Are Your Cranks Too Long?
Really Old Senior Member
I decided to "service" my BB's on my 2 bikes, since my "main ride" was getting "gritty" feeling.
It turned out both spindles were the same size and I thought- Why not try the 170MM arms from my "back up" bike on my good bike and put the 175's on the back up. (I didn't have a crank puller before)
The difference is AMAZING!
I'm running the SAME cogs in back, but using the 38T ring instead of my former 46. That's about 21% higher cadence to do the same speed! I think I'm also cruising about 0.5 MPH faster, but it's hard to tell for sure with the wind/cold etc. (edit: after today-did a 9 mile ride- I'm pretty confident I'm doing at LEAST 0.5 MPH faster- maybe closer to 1 MPH!!!!)
Before, I had to keep focused to try to keep my cadence at 65 or it would drop right down to 60 or less. My feet would come off the pedals at around 68 RPM. Now when "madly spinning", my feet still feel "stuck" to the pedals. My cadence is still relatively slow, but at least it's greatly improved. STAMINA has improved as much!
I went on a 15+ mile ride last Sat. I wouldn't have attempted 10 miles on one trip before! (10-12 miles spread over 4-5 separate "errands" per day, with rest breaks in between, was my limit) And, NO PAIN/stiffness!
My conclusion is-
With the longer cranks, I was exceeding the range of motion in my old arthritic/bad knees and was wasting energy on the "down stroke" by having to help "lift" the other leg "over the top".
I'll be curious if another 5MM shorter helps out much more. I certainly don't expect another 20%, but even 5% more would be great. (I ordered a cheap set of 165MM cranks)
My old 175 MM cranks were the stock Specialized from an 86 rock Hopper (26-36-46)
The "new" ones are the cheapest looking Bio Pace that I've ever seen. One piece arm with integrated, riveted rings (28-38-48) off my 91? TREK 820. However, as they say, it works. I don't know if the Bio Pace part helps???
BTW, I'm kind of a "short legged" 6 footer. Maybe a 31" inseam on dress pants? 30" on my Levi's.
My conclusion is-
His Brain is Gone!
Bikes: RANS Stratus, Bridgestone CB-1, Trek 7600, Sun EZ-Rider AX, Fuji Absolute 1.0, Cayne Rambler 3
I have 170mm on both of my primary bikes. 175's are too long for me, on every stroke it feels like I'm trying to step up over an obstacle.
I'd love to try 165's, sure wish it wasn't so difficult to try different lengths.
"Too often I would hear men boast of the miles covered that day, rarely of what they had seen." Louis L'Amour
There are two types of road bikers: bikers who are faster than me, and me. Bruce Cameron - Denver Post
Quoted: 8 Post(s)
Liked 10 Times
My 53cm LeMond came with 175mm crank arms, all my other bikes have 170mm, which is what I'm used to. I rode it for over a year trying to get comfortable with the extra 5mm but it never felt quite right. I picked up a good used exact replacement in 170mm on eBay and switched 'em out. Big difference. I'm still kicking myself for not doing it sooner.
Same here...
I'm 5'10", with pretty long legs for my height, and 175's drove me nuts. I could never get the saddle the right height, and was never able to really spin. 170's rock!
Quoted: 12197 Post(s)
Liked 1,497 Times
I have short legs and love my 167.5 cranks. They are a bit hard to find.
Boomer
Bikes: Diamondback Clarity II frame homebuilt.
Quoted: 16098 Post(s)
Liked 1,457 Times
I stayed with 175's for years because it was the "thing to do" for my size bike. Year before last I went to 170 because of an availability issue and with the exception of "bogged down and mashing" hill climbs my performance and comfort improved.
It is expensive to outfit you bike this way (especially if you don't like it) but well worth the inevitable test rides.
Infidel
Bikes: 1976 step thru Schwin 10 speed with fenders, home made20" long bike, '73 Puegeot P-15, several beaters, kids bikes and projects
I had been having trouble with my knees and occasionally with my right hip for the last two years. It had gotten to the point that I was avoiding riding. After reading a post in the forums (recumbent I think) about using shorter cranks and spinning more I decided to give it a try. I went from 170mm to 140mm because that is what I had. No more knee or hip pain. Not even so much as uncomfortable. I'm never going back. I may not be fast but at least I can hang in there.
Violin guitar mandolin
Bikes: Wilier Thor, Fuji Professional, LeMond Wayzata
I went from 175 to 170, spinning too high, no power. So I'm at 172.5, which works perfect for me!
