Help me with my Raleigh Twenty
Bikes: 8 bikes - one for each day of the week!
Here it is, my latest project. I need a bit of help in choosing a direction, and I'm sure I'll need plenty of advice. The first photo set was taken right when I got it home. Pretty sad, but looks like the rust is only on the parts that are going in the bin anyway. It's got a sticker from the original dealer in Queensland, celebrating 50 years! 1926-1976. I guess that puts the bike at around 30 years old. Some parts of Queensland are pretty dry, which would exlpain the mud wasp nest in the seat post. Since it seems to be in pretty good shape, with the exception of the rust, I'm not sure how much I want to change. Someone please tell me that it has no collector value, to just make it something I can enjoy on a regular basis.
The wheels are pretty crappy, but they're getting replaced anyway. Oddly, the front is a 36h, while the rear is a 28h. Do I have the hub laced to a new hoop, or look for another hub, possibly a 5 speed/derailleur combo. See next post for a follow question to go with this one.
I've read the bottom bracket nightmare stories. My cotter pins came out with a lot of coercing, but they weren't happy about it. Into the bin with them. I was able to unthread the BB by hand. The bearings were all there, and dry and dusty. I cleaned them and the inside of the frame, then greased them up and whacked them back in. It's a hack job, but until I figure out what to do with the bike, I figured it's best not to start replacing stuff.
So here's my question, which is related to the one in the previous post: Is there any reason to try to keep the bike original? Do I modernize the drivetrain, or try to keep it intact as it came from the factory? Suggestions?
Cheers.
Cheers.
Raleigh20 PugFixie, Merc
Bikes: 1982 Raleigh Twenty Hotrod Fixie; 1984 Peugeot Premier Fixie, 2007 Merc Lightweight folder
This one by Lenny Taylor is a very good example - lovely new S7 drive and light wheels but with bright chrome and original paint:
https://lennytaylor.freeyellow.com/Twenty.htm
...possibly a 5 speed/derailleur combo. See next post for a follow question to go with this one.
Keep us posted on any news!
Huw
My Raleigh Twenty site | foldr : A flickr pool | #6460, #5632 & #3407 on the fixedgeargallery
Bikes: 2020 Thompson Randonneur, 2008 Davidson Custom Titanium, 2012 Custom Seven Steel Tandem, 1981 Shogun Touring Bike, 1974 Raleigh International
Is is hilly where you live? You have a lot of choices for gearing.
Are you planning to take the bike with you on trips? If so, packing size is important.
Do you expect to ride it in the rain?
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
One way or another, PLEASE share with us your progress. Can't wait to see that bike in decent riding conditions.
Rafael
Rafael
Feel free to follow me on Instagram
Thanks.
I'll keep you guys updated as I continue to get my hands dirty.
You can date the bike by looking at the date stamped on the outer shell of the SA 3-spd. hub. Here's a link to older SA hub service manuals, it's probably an AW hub, I've been through mine, they're really not that complicated, just make sure you keep careful track of and properly reinstalling the pawls and pawl springs:
https://www.users.globalnet.co.uk/~ha...samaintind.htm
I'd also recommend spraying some WD 40 or other light-med weight rust inhibitor into all the drain/vent holes in the small frame members, e.g. the chain and seat stays and lower braces.
Those look like they might be 451 rims. My 20 has the 406s. More tire choices are available for the 406 rims.
I geared mine down, from a 15T rear sprocket to a 19T, for better hill climbing performance.
Some links:
https://www.gaerlan.com/others1/ralei/ralei.htm
https://www.users.globalnet.co.uk/~hadland/twenty.htm
https://www.sheldonbrown.com/raleigh-twenty.html
https://drumbent.com/folders.html
Some links:
Thanks for the tips. Even though the chrome is bad, the frame is pretty much rust-free.
Anyone want to offer rim suggestions? I'm thinking of just going budget on this right now, and getting some cheap BMX wheels. Should be easy to locate a front one, but the rear hoop will have to be a 28h to match the hub. I've already got some brakes, so once the wheels are sorted, I just need to mount a seat, sort out the bars, and hopefully it will be rideable.
