Will a 3/32" wide chainring work on a 1/8" wide chain and cog?
Old 02-23-07 | 10:40 PM
GeraldChan's Avatar
road curmudgeon, FG rider
Bikes: 1973 Nishiki Professional, 1990 Serotta Colorado II, 2002 Waterford Track
My new (to me) track bike came with two 3/32 cogs and chains. I think the 42T chainring (144mm bolt circle) is also 3/32". I just got my DA hi-flange 32 spoke 3X Mavic Reflex tubular wheelset built by my LBS and while I was there I bought a DA 16 teeth cog in a 1/8" width and a matching 1/8" Sram chain.
My question to some FG old timers is will the real track cog and chain work with the old chainring?
I ordered a 44T TA chainring in the 1/8" width online but would like to ride the bike soon, like tommorrow, hence my question. Thanks. Gerry
GeraldChan is offline
Reply
Old 02-23-07 | 10:42 PM
onetwentyeight's Avatar
blah
yes. the 1/8th will work on the 3/32nd stuff, but a 3/32nd chain will not work on 1/8th equipment.
onetwentyeight is offline
Reply
Old 02-23-07 | 10:43 PM
In Absentia's Avatar
Wolfman got nards!
Bikes: '06 Bianchi Volpe, '09 Mercier Kilo TT, '08 Jamis Exile 29er
Yes.
Reason is a scoundrel, stupidity is direct and honest. –Ivan Fyodorovich Karamazov
Man's mind, once stretched by a new idea, never regains its original dimensions. –Oliver Wendell Holmes
In Absentia is offline
Reply
Old 02-23-07 | 10:52 PM
GeraldChan's Avatar
Thanks guys! If it fits will it cause me any unusual wear issues? When the correct width 44T chainring arrives I will bolt it on as I really prefer the 44X16 ratio (74.4") for spinning down the hills around here and not having to touch my brakes. Yes I run BOTH front and rear ones; just in case. Gerry
Reply
Old 02-23-07 | 10:55 PM
blah
no i dont think you will notice any unusual wear on your gear, especially if you have a nice and straight chainline. i know a few track racers who use 3/32nd stuff with a 1/8th chain.
while i cant say this for a fact (i am just hypothesizing), i would imagine that any wear that would happen would be on the 3/32nd stuff you are getting rid of anyway, as the chain might have a little side to side movement that might wear it down a bit quicker than normal. i dont think this will be an issue at all though. anyone is welcome to correct me if I am wrong.
Reply
Old 02-24-07 | 04:17 AM
sers's Avatar
Bikes: Land Shark, Level Professional, Tsunami singlespeed, Giant Reign 1
i've been running a 1/8" chain on a 3/32" drivetrain for a while. no problems reported thus far. since the chain can move a bit more laterally i suppose the rollers could possibly wear against the valleys between the teeth with a bad chainline, but it hasn't been an issue for me.
sers is offline
Reply
Old 02-24-07 | 03:32 PM
GeraldChan's Avatar
Thanks for the replies guys. Gerry
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
