what's the right bike for the job?
Old 07-18-07 | 07:22 AM
atomship47's Avatar
the actual el guapo
Bikes: '06 trek 7300, '05 db wildwood, '07 felt z35
...trying to think of an alternative title to another "which bike should i buy" thread.
i'm a roadie convert (from comfort/hybrid mup rides). here is my intended use....
i have a getaway place near galena, il. about 50% of my rides there are on less-than-friendly gravel roads. riding my roadie is out. i just use my trek 7300 to ride there. and i'm slowly converting this bike to be more road-friendly (28mm tires, rigid seat post, etc.).
i'd like a bike that i can bring with me to places where i can go on rides that are on a combination of paved roads and really rough gravel roads. before i went on my trip out west, i was thinking a 'cross bike would be the way to go. however, there was a 1-mile stretch of gravel road in teton n.p. that bounced me around on my roadie so much that it makes me think i need something with a suspension.
what are your thoughts?
-should i just use my 7300 but convert it to a more efficient road bike? the downside to this is i don't like the riding position. i think i'll need to swap out my stem/handlebars. also, i'm heavy and my front suspension is too soft...even at the stiffest pre-load setting.
-would a 'cross bike be a good bet or would rough gravel roads bounce me around just as much? i guess the only major benefit would be a sturdier wheelset.
-should i look at mtn bikes? i'm not going to be rock-hopping or stump jumping. i'm thinking a pure mtn bike may not be for me since i'm looking for a bike that is road-friendly.
thoughts, comments, suggestions?
atomship47 is offline
Reply
Old 07-18-07 | 08:01 AM
markhr's Avatar
POWERCRANK addict
The cheapest option is just convert your existing bike but that never stopped anyone from buying a new bike for the sake of it - and don't let it stop you
cyclocross with disc brakes - I am biased
try voodoo, redline, salsa, kona, opus, cannondale, mountaincycle, lemond, norco, etc
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
markhr is offline
Reply
Old 07-18-07 | 08:53 AM
Try new smooth tires. If you are not going off road you probably do not need a suspension fork.
Folding bikes work for travel.
xooter.com swift, Bike Friday or Dahon Mu XL?
geo8rge is offline
Reply
Old 07-18-07 | 09:29 AM
blickblocks's Avatar
Get a CX bike. They rock.
https://blicksbags.com/
blickblocks is offline
Reply
Old 07-18-07 | 10:00 AM
After reading many 'what bike should I get' threads while trying to pick a bike for myself, I found the general consensus to be: get a Surly Cross-Check . Either buy it complete or build it to your specifications. Everyone who has it loves it and it is good for a little bit of everything.
FWIW I just upgraded my current bike. That proved to be the cheapest way to get what I needed.
dynamitemonkey is offline
Reply
Old 07-18-07 | 10:56 AM
atomship47's Avatar
the actual el guapo
i've got 28mm bontrager race lite's on the bike now.
when i was in teton n.p., my rides were mostly paved with some nasty gravel roads going up to trail heads. seemed like just the terrain for a cross bike. when i went to the lbs's in the area and asked about cx bikes, they said VERY few people ever buy them out there. they just get the ocassional special order.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
