EAI Round
Old 06-28-05 | 03:48 PM
King of the Hipsters
Bikes: Realm Cycles Custom
EAI Round
I recently put a 130mm 52t SuginoSR ring on my bike.
I didn't have an EAI cog with 18 teeth, so I put a cog made by another manufacturer on the hub.
As I spun the pedals with my bike on the workstand, I could see the chain loosening and tightening as everything went round and round.
I thought I might have somehow put the chainring on the spider off center, and so I tried Sheldon Brown's method of centering the chainring.
I spent half an hour trying to center the chainring and didn't get much improvement.
Anyway, I rode with this combination for about two weeks, listened to the chain noise which came and went rhythmically, and eventually decided I had an out-of-round chainring.
Today I decided I had sufficiently habituated to the 75.9 gear inches that 52t X 18t X 23mm provided and I might find it interesting to play around with 80.5 gear inches.
I rummaged through my parts box, found a 17t EAI cog and put it on my hub.
As I spun the pedals my chain did not go up and down.
As I rode my bike with the EAI cog, I could hear nothing from the chain.
All along I had had an out-of-round cog, and not an out-of-round chainring.
I won't name the manufacturer of the out-of-round cog.
Suffice it to say that EAI has made at least one very round 17t cog.
I have found that with SuginoSR chainrings from Sheldon Brown on the outer position of the spider, if I use an EAI cog with the flange against the hub, I have a perfect, silent chainline with no loose or tight spots in the spin.
With this bike, a 2005 Pista, I have decided to buy and use only EAI cogs.
Ken Cox is offline
Reply
Old 06-28-05 | 03:56 PM
absntr's Avatar
Frankly, Mr. Shankly
20 Anniversary
I trust no other aside from EAI and DA. Though when those Phil's come out, I'd be quite tempted to run one of them on my Phil hub - since they were made for each other.
absntr is offline
Reply
Old 06-28-05 | 04:49 PM
Fugazi Dave's Avatar
Beausage is Beautiful
20 Anniversary
Bikes: Nabiis Alchemy
I've got a Surly cog that I've been pleased with. Paired up with Sugino, Salsa, and FSA chainrings I've never had any uneven tension issues.
Yo. Everything I’m doing is linked on What’s up with Dave? but most of note currently is Somewhere in Japan.
Fugazi Dave is offline
Reply
Old 06-28-05 | 05:11 PM
Surferbruce's Avatar
i'm trying to get used to around 80 gear inches and it's a bit much for me right now. i had a nice training ride the other day, all pretty flat, but commuting-especially in any kind of headwind- is a little bit of a grunt. i've got 48x16 (81 in.) right now, but i just ordered a 44t ring to put me at 74.2 in. which should be about perfect.
let me hear how over 80 inches treats you.
Surferbruce is offline
Reply
Old 06-28-05 | 05:25 PM
Bikes: Univega - fixed conversion
that is, freakishly, my exact same set up and exact same experience.
Slartibartfast is offline
Reply
Old 06-28-05 | 05:43 PM
Paul And Pista's Avatar
Slow in traffic
Bikes: 2002 Bianchi Pista, Cannondale R1000
It might also have had to do with differing chainlines. Some cogs evidently give chainlines a couple mm off of EAI's. Sheldon: https://sheldonbrown.com/gloss_ch.html#chainline
Paul And Pista is offline
Reply
Old 06-29-05 | 03:59 PM
poppalurch's Avatar
I rode 49x16 here in SF for about a year. I've never liked the SOMA cogs-pure ****e. Dura Ace and EAI wear very nice and even, and are usually quiet. Any noise I ever have comes from the chain.
I just started using the new miche 2 piece cog setup, and I'm very pleased.
poppalurch is offline
Reply
Old 06-29-05 | 07:45 PM
Name the cog! Name the cog!
BostonFixed is offline
Reply
Old 06-29-05 | 07:51 PM
phidauex's Avatar
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
Please name the cog... Reviews don't help if you don't know what was being reviewed!
peace,
sam
phidauex is offline
Reply
Old 06-30-05 | 10:37 AM
taras0000's Avatar
Lapped 3x
peace,
sam
I agree. Save other forumites from running into the same problem.
taras0000 is offline
Reply
Old 06-30-05 | 11:25 AM
cicadashell's Avatar
heliocentrist
consider me to be (at least) the fourth user who wants to know the cog manufacturer.
also, ken, when you say "rhythmically" i assume you are referring to a "periodic" chain noise. i'm thinking you could tie it to either the chainring or the cog based on the period, relative to turning the cranks. if the noise (or loosening-tightening) is "rhythmically" synchronized with turning the cranks, then it really has to be related to the chainring, don't you think? alternatively, if the period is synchronous with the wheel rotation, then yes it pretty much has to be the cog. if it isn't really in sync with either, though, then the problem is likely with both the ring and the cog. at least that's what i think.
cicadashell is offline
Reply
Old 06-30-05 | 11:49 AM
I also run EAI and DA cogs, but just picked up a 17t 3/32" Phil for my offroad fixie (with a fixed/fixed KISS-OFF rear hub).
They've used a basic gunmetal blue finish, so it doesn't look like the polished SS one shown on the Phil website.
Quality seems excellent, on a par with EAI, but hopefully less prone to the cracking issues that have surfaced with some of the EAIs.
$41 from Brent at Phil, kinda high, but this way there can be no doubts as to thread stripping-if it ever happens, God forbid, it won't be because of mismatched parts...RC
RCMann is offline
Reply
Old 06-30-05 | 01:08 PM
Soma
Ken Cox is offline
Reply
Old 06-30-05 | 01:29 PM
My Soma cog is a little off too. Will probably swap it out for an EAI soon.
r0cket- is offline
Reply
Old 06-30-05 | 01:35 PM
12XU's Avatar
Dismount Run Remount etc.
Bikes: A couple customs and some beaters.
I ride 48x16 in somewhat hilly Pittsburgh and once acclimated have had only a little trouble making it up even some of the toughest hills.
12XU is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
