Pulling trailer with road bike
n00b
Bikes: Mt. Shasta Kilimanjaro
Is anyone pulling a trailer with a road bike? I'm currently pulling my kids around in an aluminum Performance trailer with my 10-year-old, too-small-for-me, no-suspension mountain bike. I have looked at hybrids, and they seem okay, but I sat on a road bike the other day and immediately felt at home with the frame geometry and drop bar. And, boy, have road bikes come a long way since my '86 Centurion LeMans. So now I'm thinking about something along the lines of a Giant OCR or Specialized Allez. Any opinions on whether the frame is up to trailer duty? What if the rider weighed, say, around 230 (for now)?
UareFASTjustNOTfastENOUGH
Bikes: Scott Gambler, Scott Ransom, Bianchi C2C 928
You should have no problem with either of those bikes pulling a trailer. Plus both are very nice bikes so you should get the one that fits/feels best to you.
n00b
Thanks. I used those two bikes as examples of what I'm interested in. I plan on riding everything I can find in my frame size and budget and basing my decision on what feels best.
Year-round cyclist
There might be a problem with the road bike : most don't have low gears and you'll need much lower gears to climb hills with the trailer.
Of course, if you live in a flat area, it won't matter.
n00b
Most of the bikes I've looked at have had triple chainrings. This area isn't too hilly. There are some challenging hills, but for the most part there's an alternate route that's mostly flat. I don't think I've dropped into the smallest chainring on my MTB while towing yet... well, maybe just once...
Back when I was young and pain was temporary, top tubes were flat, and shifters were on the down tube, I did several tours with a 42x52 double. Including mountain tours. Ouch. I did a century in the mountains on that same setup. I'm thinking a modern road bike with a triple chainring will seem like a treat.
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
They might have a triple like your MTB, but their gearing is nothing like your MTB. Most MTB's come with a 44/32/22 triple. Most road bike triples are 52/42/30. Your MTB probably has a low gear of 22-30 whereas the best you'll find on a stock road bike is usually 30-25. Couple that with the taller tires on a road bike and you'll be hurting in no time flat. But, I don't know your area and if it's as flat as you say it is then you could be alright. I'd try to do a practice run first though before committing to a road bike.
n00b
I understand the gearing is different. Funny thing is, I don't even like using my small chainring because I feel like I could expend less energy and make better time just pushing the thing.
Even when I rode it off-road, if it was steep enough to need the small ring, I couldn't keep the front wheel on the ground. When I leaned forward to weight the front, I just spun the rear tire. Mountain bikes just aren't for me, I guess.
Now, I wonder if there's an LBS that will let me hook up a trailer to a test bike and take it out of the parking lot so I can try it out on what passes for hills around here.
Even when I rode it off-road, if it was steep enough to need the small ring, I couldn't keep the front wheel on the ground. When I leaned forward to weight the front, I just spun the rear tire. Mountain bikes just aren't for me, I guess.Now, I wonder if there's an LBS that will let me hook up a trailer to a test bike and take it out of the parking lot so I can try it out on what passes for hills around here.
I pull my son in a trailer w/ my road bike (triple). I even ride a hilly 15 miles and I'm a small woman. If I can do it you can do it, no problem! I'm not saying it's not challenging, because it is! But, it's definitly doable! My husband did have trouble getting the hitch to fit on his OCR. He ended up having to grind off a little bit of the hitch and it works fine now. You might want to take your hitch w/ you when you look at bikes and see if it would fit.
No one carries the DogBoy
Bikes: Roubaix Expert Di2, Jamis Renegade, Surly Disc Trucker, Cervelo P2, CoMotion Tandem
I have pulled our Cougar 1 trailer with a cyclocross bike (road-geometry with beefed up frame/wheelset) and with a hybrid. Both are okay, but the mount is via a skewer. I don't think I'd put a chainstay mount on a road-bike. The gearing comments are appropriate if you are planning a road-double, but I think I heard you say road-triple so no worries. One suggestion though, if you can find it get a 30/39/52 instead of a 30/42/52. 39/25 is just so much easier than 42/25. Anyway, here are my observations. Trailer + Child ~ 50 lbs. Me ~ 220 lbs.
Cyclocross bike: Kona JTS. Gearing: 28-39-50 Chainring, 11/32 9-sp cassette.
No problems towing around town, but my mirror is a bar-end mirror and I can't see both my daughter and behind me, its either or. As soon as the grade increases to 6% or so I am in or around 39/28. For longer(1/2 mile)/steeper(>6%) uphills, I have hit 28/32 several times. For downhills, I don't think the brakes are strong enough, and I get significant pushback from the trailer. My typical comfortable crusing speed with the child is about 12 mph. Without I go around 16. Biggest issue: no kickstand. I have to lay the bike down to take the child out of the trailer because its too hard to find a wall/object to prop against and still be able to get a the trailer. Plus, the trailer moves the bike a bit as we take our daughter out, and the bike tends to fall even if propped up. I can't fit a kickstand to the bike because of clearence with the bottom-pull derailleur and the small space between the chainstay bridge and the seat-tube.
