Seriously, how big of a difference...
... does a bike that weighs (say 23lbs) compare to a bike that weighs 15-17lbs. Lets say you're interested in racing Cat 5 and you have an average fitness among those racers. Is having the heavier bike going to have a big enough effect on you where you wouldn't be able to keep up? How much effect do those 6-8lbs matter.
Thanks,
CD
Thanks,
CD
Blast from the Past
Zero, Zip, none. It won't matter.
County sign fanatic
Bikes: Masi Gran Criterium (training), looking for the money for a racing bike
Originally Posted by CycleDeac
... How much effect do those 6-8lbs matter. CD
well i went from racing a 25lb bike to a 15 pounder. I can tell a difference on hills plus, i went to sprint for the finish yesterday and noticed a huge jump compaired to the old bike. There's a website showing time saved at a constant wattage with 5lbs less weight up a hill...it's significant. But for keeping up, 5 lbs doesn't make a difference if you're in the pack. Try losing weight (if you have some to lose).
Announcer
For a cat 5 in his first few months of racing?
Go race.
Talk to me in August.
Go race.
Blast from the Past
If you took the $$$ difference between the 22lb and 15lb bike and used that to travel and race more, in the end you will be a better racer. The experience you gain would more than offset the 2% disadvantage in wattage or whatever.
pan y agua
Quoted: 1461 Post(s)
Liked 740 Times
simple physics it does matter. At a level where everyone is gifted, and extremely fit, it would be the difference between winning and losing particularly on a course with much climbing. However in Cat 5 there is a wide variance in fitness, ability, and experience. You can definitely compete on a 23lb bike, and if you're stronger you can win. It won't be a deciding or limiting factor.
If you get out and do some races, and want to stay with it, you might look into getting a little bit lighter bike.
Guest
Posts: n/a
Quoted: Post(s)
Take a 175lb rider, 15 vs 20lb bike is 2.5%, even in cat 5, fitness, trainign and diet are much bigger variables.
Slow'n'Aero
As stated before, don't worry about it unless you are always 2nd place in the sprint, or are doing some stupidly long hill climb TT. Weight will only matter with acceleration which means hills, sprints, or crits, and if you are middle of the pack consistantly, you would move up from about 17th to 15th. Not worth it. Put some time into training and worry about weight after you have upgraded a category or two.
I remember hearing somewhere (and this could be wrong) but 20 pounds difference equals about 25 watts-So the difference of 6 pounds-8 pounds is not too much. Makes a difference over time, but not a massive one in most cases.
Here is the calculator someone was referring to-It's a difference but not huge.
https://www.kreuzotter.de/english/espeed.htm
No difference, assuming the combined weight of the bike and the rider are the same. And assuming they have the same wheels.
For example, Take two racers who can both produce the same output, the same no. of watts.
One weighs 150 and has a 15 pound bike, the other weighs 145 and has a 20 pound bike. In a time trial, they will cross the finish line at the same time.
Now, whats the difference in cost between a 20lbs bike and a 15 lbs bike? Prohibitive.
If you are absolutely at your lowest weight and you cannot lose another pound, then yes, in a hill time trial, 5 lbs might make a difference.
But in any group race, criterium or road race, there are so many other variables that will completely nullify any weight advantage. Having to bridge even a small gap for a while, getting caught in the middle of the pack during a few turns and having to slow more than the guys at the front, will completely negate any weight advantage.
Bikes: Giant OCR 2004, Specialized S-Works Tarmac SL 2007
I'm interested in this matter also because I'm sort of in the same situation. I think the quality of the wheelset is by far more important then the weight of the bike. How much of a difference in km/h is there between a wheelset of good quality vs a cheap one ? Can anyone refer to some personal experience?
Ink-Stained Wretch
Well I just raced on a set of MA-3 rims with 105 hubs and felt no difference compared to racing on Velomax Circuits or Dura Ace hubs with Open Pro rims, and that was with a small climb every lap for roughly 30 or so laps...but I'm still building up a set of light rims, either those or a keg...
