"Cantilever" threaded pads on ye old style sidepulls?
Code Warrior
Bikes: Schwinn MTB/Raleigh Marathon
Should be an easy question...
Can I put these:
on single pivot sidepull brakes?
Since the package says "for ALL Threaded stem brake systems" I assume that I could use these on sidepulls (since they are threaded) but I wanted to check here first.
Can I put these:
Elwood: It's 106 miles to Chicago, we got a full tank of gas, 1/2 a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it.
Jake: Hit it.
Code Warrior
Anyone?
Jake: Hit it.
Jake: Hit it.
If they will fit between the rim and forks, then maybe? A lot of times the shoes end up hitting the forks on the back end part. The threads look like they would work, just the clearance could stop you
,,,,,BD
Love the signature, you'll probably recognize mine, hehe.
,,,,,BDLove the signature, you'll probably recognize mine, hehe.
So many bikes, so little dime.
Code Warrior
Jake: Hit it.
Jake: Hit it.
You may have clearance problems with those pads. Take a look at the thinline or the mountain pads. More info on Sheldon's site.
I've used the kool stop thinline v-brake shoes/pads on my old road bike centerpulls, and I'm currently using cartridge-type v-brake shoes with kool stop cartridge refill pads (for v-brakes) on them. If you have clearance problems, as others have said, this thinner pad might work better. But if there's no clearance problem, I don't see why the Eagle 2's wouldn't work-
Code Warrior
Ok, to be on the safe side...I'll get the thinline/mtb pads. The LBS near my work stocks them. I'll report back this evening as to the (hopefully) increase in stopping power.
Jake: Hit it.
Jake: Hit it.
The clearance problem is in the front, not the rear. You can use the thinline pads in the front and the Eagle 2's in the rear if you want.
I've bought a couple of sets of Kool Stop Continentals from an eBay seller for $7.95 for one bike's worth. There is no clearance problem, but you have to set your toe-in the old fashioned way.
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
I also added cantilever pads like those in your photo to my old ten speed and they work just fine. I did omit some of the dished washers that allow toe-in adjustment because the threaded studs were too short to accept the nut, otherwise.
Code Warrior
OK...I'm pleased to announce the mountain thinline combo pads work. And I'm even more pleased that the stopping power is par with what I was used to with cantis on my MTB. Less importantly...they look soooo good!
Jake: Hit it.
Jake: Hit it.
Canti performance with a sidepull? Sign me up! I have three old school MTB's right now, and even with dried out looking pads they stop NOW, hehe. Having that performance on a road bike would be great!,,,,BD
Code Warrior
Jake: Hit it.
Jake: Hit it.
All my roadies lumped together cost less than half a contemporary bike
Highest priced one was
about $30. I'm not counting tires/tubes/cables and all the parts needed to get them back up
to par, though. As far as braking performance lately, I got some grey Koolstop Continentals from
ebay, and they're amazing on my Super Sport. How hard you squeeze the lever, is how fast you stop.
They really impressed me with braking feel, especially on such a relatively "crude" old schwinn. I want to try the cartridge type pads on a bike to see if they feel the same.,,,,BD
Highest priced one wasabout $30. I'm not counting tires/tubes/cables and all the parts needed to get them back up
If you ever decide to upgrade the brakes, get some dual pivot sidepulls. I'm currently building an old Trek frame as my main rider, and because I'm already way over budget on it, I'll also be setting it up with extant Dia-Compe 500s with the Kool Stop MTB thinlines. However, I'm most accustomed to dual pivots on an old Cannondale, so I'm expecting a decrease in performance.
The "problem" with the dual pivots is that they are hard to find with standard nutted mounts (though Harris Cyclery has them for $40 a pop). So, you would either have to drill wider holes (which I am hesitant to do on my Trek frame) or try the trick Sheldon describes to use recessed mount calipers in standard mount holes.
