Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Anyone use this?
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Anyone use this?
Old 12-26-03 | 09:28 AM
Traffic shark
20 Anniversary
Bikes: 2 fixies, 1 road, 29er in the works.
Anyone use this?
https://www.nashbar.com/profile_morei...ku=4897&brand=
SD Fixed is offline
Reply
Old 12-26-03 | 10:20 AM
Guest
Guest
Posts: n/a
No, but thanks... I'm ordering it right friggin' now!
Koffee
Reply
Old 12-26-03 | 10:45 AM
20 Anniversary
Bikes: 2002 Giant OCR 3, 2003 Giant OCR Elite, 2004 Giant TCR, 2004 Giant OCR Touring, 2003 Giant Iguana, 2004 Cannondale Ironman 800, 2005 Giant Trance 3
Koffee
Same here!!!
pletcgm is offline
Reply
Old 12-26-03 | 10:48 AM
CRUM's Avatar
Recovering Retro-grouch
20 Anniversary
From: Some call it God's country. I call it Acton, Maine
Bikes: Too Many - 7 or 8
I have sold them. They are some loud and cannot be ignored. The one bit of negative feedback I have gotten besides their cobbiness is use them carefully. They can startle the driver into attention mode and cause possible swerving. Don't lay on them, short blast is all that is needed.
Keep it 'tween the ditches
My Blog - Lost in the Bo Zone
CRUM is offline
Reply
Old 12-26-03 | 11:02 AM
Traffic shark
20 Anniversary
It's too bad I'm not rich. If I were, I'd get a custom framed bike, have the top tube welded shut at each end, and made air tight. I'd tap it with a valve and fill it with liquid CO2 to run a horn like this.
I'm thinkin of one, if only the horn didn't look so freakin goofy.
SD Fixed is offline
Reply
Old 12-26-03 | 11:03 AM
Guest
Guest
Posts: n/a
Thanks for the tip. I wouldn't lay on it anyway, since you have to continually add air. I would hate to run out during a ride because I felt the need to be overly aggressive, then when I really needed it, I would be out of air!
The only caution I do have is that I think in Illinois, we are not allowed to have air horns on our bikes- bells are fine, but not air horns. I'm still going for it, but I'll avoid using it if the cops are around.
Koffee
Reply
Old 12-26-03 | 01:41 PM
bentbaggerlen's Avatar
20 Anniversary
I have one, don't use it very often. Too loud to use on a MUT. But sometimes I'm so tempted... it is useful in trafic.
Bentbaggerlen
"When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking." - Arthur Conan Doyle
bentbaggerlen is offline
Reply
Old 12-26-03 | 05:32 PM
slvoid's Avatar
2-Cyl, 1/2 HP @ 90 RPM
20 Anniversary
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
I've seen these at the local bike shop. It's got a clear bottle pocket that u pump air into.
Let it rip and think "truck horn". BERRRRRRRR!!
Cars will notice you, people on the bike trail will hate you. In fact, it'll probably make pedestrians jump..
slvoid is offline
Reply
Old 12-26-03 | 07:56 PM
LittleBigMan's Avatar
Sumanitu taka owaci
20 Anniversary
I'm all for equalizers. I use a whistle. It's very useful to have a loud sound device (whistles are illegal, though) to grab the attention of that motorist who doesn't see you.
One drawback is that the time you use to reach for the horn might be the time you need to avoid a collision, especially if you have to remove a hand from the bars.
No worries
LittleBigMan is offline
Reply
Old 12-26-03 | 09:38 PM
BlastRadius's Avatar
Direct Hit Not Required
20 Anniversary
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
Cheaper alternative would be to use the CO2 cartridges that are readily available. You could possible fashion a tire inflator into a lighter alternative
than the water bottle air tank. However, the 600-800 psi of liquid CO2 would be a safety concern.
BlastRadius is offline
Reply
Old 12-27-03 | 04:58 PM
Jean Beetham Smith's Avatar
20 Anniversary
Bikes: Felt F-70, Terry Madeleine, Novara Safari fully customized by me
I used to use an Air Zound. I mounted it at the end of my handlebar so that I could hit it with the heel of my hand. I liked it very much, and think it probably saved my life a time or two, but they don't last very long. Sometimes just putting a new coke bottle on them would fix the problem, but they die after a year or so. They also don't work well in the winter. Currently I use a hand held marine foghorn from REI, just as loud, and works in cold weather. I fasten it on my handlebars with a strip of old inner tube. Maybe $5 total.
Jean Beetham Smith is offline
Reply
Old 12-27-03 | 05:55 PM
khuon's Avatar
DEADBEEF
20 Anniversary
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Just for clarification... For those of you who ave used the Air Zounds, was your experience with the original or the Air Zounds 2? And if it's the latter, do you know if the AZ2 fixed the shortcomings of the original?
