FYI - good tubular glue removal stuff
For those of you who prefer to remove the old tubular glue from your rim before installing a new tire. I have used Citristip on two seperate occasions and it works real well. I paint it on, wait about 12 hours and then use a tire lever to scrape the mostly dissolved glue away. You may need to do this twice if you have thick old glue on a rim.
You can use Citristrip indoors and it isn't nasty to the environment or your brain cells. It seems to work much better than acetone or goof off.
C
C
Bikes: o5 Specilized roubaix Comp, 06 Tequilo
Before you start swimming in this "non-nasty" product, here is the link to the MSDS informatio.https://www.wmbarr.com/msds/CCG73804.pdf
Bikes: Cervelo R3
Goof Off works great. I picked up a tin can of it at Home Depot for like $4. Best used outdoors tho, because the chemicals listed on the back have a lot of *-zene names... not good. Goof Off worked much better than acetone on old Vittoria Mastik glue
Bikes: Derosa SuperKing Dura ace, DA wheels, Cannondale Topstone AL, Grx, FFWD 350. Specialized Tarmac SL7 UDi2, Sworks Crux, GRX, Ridley X-night sl, GRX, Specialised Epic Comp Carbon.
I'm assuming Goo-off, acetone and citirstrip are safe to use on carbon rims
