The perfect classic bend handlebar...
Old 09-21-07 | 08:15 PM
...is the Easton EC90 Equipe Pro. 75mm reach, 130mm drop. Most importantly, the bar doesn't have that horrible slanted angle where the levers clamp on, so you get a nice flat platform for your hands. "Belgian style" bars have this quality, but they always have a huge drop (~145mm).
I have looked EVERYWHERE for a bar that uses these measurements and bend. No luck, except for an old Icon bar I found in the back of a LBS. Probably came off a Trek sometime in the late 90's.
The next closes thing I've found is the ITM Visia, but it's a little longer, a little deeper, and the bend is not as "round" at the clamp area.
Why not just buy the Easton, you ask? Well, for one, it's carbon (and I don't like carbon bars), and two, it's horribly expensive (and I don't like that either).
Anyone know of a bar (preferably aluminum) that mimics this one?
justin_fraga is offline
Reply
Old 09-21-07 | 11:34 PM
55/Rad's Avatar
Former Hoarder
20 Anniversary
Bikes: Steve Rex, Seven Axiom, Felt Z1, Dave Moulton Fuso
Check out the Nitto Noodle series - there is one on the chrome bike in my sig.
55/Rad is offline
Reply
Old 09-21-07 | 11:35 PM
grahny's Avatar
hobo
+6.94827 billion... Noodles are the best. I use them on 2 of my bikes and love them. Look at the R3 in my sig. There's a close up of the bend.
grahny is offline
Reply
Old 09-22-07 | 04:54 AM
damocles1's Avatar
The mods changed this...
Deda Newton
...comes in shallow(Italian) or deep(Belgian)
damocles1 is offline
Reply
Old 09-22-07 | 10:56 AM
Thanks for the help so far. Couple of comments (and now I'm going to sound pretty anal):
- The Noodle is essentially a "Belgian bend"; nice constant radius and a flat platform on top, but at 95mm throw and 140mm drop, it's just bigger than I'd like. It's close to the same bar as the Deda Newton Deep or the FSA Energy T.
- The Newton Shallow is an "Italian bend" or "Maiz bend" bar; much shorter throw and only 135mm drop, *but* the platform is slanted and you don't get an even transition from the shifter body to the top of the bar like you do with the Noodle.
So I'm really looking for a bar that has the shape of the Noodle, and the extension & drop of the Newton Shallow. Only bar I know of that has this the the Easton Equipe Pro-- no aluminum version. Again, thanks for any suggestions people have.
Reply
Old 09-22-07 | 10:57 AM
...and by the way, that's some of the best bike porn I've ever seen.
Reply
Old 09-22-07 | 11:58 AM
55/Rad's Avatar
Former Hoarder
20 Anniversary
Thanks! Check out the rest of the Nitto line - some good options there.
55/Rad is offline
Reply
Old 09-22-07 | 12:37 PM
marqueemoon's Avatar
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Nitto 115! The only downside is the 25.4mm clamp.
marqueemoon is offline
Reply
Old 09-22-07 | 01:11 PM
grahny's Avatar
hobo
I use a problem solvers shim and it's been fine so far (w/ thomson x2 stem)
grahny is offline
Reply
Old 09-22-07 | 06:48 PM
FrankBattle's Avatar
SilentRider
Bikes: Trek Madone SLR 7, Giant TCR Advanced Pro, Trek Domane SLR, Trek Emonda SLR Project One (x2), custom Bingham Built Titanium road bike
Thanks for this thread. I now know what that new custom steel frame is getting for a bar (Nitto noodle), seat (Sella An-Atomica) & seat post (Nitto Crystal Fellow); my god will it set off that white frame.
Grahny, that tape on the Cervelo .. leather? Nice setup!
FrankBattle is offline
Reply
Old 09-22-07 | 11:25 PM
I use a NOS Salsa 25.4 stem
Reply
Old 09-24-07 | 02:30 PM
The 115 has 140mm drop and 100mm throw; basically a Belgian bend.
Looking for something ~ 130mm x 80mm (like Italian), flat clamp platform (like Belgian). Seems picky, but even 5mm makes a noticable difference.
I finally just broke down and ordered an Easton Equipe Pro. I don't want a carbon bar on any bike of mine, so I'll keep looking...
