homespun headset press idea
I really need my own headset press. I would love to have my own Park, VAR, or better yet the deluxe Bicycle Research one that combines reamer, facer and headset press all in one for a lovely price just shy of $300! Actually forking out the $$ for any of these is a problem since I always need the cash for something more critical, so I started thinking: why not use my wood lathe and turn some maple hardwood into some custom bushings and use some 1/2" (or better yet 5/8") threaded rod, and some other custom fabricated bits to rig up a smooth acting, powerful headset press of my own? How hard could it be. If I do produce it, I'll post up my creation here.
There are some threads on this. I started one awhile back that got lots of replies. I made my own headset press awhile back for $15 at a hardware store - long bolt, brass bushings (need to get correct size to fit 1" or 1.125" headset cups", large washers and a nut. You just tighten the nut and it forces the headset cups in like a knife into butter.
The trickier part is tooling to get the headset cups *out* of the frame in the first place.
"c" is not a unit that measures tire width
Second Timcuppery, but mine is even simpler, just two very big washers that fit over the ends of the cups and a long bolt and nut. Grease well, makes it easier to install and more importantly, remove.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Mad bike riding scientist
Originally Posted by genericbikedude
with a bit of care, a rag and a screwdriver and a hammer will do you just fine.
For the homemade press, the washers work but they can be difficult to keep the headset properly aligned. Spend a little cash and buy just the cups for a good press. It makes alignment much better and much easier.
On the other hand, the Park tools are sweeeet! I've been able to aquire the crown set tool, the cup remover and the headset press over the years and they are so much easier to use than the kluge jobs that I've made. The press, in particular, is like butta
Stuart Black
Dreamin' of Bemidji Down the Mississippi (in part)
Stuart Black
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Just how many times are you planning on putting in new cups? I give my team's wrench 10 bucks and it's done by the time I come back with a couple of coffees. Don't get me wrong, I'm the king of do-it-yourselfers, but some stuff just doesn't make sense due to the limited volume.
New Orleans
I always just tap them out with a punch or a home made drift,and press them in with a 2x4 and a hammer.My method is half azzed;it would be nice to have a real"press" of some sort.Hardwoods should make nice cup presser inners-heck,if you are a real cheapskate you could put them on either side of a big screw type pipe clamp,and just press them in.Maybe you could make a run of just the wooden "pressers" and sell them here.Luck,Charlie
Direct Hit Not Required
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
Originally Posted by concernicus
you can get headset presses for way cheaper than 3 hundy. doesnt nashbar make one?
https://www.performancebike.com/shop/...tegory_ID=4209
Originally Posted by The Fixer
Simple, but effective........I'll post this again...
(I say $99 because the $50 Pricepoint tool is backordered.)
3/4" bolt, nuts, and washers.
Stuart Black
Stuart Black
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Made one similar to the Fixer's for the cups about 40 years ago and it still works. For the fork race I made one with a pipe that had an ID just slightly larger than the fork OD...again a lot of years ago...still works on the 1" steerer tubs. I will need to make another when I go to a 1 1/8" steerer tube. Shouldn't be a problem.
