Chain Stretch: How to Deal With It
Old 03-21-06 | 06:29 PM
mmaceda's Avatar
stress free.
Bikes: no-name fixed conversion, a pony
Recently, my chain has become so stretched that it is now at the very end of the dropout. I haven't thrown the chain yet, but I am worried about any problems that may come because of the current tension.
Should I remove a link so I can adjust the tension? Would this compromise the total integrity of the chain? Should I purchase a new chain?
I'm riding from San Diego to Los Angeles this weekend and I'm trying to get all my eggs inside of a basket or whatever.
mmaceda is offline
Reply
Old 03-21-06 | 06:35 PM
baxtefer's Avatar
Cornucopia of Awesomeness
you should have purchased a new chain several months ago.
now you probably have to replace the cog as well.
and maybe even a chainring.
baxtefer is offline
Reply
Old 03-21-06 | 06:41 PM
popluhv's Avatar
Doortrapper
Take a link out for now, it certaintly won't hurt.
popluhv is offline
Reply
Old 03-21-06 | 06:44 PM
20 Anniversary
Bikes: peugot fixed, Steelman cyclocross, Yeti Kokopelli
Yes. Buy a chain before you do that ride. It is long walk though Camp pendleton with a broken chain.
prodigal son is offline
Reply
Old 03-21-06 | 06:46 PM
brunning's Avatar
20 Anniversary
get a new chain. $12 well spent.
brunning is offline
Reply
Old 03-21-06 | 06:47 PM
it'll probably need a new chain, cog, and chainring, the sooner the better.
PhattTyre is offline
Reply
Old 03-21-06 | 06:50 PM
Bikes: 80's bianchi frame with IRO wheelset
why you need to buy a new cog and chainring as well?
Coquelicot is offline
Reply
Old 03-21-06 | 06:53 PM
baxtefer's Avatar
the "stretched" (worn) chain is longer and doesn't fit into the teeth correctly. So it wears on the teeth until it does.
i'll let sheldon explain it better.
https://www.sheldonbrown.com/chains.html#wear
baxtefer is offline
Reply
Old 03-21-06 | 06:55 PM
20 Anniversary
I know this can be true with geared bikes, but I don;t know if this applies to a fixed gear set up.
Reply
Old 03-21-06 | 07:12 PM
sers's Avatar
Bikes: Land Shark, Level Professional, Tsunami singlespeed, Giant Reign 1
it should especially matter on a fixed gear setup. since the chain is only ever on one ring and one sprocket, the noticible wear will be accellerated. not to mention that the wear happens during pedaling and when applying backpressure.
if the chain is stretched that badly, the op will most definately need to get a new chain, chainring and cog and install them together. a single new part will wear fast and mimic the old wear pattern. a new chain is going to be noisy and rough.
sers is offline
Reply
Old 03-21-06 | 07:43 PM
mmaceda's Avatar
stress free.
God. Dammnit. Yeah, it's my fault for not being vigilant about monitoring my drivetrain, but still. ****.
I know I'm not going to be able to afford a new cog and chainring, but I can afford the chain. If I go through with using a new chain on the old setup, what will I risk? I really want to ride this weekend and I kind of don't have a choice, as trains don't run on the weekend.
This brings another question to mind; how often do you replace your chains? Furthermore, how often do you replace your chainring and cog?
mmaceda is offline
Reply
Old 03-21-06 | 07:47 PM
20 Anniversary
amtrack runs every day.
Reply
Old 03-21-06 | 07:54 PM
mmaceda's Avatar
stress free.
Ah, I was looking at metrolink.
mmaceda is offline
Reply
Old 03-21-06 | 07:59 PM
Replace the chain first. If it runs over the ring and cog smoothly, you're fine. If it skips around and makes bad noises, replace them. Replace the chains when they stretch. You can check it with a special tool (most LBSs will do it quick for free in hopes that you buy a chain) or you can measure it. A new chain will have a pin every half inch on center. In 12 inches if you're not even landing on a pin, get a new chain. If you're using a singlespeed chain with no bushings they should last longer than your average multispeed chain. Replace the ring and cog when the new chain doesn't work smoothly on the old gears.
Reply
Old 03-21-06 | 08:00 PM
20 Anniversary
I am not sure how bikes get handled on Amtrak. I think a lot of people probably take the train as opposed to riding Freeway. last time I checked civilians are allowed on Camp Pendleton. Pre 9/11 there was a trail. I think they may have closed this pathway.
Reply
Old 03-21-06 | 08:12 PM
jamey's Avatar
am i missing something here? a new chain is so cheap how could you let it get to that point?
jamey is offline
Reply
Old 03-21-06 | 08:24 PM
mmaceda's Avatar
stress free.
You see, I am what you would call "new" at this thing. The only person helping me at the time was my dad who focuses in road cycling. Specifically speaking, he is a roadie; I guess chain wear is far less accelerated when riding with multiple gears and he failed to warn me of any such thing.
Also, I am an idiot. A lot.
mmaceda is offline
Reply
Old 03-21-06 | 08:33 PM
jim-bob's Avatar
hateful little monkey
20 Anniversary
For me it's not a money issue so much as a "I'll fix that later" kind of thing. Later takes a long time to come, sometimes.
jim-bob is offline
Reply
Yeah, I'd agree. "ALOT"
ChicagoxBoston is offline
Reply
Old 03-21-06 | 08:43 PM
fatbat's Avatar
spinspinspinspin
You can always flip the chainring over when you put on the new chain. However, if the teeth on the cog are noticeably worn, then best to just take out a link on the stretched chain, and start saving for a new drivetrain.
putting a new chain on worn teeth is worse than keeping the old chain.
fatbat is offline
Reply
Old 03-21-06 | 09:16 PM
likes avocadoes
Bikes: heh, like that info would fit here...
If it is indeed that worn, it's better (safer) to replace nothing than just a chain. If you replace just the chain, I guarantee you'll toss it on that ride, probably within 2 blocks. If you haven't tossed the chain yet with your current setup, remove a link, reposition your wheel, and replace everything as soon as you can.
r-dub is offline
Reply
Old 03-21-06 | 09:47 PM
mmaceda's Avatar
stress free.
This is the route I have taken. Many thanks to everyone that gave their input.
mmaceda is offline
Reply
Old 03-21-06 | 10:13 PM
12XU's Avatar
Dismount Run Remount etc.
Bikes: A couple customs and some beaters.
Dumbest thread of the week for sure. If you're experienced enough to know about "chain stretch" (which is actually just the pins developing grooves on either side of the chain), then you certainly should know that by the time it elongates to a noticeable point, it should've been replaced long ago!
12XU is offline
Reply
Old 03-21-06 | 10:59 PM
worker4youth's Avatar
Vanned.
20 Anniversary
Bikes: 2006 Motobecane Le Champ SL, 2006 Mercier Kilo TT, 2004 Gary Fisher Tassajara
I don't even use a ruler for chain wear. I use an 8.5x11 piece of paper. I measure the distance from one link to 11 away (using the 11in side). If I eyeball about 1/16th of an inch wear, I replace. A cheap 1/8th chain is only $10 around here.
worker4youth is offline
Reply
Old 03-22-06 | 12:01 AM
12XU's Avatar
Park makes a wonderful chain checker that measures for either .75 or 1 mm stretch, which if registered means "CHANGE THE CHAIN BEFORE YOU WRECK YRSELF."
12XU is offline
Reply