Reply
Old 09-24-07 | 03:58 PM
caloso's Avatar
20 Anniversary
No love for the Ritchey WCS Classic?
caloso is offline
Reply
Old 09-24-07 | 04:11 PM
20 Anniversary
From: Latitude 42○13'44" Longitude 71○41'42" Elevation 223 ft.
Bikes: 2006 Merlin CR Works w/DA 10
FWIW, I have the Easton EC90 Equipe Pro and love it.
Markedoc is offline
Reply
Old 09-24-07 | 04:17 PM
CastIron's Avatar
Sensible shoes.
Bikes: A few.
Classic bend by Cinelli.
Mike
Originally Posted by cedricbosch
It looks silly when you have quotes from other forum members in your signature. Nobody on this forum is that funny.
Why am I in your signature.
CastIron is offline
Reply
Old 09-25-07 | 03:51 PM
Not much. I had a cache of these bars from last year's team pro deal, and the platform at the clamp area is so sloped you can't possibly get the shifter to line up flush with the bar without tilting the bar waaaay back. At that point it has a virtual extension of about 110mm and the drops are too steep for me.
Reply
Old 09-25-07 | 03:58 PM
caloso's Avatar
20 Anniversary
Shimano shifters? I ask because I love them on my Campy equipped bike and then got a set for my Shimano bike. It just wasn't the same and I couldn't put my finger on it. I think you've nailed it. I may be looking at a set of Nitto Soba Bars for the DA bike now.
caloso is offline
Reply
Old 09-25-07 | 05:34 PM
No, Campy, but it's even more pronounced on Shimano because the brake hood platform is a bit shorter. Some people can comfortably fit their palm on a Campy hood, but my hands are on the larger side and they sit on the bar as well.
Either way, the Ritcheys have one of the more pronounced slopes on their clamp area and usually need to be tilted back to get a flat platform. This will always extend the virtual throw of the bar (no matter what the spec says about "82mm" or whatever). The Nitto has a pretty flat platform, but still has a lot of extension anyway. In the realm of classic bend handlebars, only the Easton (as far as I know) has a short throw, shallow drop *and* a flat platform.
Reply
Old 09-25-07 | 06:26 PM
Bikes: Canyon Ultimate CF, Moto LeChamp SL, Raleigh Rush Hour, Crescent MTB, Swedish Army issue bike
if you could post a pic when you get them on the bar, that'd be great. i'm looking for exactly the type of bar you're talking about, and it'd be excellent to get a straight on profile of them with the shifters on.
even if they are carbon, these might turn out to be perfect in shape, if a bit radical:
pidda is offline
Reply
Old 09-25-07 | 09:43 PM
cuda2k's Avatar
Unique Vintage Steel
Titanium Club Membership
Sheldon Brown Memorial - Titanium
20 Anniversary
Bikes: Kirk Frameworks JKS-C, Serotta Nova, Gazelle AB-Frame, Fuji Team Issue, Surly Straggler
Much love for the classic Cinelli 66 Campione del Mondo bar. I searched high and low till I found one with double grooves to work perfectly with modern Campy Ergo on my Serotta.
cuda2k is offline
Reply
Old 09-26-07 | 11:11 AM
20 Anniversary
Anyone tried the Modolo Curvissima, not a classic curve but worth a look if you like shallower drops.
https://www.la-vuelta.com/veloidealPA...RES_MODOLO.htm
MichaelW is offline
Reply
Old 09-26-07 | 11:14 AM
cuda2k's Avatar
20 Anniversary
I found most Modolo bars to be very flexy. Those that I owned (a couple models) and those I've heard about and seen as well.
cuda2k is offline
Reply
Old 09-26-07 | 11:17 AM
bac's Avatar
bac
20 Anniversary
Bikes: Too many to list!
I'm still looking. Rad, you are surely violating some sort of law by posting such beauty.
Damn!
... Brad
bac is offline
Reply
Old 09-26-07 | 11:41 AM
auk
Coasting makes you grumpy
20 Anniversary
Bikes: Specialized Stumpjumper M2Comp; Habanero Ti-Team; Slingshot Road; 1962 converted Raliegh fixer aka: The Beast
Check out the FSA RD200 classic bend. Very nice.
auk is offline
Reply
Old 09-26-07 | 11:44 AM
Bikes: Motobecane fixed conversion, Faggin fixed conversion, '86 Raleigh Grand Prix
64s for me. Hard to beat.
littledjahn is offline
Reply
