9 speed rear derailleur on 7 speed cassette?
Old 08-28-06 | 08:59 PM
JNG330's Avatar
Bikes: Cannondale M300
I'm planning to buy a new shimano xt rear derailleur soon. My question is will a 8/9 speed rear derailleur works with my 7 speed cassette/shifters? I think i read somewhere that it will work but just want to be sure
Thanks
John
JNG330 is offline
Reply
Old 08-28-06 | 09:09 PM
Sheldon Brown's Avatar
Gone, but not forgotten
Sheldon Brown Memorial - Titanium
20 Anniversary
Bikes: See: https://sheldonbrown.org/bicycles
No problem. There's actually no such thing as a "9-speed" or "7-speed" derailer, that's just marketing hype. Derailers don't care how many gears there are.
See also: https://sheldonbrown.com/speeds
Sheldon "No Problemo" Brown
Sheldon Brown is offline
Reply
Old 08-28-06 | 09:12 PM
TallRider's Avatar
20 Anniversary
Which is to say, all Shimano rear deraillers designed for indexed shifting have the same cable-pull ratio. (Excepting pre-9-speed Dura-Ace, which probably isn't your worry.) So you could use a 105 rear derailler originally from a 6-speed gruppo, with 9-speed cassette and shifters. I've done this and it works fine. You could also go the other direction.
This isn't nearly so clean with Campagnolo, fyi.
"c" is not a unit that measures tire width
TallRider is offline
Reply
Old 08-28-06 | 09:32 PM
JNG330's Avatar
So that goes for SRAM ESP derailleur also? Just have to use it with SRAM ESP Shifter or can throw in shimano stx shifter?
JNG330 is offline
Reply
Old 08-28-06 | 10:17 PM
TallRider's Avatar
20 Anniversary
It goes for Shimano and Shimano-compatible rear deraillers and shifters. Some SRAM stuff is Shimano-compatible, some is not. I'm not sure about the ESP, but I think it's not the same cable-pull ratio as Shimano.
Reply
Old 08-29-06 | 03:43 AM
slider77's Avatar
Cletus Awreetus-Awrightus
20 Anniversary
Tim is correct, ESP does not use Shimano's 1:2 standard. From SRAM at:
https://www.sram.com/en/service/sram/...27a0c99bff6710
Q.What's the deal with different actuation ratios?
A.Well, SRAM's ESP design uses a 1:1 ratio. This means that for each millimeter of cable moved in the shifter, an equal millimeter will be moved in the derailleur. This allows a greater acceptance of off-road conditions (dirt, water, sand, etc.) and also gives SRAM a unique shifting technology. Conversely, Shimano uses a 1:2 ratio for it's shifting systems. This means that for every one millimeter of movement in the cable there will be two millimeters of corresponding movement in the rear derailleur. The ratios are not the same; therefore, you cannot use an ESP shifter and a Shimano derailleur, or vice versa.
slider77 is offline
Reply
Old 08-29-06 | 11:21 AM
DieselDan's Avatar
20 Anniversary
From: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
No problem. Heck, I one up you and use a 10 speed rear derailluer with a 7 speed cassette and RSX brifter.
DieselDan is offline
Reply
Old 08-29-06 | 03:56 PM
JNG330's Avatar
So im guessing the SRAM shifting method is more accurate and faster?? My bro just brought a SRAM attack shifter and he said its compatible with shimano derailleur. It is a awesome shifter, can be downshift a few times by pushing the trigger down harder. It is too bad for me tho cause i got a 7 speed bike and there isnt any good shifter out there for that
JNG330 is offline
Reply
Old 10-25-17 | 11:47 PM
I'm planning to buy a new shimano 9s shifter and chain 9s cogs, and my shimano tourney 7s rear derailleur still working. My question is it compatible to speed rear derailleur with my 7 speed? I think i read somewhere that it will work but just want to be sure.
Also have a problem with chains get slipping
Thanks
Allenos is offline
Reply
Old 10-26-17 | 02:46 AM
Thanks
A supposedly 7-speed derailer will work with a 9-speed shifter.
A new chain and cassette may cure the chain slip problem.
A 9-speed cassette won’t fit on a 7-speed freehub body.
dabac is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