Hybrid: Specialized Crossroads Elite XC. 28/38/48, 8-sp 11/32.
The upright position and bar-end mtn mirricycle allows me to see both the kid in the trailer and traffic behind. The upright position doesn't rob me of any speed unless the wind is REALLY blowing. The linear pull brakes are much better on downhills than the cantis on the JTS. It feels a bit more natural to me to be pulling the trailer with the hybrid than pulling it with the JTS. Gearing is similar to the other bike, but I find myself dropping to the 28 ring more often on this bike than the other. I don't have a computer on this bike, but I think I probably go slower on it, mostly because of the attitude/feel of the bike. The kickstand makes this bike much easier to use since I can stop in the park right next to the play area and let our daughter run free much more quickly than I can with the JTS.
I don't want to discourage you from getting the type of bike that you want, but definately concern yourself with quality brakes/pads and proper gearing if you go road-bike. Also concern yourself with the ability to mount a kickstand. Road-bikes often have tight clearence between the seat tube and the chainstay bridge with bottom-pull derailleurs. That means traditional kickstands are likely out of the question, and chainstay/hub mount kickstands may interfere with the trailer mount. I hope that was helpful.
Bikes: Giant OCR1, Marin mtn bike
I use both road bike and mountain bike to pull my son in his trailer, depending upon the surface. Lately, I've been riding at a paved fitness park area, and have been using my Giant OCR-1. It works great pulling the Burley - no problems at all. It was difficult in the beginning with the gearing (yes, even with the triple), but I was a beginning cyclist. It has really helped me get stronger with my riding in general. I usually ride about 50 trailer miles a week in summer with this setup.
Trailer with child is about 75 lb. I was 190 when I started cycling 2 yrs ago, now down to 160)
n00b
Originally Posted by phinney
Another vote for the skewer hitch.
So far no problems pulling the trailer with the Mt. Shasta. I was in the shop this weekend drooling over a candy-apple red Allez.
SWENC Biker
Bikes: Bianchi Brava (2000)
I got my first "real" bike just before my son's first birthday. I have always been a road bike person, so there was no question in my mind about that. I bought it and the child seat at the same time. My large child outgrew the seat quickly, so we replaced it with a Chariot Cougar 1. Now he's using an Adams Trail-a-Bike. All of them have worked fine witht he road configuration. I will say this: you may want to consider a touring or light touring model; that's what I have, and the slightly longer chainstay means I can use a kickstand, which has been helpful, although clearly not necessary. The other thing is, that while I agree with other comments taht the skewer hitch is wonderful (it is also an option with Burley trailers, apparently), I had a bit of trouble with it on my road bike. The skewer that Chariot includes has a very long threaded side, and the nut on that side (the non-quick release side) is open so you can screw it down as tight as you need to. However, as it is designed to fit anything up to crazy-wide mountain bikes, it stuck out frighteningly far from my hub. I ended up using the skewer from my wife's hybrid on my road bike, and the Chariot skewer on her bike, although there are clearly many other solutions as well. The overall moral of the story is, while I never took it up the Alp d'Huez, I also never, in the four years I've been trailering, had to get off and push.
You'll be fine -- enjoy!
I found a best of both worlds scenario in a older Cannondale touring bike. It has similar geometry to a racing bike, light aluminum frame & drop handle bars, it deals nicly for my occasional need for speed. But, a longer sturdier frame, triple chain ring, heavier duty wheels, wider tires, all of which help distribute and remove the drag of my 40-pound daughter in a bike seat. (we are 220 together)
The combined attributes make for a quick and supportive ride as we cruse the trails, hit the assault or run over the occasional curb, while pulling a Burly trailer.
I primarily use my road bike to pull my son in a trailer - a Bianchi Sport SX (I think). It has no granny gear - which really stinks, but when I ride regularly it builds my leg muscles - getting up hills is rough though. I've never had a problem. I occasionly use a really old Schwinn (a bike I got in the sixth grade that somehow still fits me) hybrid bike. This is more comfy for me, but the bike is in such bad condition I don't like to be seen in public with it.
If you feel more comfortable on a road bike (as I do), you should get it. Some may disagree, but a 30x25 or 30x27 low gear is plenty low for pulling a trailer.
Right now, the dedicated trailer hauler is an 80s GT mountain bike, but I have pulled our twins' Chariot Cougar 2 with both my road bikes, including my carbon fiber racing bike. With the skewer hitch I didn't think it would put any greater stress on the wheel than a hard sprint. But I would never put a chainstay hitch on CF.
Agree with the comment that a kick stand is helpful. Especially if you're loading two kids.
Deffinatly, check the trailer before buying!!!
I was out with a friend, and I ended up pulling his daughter. I couldn't clip because my heel would hit the trailer neck.
