Touring gears with Campagnolo
Old 07-23-07 | 06:28 AM
MrPolak's Avatar
Just ride it.
Folks, for those interested in a Campy touring triple crank, I have completed installation of IRD triple-lizer (tripleizer) on my Campagnolo Centaur compact crank (110BCD). The crank comes with 50/34 gearing, which is fine for all but the nastiest of ascents. If you are interested here are a list of things to get:
  1. IRD Triple-lizer chaing ring
  2. Campagnolo 5mm chainring spacers (available from Harris Cyclery)
  3. Campagnolo chainring bolts
  4. 74 BCD small ring
  5. Triple front Dérailleur, such as Campagnolo Record.
  6. Triple bottom bracket, such as Campagnolo Centaur 68x115 sealed BB.
Sample image:
The non-Campy chainrings work wonderfully with my 10-speed drivetrain. The rear 11-25 cassette and 24t small ring give me a nice near 1:1 ratio. With my FSA 46t big chainring, making my triple a 46-36-24, I can access all the gears despite using a short-cage rear dérailleur.
MrPolak is offline
Reply
Old 05-26-08 | 06:42 PM
maddyfish's Avatar
Bikes: KHS steel SS
Interesting conversion, with Nashbar giving away Centaur compacts (I've got one on the way) should be useful.
Is the 115 BB the standard for Campy triples? My centaur standard double has a 111.
maddyfish is offline
Reply
Old 05-26-08 | 10:08 PM
Deanster04's Avatar
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Sample image:
Very nice setup. I found a 30-40-50 racing triple and put a 26t T\A Specialities on the 74 BCD with a 13-29 cassette. Works quite well. I have a more radical setup using a Centaur hub with a Campy FHB with the Shimano spline pattern. The wheel with a 11-34 9 spd cassette works extraordinarly well with the 10 spd shifters. This is for the more radical mountain touring. I like your setup and will have to look for a compact crank.
Deanster04 is offline
Reply
Old 05-27-08 | 05:58 AM
east coast tourer
Bikes: too many to list
i am getting ready fro my northern tier tour with a campy 10 speed setup. i am going with an FSA compact 50-34 and then a miche 10 speed cassette modified to be 12-29 in the back. i consider myself a strong climber, wanted to avoid a triple since i had the compact already, and wanted to keep the 12 tooth low end so i can still cruise at a fast clip in the midwest. i'll let you know how the 12-29 works out.
roseyscot is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