Bikes: Heron Wayfarer/ 2004 Giant Cypress SX
I'm 6:1 with a 32" inseam and Went from 170 to 175's on my Touring/Commute bike. Almost ruined my knee's. Went back to 170's. Less knee pain.
Richard
Richard
Time for a change.
Liked 5 Times
I ride a varierty of Bikes with cranks from 165 to 175. For some reason I do not not find that 3/8" affects the feel of the bikes in any way.
Spike Milligan
Spike Milligan
Quoted: 8 Post(s)
Liked 10 Times
Denver -
Most cranks are stamped with length in mm on the inside of crank arm. If not, measure from center of pedal axle to center of bottom bracket spindle .
Senior Member ??
Bikes: 2007 Trek Madone 5.0 WSD - 2007 Trek 4300 WSD - 2008 Trek 520 - 2014 Catrike Trail
I had the opposite problem with the 170 cranks that came on the Madone. I rode it 500 miles and couldn't get used to the cranks. I had 175 cranks installed and love them. I guess it's all related to what we're accustomed to riding.
Enjoy the little things in life, for one day you may look back and realize they were the big things.
-- Antonio Smith
-- Antonio Smith
I stick to mostly flat pavement and ride a bike because I don't have a car. I pretty much want the fastest speed that I can comfortably maintain. I'm NOT fast, so going from 10 MPH to 11 MPH is a 10% increase! The shorter cranks HAVE helped my speed slightly, but they have REALLY helped my endurance. At this early time, it appears I can ride about 60-70% further with the same level of fatigue. On my shorter errands (1-2 miles), I can "crank it up" an extra 2-3 MPH. That doesn't help much when you speed up to a stop light, but maybe I'll catch a few when they are still green Actually, there is one "timed" light I can now catch with a little "burst"! If only it was on my "usual" route
I'm running three length cranks. 165's on my touring bike. 172.5s on the full carbon road bike, and 175s on my 853 steel and carbon raod bike. the 175s are by far the easiest for me to ride. I notice no difference in ability to spin all three in the 90 to 95 rpm range. I like the 175s the best when standing while climbing. Personally, I find the difference not worth worrying about. Meaning that if there were a bike with any of the three length crankarms on it, and I liked the bike, I'd be comfortable with purchasing it. If given a choice, I'd go with the 175s.
Quoted: 1858 Post(s)
Liked 664 Times
Road Fan
Quoted: 21 Post(s)
Man, you guys are confusing me. I have been all set to replace by triple with a compact double with 175 cranks, but now I'm not so sure. I'm 6'0" with a 35" inseam, and I've always understood that longer cranks are appropriate for longer legs. Maybe I should think about something shorter.
Liked 1,497 Times
I don't know what you have, but you could keep an eye on ebay for some used cranks in a size you want to try. Nashbar often has great prices on leftover cranks.
Liked 12 Times
Wouldn't changing the cranks to a smaller crank effectively change your gearing ratios, considering the crank to be a lever, and the pivot point a fulcrum??
I see no need to change mine.
Senior Member ??
Beverly, aren't you more of a "casual" rider where you like to "enjoy the view" and speed ISN'T the issue? I can see where with trail type riding (slower speeds), the longer cranks might work better for you. The longer arms give a little better "torque" for accelerating from a stop or "crawl".
I'm not a tall person but I have longer legs than most women my height (5' 3"). My sister and I are the same height....she has a 29" inseam and I have 31" inseam. I still think the biggest factor was I was used to 175 cranks. Every bike I've ever owned had them. I also prefer to push the gears instead of spin.
-- Antonio Smith
-- Antonio Smith
Yes, I believe the effect is that with shorter cranks you always are riding effectively in a lower gear. You can compensate of course by upshifting, but you always have a smaller circle to pedal. If you keep your seat-to-bottom-pedal range the same, your knee angle at the top is eased up.
The key thing with crank length is that a .23" difference is doubled to .46" when you look at the full circle.
What is confusing is that usually the longer lever = more leverage = better.
I've been riding 175's and having knee trouble, which nothing seems to fix. I'm probably going to soon try 170. In fact I recently had a rental bike with 165's and that worked out better for me than my current bike.
My beef with crank length is that so few manufacturers list the info on websites. (Kudos to Jamis as one of the only exceptions).
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,483 Times
172.5 on the single, 175 on the tandem. I do not seem to notice any difference.