Certifiable Bike "Expert"
I pull a Burley Encore with a road bike. I use the chainstay mount, but I think the skewer hitch would be better on a modern road bike.
I have three road bikes - two 1980's steel bikes and a 2000 Cannondale R800. The R800 has short, fat aluminum chainstays and I can hit the hitch mount with my heel if I'm not careful, but it's not a major problem. I never hit the hitch on either of the steel bikes.
I mostly ride on a local paved trail, but I do ride a mile or so on the road from my house to the local trail. There is one large hill on this route and it's located so I have to climb it on my way home.
The Cannondale is a 39X53 double crank and that gearing is fine for me.
One of the 80's steel bikes is a Centurion with a 42-tooth small ring and a smallish 7-speed cassette. It's a bit tough to crank up the hill going home at the end of the ride, and I find myself in the bottom two or three gears if there's much of a headwind, but it works okay.
The other steel bike is a Schwinn Passage. It's set up as a 42x18 fixed gear. That means 20+ mph at 90 rpm... a little tall for the flat and requires some serious strength for the hills. I can power up the big hill on the way home without a whole lot of trouble, but I wouldn't want to pull a trailer with a 70+ gear-inch fixed gear over very many hills.
The chainstay mount will mar your finish, so I recommend getting a skewer-mount. My bikes are older, and I'm not that anal, so it's okay for me.
"Strength" of the frame will not be an issue. You aren't going to be putting more force onto the frame unless you get stronger legs.
Gearing is acceptable with my double-equipped road bikes, FOR ME. You may be weaker or may like to ride hillier terrain. Unfortunately, I live in a city and I don't feel comfortable pulling the trailer on the local roads.
I regularly ride my De Rosa with a Burley Solo. Skewer mount. No problems at all. Difficult on the hills, but nothing problematic. Still riding a 53x39 up front, 13-27 on the back.
No reliability problems with the bike. Ultra-light alu/carbon fiber frame, bike mounted Campagnolo Chorus, with bog standard wheels (36 spoke Mavic Open Pros).
Not very long rides (20 odd km), and very enjoyable both for my daughter and myself.
Here is a picture, a crummy one of me, but a decent one of the setup and the daughter!
I pull our Burley D'lite with a Seven Axiom, skewer hitch. I hit my foot on the hitch with the rear triangle hitch. Running a double 53/39, 12-25 in back; I'm fine with mid range hills on that (Up to about 7-8% sustained, short bits up to 10%). If I were planning on pulling significantly more weight (My son is about 25 lbs), or climbing steeper hills, I'd probably rather have more gears there. 10% sustained was doable but not much fun. I've pulled this up to about 45 miles over rolling terrain. I wouldn't recommend this gearing for someone who wasn't a strong hill-climber on their own, though.
Keith
Keith
Bikes: Decathlon 9.2, Peugeot
Originally Posted by plin
My fear is not about going up but rather coming down. If I am going at 40Km/h downhill I have the impression that I am slow as a snail and chewing my brakes. But I am sure that even that's way too fast if I am pulling a trailer especially in the switchbacks. How fast do you come downhill and how do you manage the slow speed? The only way of having a nice ride with my son is pull him up for about 800 vertical meters and ride on a plateau.
a trailer; I played it very conservatively at first and sped up as I got used to how it handled. Even with experience though, the trailers don't lean and can't corner sharply. Managing speed isn't as hard on a gentle downhill as I initially thought it might be - at least my trailer produces a very large amount of wind drag which limits downhill speed. I've gone down several hills where my wife (on her own bike) is coasting and accellerating away from me, while I'm pedalling with the trailer. I do avoid steep slopes where possible. Anticipating your need to stop is also good - try your brakes out well before you think you need them, so you know how much slowing they will give you. If the hill is steel enough, I tend to brake in chunks, rather than continually riding them on the way down.
Keith
Tossed some weight
Bikes: '96 Specialized Rockhopper, '70's Fixed Fuji, '02 Organic Engines Troika Tandem Trike
You roadies pulling those wide trailers with kiddies in the road freak me out. You place so much trust in drivers of automobiles. I would probably freak you out too, I put two kids on the back of my xtracycle equiped mountain bike, and ride on greenway trails. We're all probably all a bit nutty.
I pulled both of my children in a trailer pulled by my road bike (with a skewer hitch). Currently, my younger child rides a trail-bike -- I'll pull the trail bike (she doesn't pedal much) AND the trailer using my triple-equipped road bike. I'm in Colorado and some of the uphills take effort, but it's certainly doable.
Redrom, consider this commentary about the level of perceived "control" of a situation and the amount of risk people are willing to accept. The less control you have, the less risk many people are willing to accept, although statistically the real risk is equal or less than that of many other everyday activities.
Example: Some people are terrified of flying, and a significant population feel some anxiety in the plane because they are not in the driver's seat, so to speak. This is not a rational fear, but people feel the fear anyway.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
