Sugino 75: Designed to work with Shimano BB?
#52
My experience:
The Shimano 107 BB works fine with the Sugino 75. Not quite "on" but close enough.
I am now running the proper matching Sugino 75 BB with the cranks and it actually feels different. Smoother, quieter and a dead-on chainline.
While running the Shimano will do you just fine, if you can afford to, get the matching BB. Having the proper set-up just "feels" right on many levels.
#53
Originally Posted by absntr
My experience:
I ran a 107 shimano with Sug 75 added a spacer to the bb and the chainline was dead on and it was quiet and smooth until the bb crapped out. Now running a phil and it is again smooth and quiet.
In your experience does the Sugino let the cranks sit deeper than the Shimano? My guess is it is the same, since it managed to change your chainline when switching from a 107 to a 109 bb. But who knows...
#54
Definitely, the quiet and smooth changed with the chainline. It was 1mm off with the Shimano. You could barely tell but you could see the chain come onto the chainring at a very slight angle.
And yes, the Sugino BB lets the cranks sit in deeper. They're pretty close to the BB shell, with no odd gaps - whereas the Shimano showed quite a bit of gap. This of course has to do with the BB cup and cone sticking outwards but it also feels like it went on snugger. All of this is "feel" rather than actual science like you folks have been debating but sometimes, "feel" feels right.
#55
MADE IN HONG KONG
Bikes: some but not enough
Sugino may be managing their tolerances to a smaller variance. Shimano BB are made for gears and crossed over chainlines so will not care as much about how consistant their products are. Sugino prob cares a lot more and will reduce the variance in their products (i.e. impose a tighter manufacturing tolerance than the industry standard) which will result in repeatability between parts (i.e. better chain line as advertized). Remember there is industry tolerance and there is manufacturing variance. How you manage the variance depends on what your audience demand and how much they are willing to pay.
#56
if you want to be cheaper about it, just buy the damn sugino bottom bracket spindle and use whatever japanese cups and bearings that you have. i run sugino 75s on my gitane, which is french threaded and just use sugino french threaded cups and quality loose bearings. my price ended up not being too much lower than the actual 75 bottom bracket cost, but that's because the french cups are rare and expensive. almost any garbage-ass bottom bracket on a bike from the 80s japanese bike boom will have suitable cups. buy the 30$ spindle from aebike or realize that the shimano (or whatever) JIS bottom bracket that you buy will work alright, but is not ideal, and shut the **** up.
#57
Bikes: Custom DeanUSA El Diente CTI, Rich Adams Track, Johnny Coast Fixed, Argon18 Gallium Pro
The Shimano BB-7610 square taper 109mm track bottom bracket is still available from the UK. If you want to use a sealed BB this is a good option.
I use it. No chainline worries. No noisy drivetrain. It works.
I have three. All bought from Swinnerton in the UK.
#58
every scar has a story
#63
meet the mets
Bikes: Raleigh conversion (hours spent making it look like a Pista); Porter Track, Samson Track, Leto Roadie.
My experience:
Schloe-no frame yet. This week, hopefully? I'm taking the mailroom guy at work out to lunch tomorrow in anticipatory thanks for signing for an endless barrage of boxes over the next couple of months.
Originally Posted by monkey
You could be doing blow off a dead hooker with a needle sticking out of your arm and you wouldn't get kicked out of Humboldt.
#65
Originally Posted by chicagoamdream
Naz, I was waiting for you to weigh in. I'm kind of wincing at the thought of spending $90 on a part that I'm not even going to get to see on a daily basis, but I'm determined not to cut corners with this build (spare me the usual "bottom brackets are as important as hubs" speech, everybody). Always nice to see threads that are actually about bikes get this much attention. Maybe I'll be able to get a DA headset off of eBay for $5 and it'll all even out.
As for DA headsets - ebay has em cheap! There are a few for $6 right now. You can get them under $30 easily. Campy too...
#66
meet the mets
You might actually see the BB daily - the cups are on the outside so if you look down, there they are. It's a beautiful BB, very nicely made. But that's aesthetics and quality I guess.
Fortunately, it's all interchangable...
