushed. I stretch plastic wrap oer the head tube, trapping both bearings, and likewise wrap all the spacers and top cap onto the steerer.
FB
Chain-L site
FB
Chain-L site
Method to My Madness
Quoted: 2063 Post(s)
Liked 1,557 Times
Both bikes I have bought online were packed and shipped with the handlebar removed from the stem, rather than removing the stem from the steerer. Does the former approach not work in your case?
Liked 1,557 Times
Liked 1,740 Times
We all forgot the perfect fitting spacer to replace the stem: A stack of headset spacers.