The 28H hub limits your choices on rims, my hub is a 36H. Here's a couple of Sun rims from bikepartsusa, it says they are M-13 rims, 20 x 1-1/8, sounds like 451 rims to me. Perhaps Raleigh put 28H hubs and rims on the 451 bikes and 36H hubs and rims on the 406 bikes?
https://www.bikepartsusa.com/product_...ml?p=01-124371
https://www.bikepartsusa.com/product_...ml?p=01-124369
20-inch rim page:
https://www.bikepartsusa.com/view.pht...m&f_c2=20+inch
Wheel sizing chart:
https://www.bikecult.com/works/wheelsizes.html
20-inch rim page:
Wheel sizing chart:
I'm hoping to sort out the wheels while I'm still over here. I did read somewhere that Raleigh Dragsters got the 28h, and the others got 36h. More research to be done. I'll start with the LBS and see what they can order. I have to decide if I want all black components, or silver.
Industry Maven
Bikes: Thylacines...only Thylacines.
Silver.
One of my first bikes was a Raleigh Commando, which looked like a non-folding version of that bike that came in fluoro orange and had 3 speed 'grip shifters' (I think).
Kinda explains my lifelong obsession with orange.
And irony. (An orange bike called 'Commando'?)
*edit* Thank you Google ->
Beats having one with a brown stripe called "Commando". I thought the orange was to match your hair? Explains why so many of my rides have no paint...
Isn't black the new silver?
Industry Maven
Naw, pink is the new black which means silver is the new pink. Trust me on this
Actually, 3D Violet could make a comeback which would make fools of us all.
I wonder what those grip shifters were that were on the Commando?
Actually, 3D Violet could make a comeback which would make fools of us all.I wonder what those grip shifters were that were on the Commando?
Bromptonaut
Rafael
Originally Posted by Rafael Guerra
We ALL KNOW that the fastest folders are the White ones. That is a scientific fact.
Rafael
Rafael
[edit] If I repaint it, I've got to choose a color. Damn non-titanium tubing!
Bromptonaut
Expatriate,
If I had to repaint your bike, I would paint it blue again. I think this is the first blue 20 I've seen and somehow, it is the most good looking one. I really want to see in which direction you are going to take it.
Rafael
PS: you might be right, red ones may be the faster ones. My giant 1/2way is just the exception to make the rule...you know...a rule.
Rafael
Metamerism. Google it. The frame is actually more blue/green than blue. I'd really like to salvage the paint. The front mudguard has some damage on the lower edge. Maybe replace them with some chrome ones? Who knows, I've only had it a day.
Offhand, anyone know how many teeth on the chain ring?
I think this is beyond 'restoration' but a very good project bike.
I read Sheldons site extensively before starting and this is what I have done so far;
Metal polish and wax the frame.
Replace stem with 'aluminum comfort bike' swivel threaded type stem. used
Aluminum risers bars meant for same.used
Aluminum seatpost and sprung saddle (mountain bike size). used
New break pads and tires.
I bought a garage sale mtb for the deore bb cranks and pedals. (instructions per Sheldon). obviously used
Next (and most expensive) will be a set of sun-ringle ici-something 451 rims in 28 hole.
These will effectivley double my investment to date.
Have fun with your project.
Bromptonaut
Ici,
Newspaper on hands, a saturday morning looking for garage sales and US$300.00 will make any bike enthusiast in the USA a happy soul.
It's amazing what you can get from a divorced wife, upset girlfriend, rich fella or just the average "got this bike to get in shape and used it once" kind of thing. Good places for upgrades too (just like Ici did)
I've seen some nice stuff out there. If I had the space...
Rafael
Rafael
Rafael, if you were in SoCal, I'd give you my brother's address. The last bike I bought from him was a custom Cannondale that he spent about $3500 on. It was 2-3 months old, and I gave him $750 for it.
He has BADD. Bicycle Attention Deficit Disorder.
Wait. My Twenty is bike number 10 at my house. [inserts foot into mouth
Bromptonaut
If everything goes right 2006 will be a year long remembered. My federal grants will go up (I am a researcher) and I will be able to move from the apartment I am currently residing. priority #1 will be getting a second bike. May even get one of these twenties to work and learn about bikes. Or an european folding tandem. Or a road bike. Another Dowtube maybe...ok, let's just change subjects.
Rafael
Rafael