Slow'n'Aero
a wheelset is the best improvement you can make to your bike. Deeper rims give aero advantage (particularly for the front wheel), whereas light periphery (read: rims) severely decrease rotational inertia. Here is a link to wheels and wattage requirements.
https://www.diablocyclists.com/aerowheels.htm
I think there is another out there, but I am not remembering the link...if I come across it, i will post it here.
Tiocfáidh ár Lá
I just got a set of light aero wheels. They weigh in at about 1500g. I think they feel faster on the jumps but I am having a hard time deciding if it's all in my head.
Aero wheels will give you the most improvement in speed compared to going with just a very light set of non aero wheels.
At first, I thought that the lighter the wheel, the better, because the whole thing in acceleration is overcomming inertia, and rotating objects develop much more inertia than non-rotating objects.
I learned on this site, however, that that is not the case. Take a look at https://www.biketechreview.com/archive/wheel_theory.htm.
You will see that aero wheels are over 10 times more efficient than the lightest non aero wheels.
But also notice we are not talking big numbers here. An aero wheel saves about 1.8 % of the watts put out for the same speed, while a non aero wheel saves about .14 %.
Clearly, these small gains will be more than overcome in a real world race where one mistake or misjudgement, i.e., going with a break that gets caught, being too far back in the pack for a few laps, will negate any wattage savings from trick parts.
Lotion/Basket/Hose
Bikes: 1992 Schwinn Paramount
But I'm still saving up for a choice road bike. Why? 'Cause I want to, but I maintain no illusions that by buying a new bike, I'll be able to place higher in the races that I enter. Essentially, buy a tricked-out bike if you have the means to afford it, but make sure that your legs are strong enough to deserve it. It seems awful to say, but you never want to be "that guy" who comes out to a race on a $6000 Fondriest and who gets dropped on the first hill.
Plus, I couldn't imagine the heartache if I entered a Cat. 5 race on a superbike and some squirrely rider plowed me over in a corner, scratching up both my bike and my skin.
Slow'n'Aero
Originally Posted by feltdude
I won my first Cat 5 race on a ~22 lb Trek 1000 with Sora. And hairy legs.
Throw the stick!!!!
I may be fat but I'm slow enough to make up for it.
more ape than man
this is why i will probably never go above a mid-priced ulterga equipped bike to race on. that's more than enough equipment.
plus, if i crash and total the bike, i'm not out thousands of dollars. i can actually afford a new one. imagine that
A heavier bike is often designed for something besides racing. Honestly I would worry more about those other things that might go with the weight. Lack of stiffness in the BB can mean a significant power loss, esp in a sprint. A more relaxed geometry means comfort, but lack of handling as far as a racer is concerned.
But as long as the gearing is right, it has drop bars and the tires are not wide go for it. Do not pass on the experience you are looking for because the bike might limit you. If it turns out the bike is a limiting factor having a race or two under your belt will at least help you decide if a more expensive/race specific bike is worth the cost.
Tiocfáidh ár Lá
Actually I did win my first cyclocross season, Men’s C a few years ago on a 25 pound touring bike. It actually was a nicely set up bike for cross. But on the road once I replaced it with a modern racing bike the difference was quite obvious and definitely not just in my head. I think though that the difference was more in the geometry then in the weights or probably realistically a combination of the two. My racing bike is about 20LBS.
More on aero wheels: Is the advantage in aerodynamics gained as the wheel rotates slicing through the air or is it gained as the wheels them selves move forward slicing through the air. IOW think of the wheel as not rotating but moving forward and cutting air. I guess maybe it's both, or I am not making any sense. I guess when you are talking about inertia weight savings of around 200 grams or so maybe won’t make a difference but I know when my cyclocross tires get caked up with heavy mud they are definitely harder to spin.
