need help climbing
need help climbing
hey, i'm a relitivly strong junior rider. i've place well in most of my races. my only problem is my climbing. as soon as we hit the first hill i'm usually dropped if you have any advice for training or climbing it would be apprieciated.
thanks
thanks
Devourer of souls
Bikes: Felt f70
repeats, preten it dosent hurt. Im not a very good climber statistically, but i have a high tolerance for pain.
Montani Semper Liberi
Bikes: Specialized Hardrock
A/K/A "Alpha Male"
Bikes: 2005 Trek 1200 (Upgraded)
thanks
thanks
Oh, well I don't know then. Hitting the wall sucks in a big way!
Seriously, repeats, or hill intervals will make you faster eventually, it just takes a while.
Quoted: 842 Post(s)
Liked 469 Times
What is an ideal repeats session?
I have a hill I go up which is either 150 feet 12% climb which the ascent and decent are about a mile for the loop, or a 400 ft 12% to a 24% climb which is 1.5 miles. Not sure if this is an ideal repeat, and if it isn't let me know what is.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
1. Let A = the number of vertical feet you climb per week.
2. Let B = A + A.
3. B is your new weekly climbing goal.
That's it. Good climbers climb a lot.
DO panic!
Bikes: Scott Speedster, Giant Trance X
i mostly mountain bike, and thus spend a great deal of time on steep inclines. what i've found is that the ideal climbing position is to sit forward on the saddle, try to keep your center of gravity low, and spin a low gear. now this might be bc (coming from offroad) i'm accustomed to having to worry about the rear wheel losing grip, but it works for me. another trick, which is entirely mental and probably only works bc i have a short temper, is to get pissed off at the hill and hammer all the way up
...all of 'em?
Put yourslef upfront as much as you can, and pull these pedals. Do not downshift, instead go for the hardest gear. Watch your breath. In some cases you will go downhill right after climbing, make sure that pedaling is even tougher.
Used to be a climber..
Bikes: 2016 Ridley Fenix SL, 2020 Trek Emonda ALR (rim brake)
Quoted: 7 Post(s)
Climbing repeats....i.e., intervals. Find a nearby hill, and climb it....descend w/ a short break....2-3 minutes or so....and repeat. Do it until you throw up (not literally....but I can usually tell when I'm done when my sides start to hurt and I feel like I want to die).
This is my climbing repeat hill:
https://www.routeslip.com/map.php?map=3364
Gains a few hundred feet or so in just a tick under a mile. Fun times.
