Total Geekiness
#1428
Bikes: www.amoebalight.blogspot.com
Originally Posted by dwoloz
Looks cool, good job
I saw those pond lights before but forget where you can buy them. Have any more info?
https://forums.mtbr.com/showthread.php?t=245737
#1429
Hey folks: My DIY lights are great. I have run into a little problem with the glue. I glued the waterproof light switches to the PVC pipes. Worked for a short while(2 weeks) then failed. Seems the glued stayed on the PVC but not the switches. I used the WP switches from batteryspace.com and 5 minute epoxy. The are made of hard plastic. Any recommendations on other glues that may work? I was thinking marine goop. Thanks Charlie
#1431
I had the same problem using some JB Weld. I am now using Devcon Plastic Welder. This stuff is supposed to have a solvent that helps melt the plastic. So far the stuff seems very robust. I picked it up at an Ace Hardware by me. It definitely helps to rough up the surface with some sand paper, then clean real good with alcohol.
#1433
I put the Pond Scum light together, too. My parts list is about $62.50 and includes only 1 front light. However, there is great xenon strobe light included... if the thing lasts that long!
I posted my solution on the Car Free Living forum
https://www.bikeforums.net/showthread...05#post3472205
mainly so those guys could find out about this wonderful thread!
#1435
Recumbent Evangelist
Bikes: Rebel Cycles Trike, Trek 7500FX
Has anyone looked into the possibility of utilizing a dynamo hub as a trickle charger to a battery?
#1436
I was thinking more along the lines of having it charge while it wasn't being used during the daytime (I know some people take their batteries off when not in use but I just keep mine on)
I feel it would indeed be complicated but something maybe worth looking into
#1437
You're right then, a generator could be used to charge the battery during daylight hours. Heck, you could even slap a solar panel on there and have it charge while the bike is parked at work!
#1438
My All Electronics xenon strobe failed and I'm going to replace it. I need something to mount to the rear of my trunk box where the strobe is. I've thought about getting one of those magnetic mount amber flashers with the cig lighter plug on one end. Anyone use a tail light built for trucks/trailers? I use a 12v 8amh LAB with seperate switches for headlight and tail. Suggestions welcome.
#1439
Trans-Urban Velocommando
Bikes: 06 Trek 1200 - 98 DB Outlook - 99 DB Sorrento
This has nothing to do with lighting, but it just beat all of you by eleventy-billion geekofactor and 401 watts.
Link for those who wonder WTF it is:
https://kc-bike.blogspot.com/2006/12/war-biking.html
#1440
Senior_Member2
Bikes: Beater + Nishiki Bigfoot X-29
Ok got me a 20w hal light. MR16 last i checked. i dont have a batery but i did test it with a 12v source, and its way brighter than any led light.
And the reflector housing is NOT water tight... i got proof... failed water test... MORE HOT GLUE!
EDIT:
Firstly, hot glue, totaly useless, as the light it self gets hotter than the melting point of the glue. Sencondly, the WHOLE housing started to get too soft. so here is my failed attempt at a bike light...:
EDIT:
#1441
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
When I arrived at the transit mall this dark AM I was praised for my strobe tail light by a Suit headed for San Francisco. The 35 watt headlight meant nothing to him. "They would have to be blind to miss that taillight."
So I told him about the blind man driving back east with his kid in his lap giving directions.
#1443
I'm sure you could find something at an auto parts store. Here's a few thought:
https://www.commandelectronics.com/in...il-lights.html
#1444
OK. Got my All Electronics strobe working. Finally got around to tracking down a loose wire-to-connector connection. Just in case I bought an amber, twin bulb, trailer marking lamp and an automotive, two contact, flasher unit. Has anyone tried this combination. Will the flasher work with my 12v 8amh SLA battery?
#1445
Senior_Member2
diff lock2 Love the play dough fixture
I think Epoxy will fail at -20C ((-20) degrees Celsius = -4 degrees Fahrenheit). I think ill find out the hard way.
were on earth is my epoxy?!
#1446
Originally Posted by diff_lock2
yeah, I'm thinking of keeping it as the housing, but i gota find my epoxy cause hot glue melts at the operating temps. Actually i think im going to figure a way of mounting it with out glue! like a clip or something!... but im gona need epoxy for the clip.
#1447
I'm confused... Now I've seen that both the radioshack strobes and the all-electronics ones have failed on people because they can't handle vibration? If I buy one, I want it to last a while. What is the recommendation?
Thanks!
Thanks!
#1448
Mine has been working for the 2 weeks I've had it. And others here seem to use them. But I can't speak to how long they will last.
They certainly are great lights though... very brilliant and run at less than 2 watts.
#1449
Senior_Member2
OR use a hose clamp around the whole unit
Thanks for the heads up... ill try caulk for water proofing...
#1450
I am not a car
Bikes: Giant Revel 1, Surly Ogre
Thanks!
Thanks!
Last month I noticed a bit on condensation on the inside after a hard rain. I drilled two small holes on the bottom of the yellow cover and it cleared right up.
"Bad facts make bad laws." FZ