My only forseeable issue with these types of horns is that one of my most dangerous riding incidents involve people cutting in front of me at an intersection at the bottom of a hill when I have a green light or any intersection where I'm really moving through at a fair clip for that matter. We have plenty of those types of intersections here in the Seattle area and I usually try and mitigate the risks by braking to near 15MPH (from 40+ MPH) so I can safely panic-stop when some idiot decides to pull out right in front of me. This present many drawbacks as one can imagine not the least of which includes possible brake fade on long hills. As such, I'm covering my brakes and in the drops and either way, I'd rather not have to remove my hands from the brake levers to operate the horn. What would be nice would be some sort of remote trigger mechanism you could mount to the brake levers to activate the horn.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
khuon is offline
Reply
Old 12-27-03 | 07:45 PM
20 Anniversary
Mine is the early Air Zounds horn, I don't have it mounted on a bike right now, it's a paint to move from one bike to another, so for the most part I've stoped using it.
The type of horn that Jean is using is better then the Air Zounds horn. It works in the cold better then the Air Zounds.
Bentbaggerlen
Reply
Old 01-08-04 | 06:38 AM
Tom_The_Bikeman's Avatar
Señor Member
20 Anniversary
air ZOUNDS
Yup.
However, not on single, fighter-type bicycles, only on our tandem, and driven by stoker use. Basically, one blast from this will stop dogs in their tracks, get Grandma's attention, and will let cars know that you are there.
I've been tempted to use it on some doggies who are insanely interested in my riding by them at a dangerous curve on my commute, but I've managed to restrain myself so far.
Air Zounds works great.
Enjoy,
Tom
P.S. as I can achieve 100 db with voice activated built-in alarm (HEY!!!) I usually settle for a little ding ding bell to alert elderly people that I am about to kill them by running them (and their little doggy, Toto) over. Worked this morning....
Tom_The_Bikeman is offline
Reply
Old 01-21-04 | 09:52 PM
Jay_2004's Avatar
-RiDe On-
20 Anniversary
Bikes: 1 Supercycle Hoolagan ...(i need a new bike as you can see)
All we need now is some flashing lights and a box of flares....
Jay_2004 is offline
Reply
Old 01-23-04 | 10:15 AM
20 Anniversary
From: The Alta Loma area of Rancho Cucamonga. About 45 miles east of Los Angeles, California. Uphill, downhill and across hill riding; not too level!
I have found that, along with one of the parents of 3 stubborn human-type beings, that my bike riding has improved my lung capacity enough that I can holler quite loud enought to get just about ANYONE's attention. In a closed motor vehicle or not.
Except for my husband.
His "selective perception" is really quite good; better than mine!
foehn is offline
Reply
Old 01-26-04 | 05:05 AM
20 Anniversary
I like the idea of the air horn, but if I were driving my car and heard that I would probably jump. That is probably a reaction a cyclist wouldn't want from a motorist.
Someone mentioned using a whistle, but they are illegal. Why? If it's just where they live then that really sucks. Whistles issue a high pitch that is easier for the human ear to detect than the lower pitch of an air horn. Because of this a whistle requires less energy to be detected. I like the idea of using a whistle, but I don't think I have the reflexes to put a whistle to my lips and blow it in a split second life or death situation. I also don't think I can keep a whistle between my lips for the entire duration of a bike ride. Here's a cool alternative. Attach a compressed air tank (like that air horn's) to a Storm Whistle (tm) (one of the loudest whistles in the world) with a button valve to activate it. High pitched warning alert at your fingertips.
Wayneburg is offline
Reply
Old 01-26-04 | 12:52 PM
Max
20 Anniversary
I returned back to the bell from the horn. I noticed that when people hear the bicycle bell they realize that the bicycle is behind and behave properly.
But when they hear the horn blast they think that it is the sort of a truck behind and jump sideways, maiking it risky to pass them.
I also noticed that my horn does not work in frosty weather. Though my bell also does not work but in rain.
The whistle seems to be the good idea, because the police uses whistles. Maybe only for emergency situatiions, since it is illegal. Once I cycled in the dark in the yellow reflective vest, which resembled the one, which the traffice police uses. I noticed that the cars were slowing down everywhere, as soon as they saw the familiar yellow outline in the dark. Probably they thought that it was the policemen on the motorbike. But it felt good.
Max is offline
Reply
Old 01-26-04 | 01:42 PM
Sumanitu taka owaci
20 Anniversary
Since I wrote the above post around Christmas, I've rigged a 12V car horn to the homebuilt light set I put together. The horn cost about $12 and the activator button an additional $6 from a local auto parts store. It's plenty loud.
Since I already had the 12V power source, it seemed just as cheap as an air horn to add to my bike, and possibly more reliable. I've tested it in real traffic situations, and motorists pay attention to it.
I don't usually ride around pedestrians, but I will mount a small bell to alert them. I think the bell is appropriate for them, but for cars, a horn is necessary.
(I carry the whistle in my pocket as a back-up.)
Next, I'm replacing my rear LED's with a red 12V light.
No worries
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
