First wheel build -- problem?
Just finished my first wheel build--haven't ridden it yet, but it's true and evenly tensioned. I was looking at it again today, and became concerned by the seemingly sharp angle between the spoke and the nipple. I was conscious to put it in the appropriately-sided hole when lacing, but certainly I could have bungled this. Any way to tell? I can't, just based on looking at the hub side of the rim. Pics are the area of my concern.
Never saw that before. Did it happen to all the spokes, just the spokes on one side, or just one spoke?
Perhaps the nipples are just not seating well in the rim. Try tensioning the wheel to see if that changes anything.
Over the hill
Bikes: Pinarello Nytro, Momentum Transend
Agreeing with the above comment, have you brought the spokes up to tension yet? I've seen that before, but only before the spokes are brought up to tension. The tension straightens it out a bit.
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
Did you pre-stress the spokes?
You need to seat and stress relieve those spokes bad
https://www.sheldonbrown.com/wheelbuild.html
scroll down to seat and stress relieving.
I'm not sure what *pre* stressing is, but I did stress relieve as best I know. That is, grabbing parallel spoke pairs and giving a moderate squeeze at midspoke. It's well tensioned also. It looks like this to different degrees all the way around.
Here's a thought: because I couldn't tell which side the hole was drilled to from the hub side, I used the more obvious tire side as a guide. I assumed a hole on the left on this side meant the spoke was to go to the left flange, but it is a double-walled rim, and I assumed suppose it could be drilled at an angle?? Hole on the left actually angles to the right flange??
Edit: Rim is a Velocity Aero, in case that matters. Not what I would have chosen after thinking about it some more, but what the LBS had in stock. I put another wheel together last night on a Mavic rim, without this problem.
This actually looks OK to me, is the thing. If you stress relieved the spokes (same thing as pre-stressing), then it should be cool.
I don't think you want to use "moderate" pressure to stress-relieve, though. Squeeze hard. You're actually deforming the steel.
You can try it by disassembling one spoke and just laying it in position against the other flange while threaded on to the nipple and see how things line up then.
Or you just ignore the whole thing and say that you always intended to lace it in lateral cross
Bikes: 1982 Fuji Team, 1979 Raleigh Team Record, 1984 Raleigh Team USA, Japanese Raleigh Super Course, 2000 LeMond Buenos Aires, 90's Schwinn High Plains, 1978? Austro Daimler Inter 10
I"ve seen this happen to before. to me. at the start of tightening the first nipple, I noticed the angle. I had laced all the left spokes in the right holes, and vice versa. I just wasn't paying attention. If you can't tell if the hole is left or right, you can put a spoke through the hold and see which irection it points.
Just in case with some velocity rims u cant tell if a spoke is at the left or right side of the rim
Thanks.
I think you nailed it right there, a hole on the left side as seen from the tire side would be for a spoke going to the right flange.
So a spoke going center-to-right would have a tire side hole to the left ASO.
If you have to redo it, stick the spokes together at the cross with a bit of tape, undo the rim, shift one notch and hook it all up again. For me that's faster that total disassembly.
Mind where the valve hole ends up.
I've put plenty of miles into two wheels deliberately built lateral cross, and they're still doing just fine. YMMV though. Potential risks: increased load on nipple seat in rim, more wind-up, harder to tension properly, spoke angle at nipple might act as spring with hard-to-predict results.
IMO:
All other things being equal(average weight rider, average riding style, average riding conditions, a decent spoke count..) a wheel is such a excessively strong part that they just about "never" fail catastrophically while JRA. So if I see a lot of those averages ahead of me I wouldn't hesitate at all about reusing the current parts.
Most likely "cause of destruction" for my bikes are violent random events anyhow, and I don't think a few percent of lost strength in the build phase would mean a thing for those.
Thanks everyone for your input. Dabac, this will have to be an experiment in the structural soundness of unintentional lateral cross. I unlaced one spoke, with great difficulty. There is spoke prep on this wheel, and I nearly rounded out the nipple so much I couldn't get the spoke off. Once off, I tried threading back onto the spoke and laying it across the opposite flange. I don't know--I'm not sure if I could see a difference or not. Regardless, it's apples to oranges unless it's tensioned, I guess.
All things considered, I think my risk of causing some part to fail will be greatly increased if I try to fix it at this point. And, if my alternative is to use new parts (spokes, at least), I might as well just ride it until something comical happens and then try again, the right way. Maybe I'll ride with a camera for a while, just in case the whole wheel implodes when I'm going off a curb or something like that.
That's what I'd do.
If I were to guess I'd say you might get a shorter life out of this wheel, but no sudden catastrophic failures.
I've put together several wheels using techniques some other guys on this forum(you might want to search for a thread about un-tacoing a wheel..) considers to be absolute no-nos. But with a decent build and a lot of averages sudden and disastrous failures just aren't happening.
This is a little confusing to me are you saying tire side as in you are looking down at the wheel from above? I always go by sheldon's synopsis that "the spoke holes do not run down the middle of the rim, but are offset alternately from side to side. The holes on the left side of the rim are for spokes that run to the left flange of the hub." And the holes on the right side of the rim run to the right side of the flange.
Sheldon is talking about an average/generic type of rim with a (more or less) concave side facing the hub. Seen from the hub you then get the best nipple/rim alignment if a spoke from the left flange goes to to a hole drilled to the left of the center.
But remember that this hole is drilled at an angle. It's like if you would draw a diagonal line across a square, if you start at the top left you would come out at the bottom right.
With a double-walled rim and the angled line started pretty close to the center what's a "left" on the hub side can very well become a "right" on the tire side, just as a diagonal crosses over.
Move the holes just a little more apart and the tire side holes would end up in the middle whether they're a "left" or a "right" on the hub side.
Move them a bit more apart and a hub side "left" would also be a tire side "left".
And for a single-walled rim it doesn't matter, there a "left" will always be a "left", independent on which side you're looking at it from.
