Octalink vs. Isis Drive
Mad For Marinoni !!!
What 's the difference between these two BB's and what are the benefits of each if any over the other? I cannot seem to find much info on either anywhere.
Thanks
Thanks
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I'm not sure what the exact differences are between ISIS and Octalink but the differences between ISIS and Shimano splined XT/LX and Shimano splined XTR (note that XT/LX and XTR are also different from each other I believe... XT/LX might be Octalink) is that ISIS uses 10 splines that are set deeper along the spindle than Shimano's 8-spline design which don't run as far along the spindle. There are also differences in the width and curvature-depth (ISIS grooves are deeper but narrower) of the splines too as well as the thickness of the spindle. I'm not certain if there's a diameter difference however it's more than likely there is.
The ISIS Drive webpage has all the specs of course but I don't know of a webpage that details Shimano's spline specs of which there are many versions.
Sheldon Brown's webpage about BB sizes details more important fitting information such as chainline positions and spindle-lengths.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
