Carbon post stuck in steel frame
Bikes: 05 Norco CRR Team Carbon Dura Ace, 06 Cervelo P2C TT Dura Ace, 88 Olmo Steelie w. Campy Mirage, Cypress CX w. 105
Just picked up a used Colnago Master Light, just immaculate, beautiful bike. I knew I needed to have the seat raised, but thought, 'no problem, I can do this at home.' Nope. Post is jammed in the seat tube. Suggestions? Penetrating lubricants? Hulk Hogan biceps?
I'd be doing myself, and you guys, a disservice if I didn't ride the hell out of this thing!
Bikes: Trek Madone 5.5, Klein Q Pro Elite, Surley LHT
You could try penetrating oil. This will ruin the seat post. My guess is that someone lubed the seat post with grease. This is a no no on carbon.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
How does greasing the post lead to it being stuck?
www.theheadbadge.com
Quoted: 2430 Post(s)
Liked 4,430 Times
Thanks guys. I've put some penetrant down it and I'll see if I can get it loose tomorrow. If not I guess I'll have to take it back to the LBS and maybe they can hack it off and pry out the shards and I can put in a new seat post. Oh well.
S Force,
So what happened?
I found your June discussion with interest (one guess why) and am interested in how it "worked out".
My situation
I've a Serrotta Fierte with carbon back stay bonded to the steel frame just south of the seat tube. Yes, FSA seat post stuck in the steel frame. I'm concerned about PB penetraiting oil as it might weaken the carbon back stay to seat tube bond.
Looks like a 1" reamer or drill would remove 50% of the seat post and annoy the remaining bit. If the about 15cm of the post is in the seat tube, the rest is on the shoop floor after it broke off flush to the top of the seat tube.
So what happened?
My situation
FYI, I hack sawed and peeled and yanked bits and pieces out. I removed the part that had stuck to the inside diameter of the seat tube. It turns out the seat tube is double butted with the top 3" or so smaller diameter than the remaining part. The last 1 or 2" of the carbon seat post fell down teh tube. The frayed end prevents any hope of pulling it out so after an eventfull replacement with a good old (cheaper) (lubricated) aluminum seatpost I rode to NH. Guess what? It rattles like a broken water bottle cage.
I am dreaming of forceps and a long nosed nibbler to get the carbon rattler out of there.
Boosted Mr2
Bikes: Klein's Merlin's
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 28 Times
My Fierte is steel seat tube but the same holds true. BTW, The remaining rattling bit is a full cylinder with a splayed end so at this point it can't be blown out. I did have the bottom bracket out for the first operation where the stuck portion was removed. With very long nose plier-vice grips maybe I can nibble and fray the rest into small, removable pieces. I am wondering what to use to cut and nibble the remaining piece. It can't get closer than the 3 or 4 inches of the top of the seat tube.
There is a special paste for carbon seat posts inserted into aluminum tubes. Apparently, the carbon bonds somewhat to the aluminum and you can run into that problem. I don't know about steel, but it'd be worth investigating with a google search.
Quoted: 2026 Post(s)
Liked 1,096 Times
You can get the stub out of the bottom of the seat tube, assuming the seat tube is open at the bottom bracket end.
Remove the bottom bracket and take a saber saw with a long fine tooth blade and place the blade through the bb shell with the teeth pointing up. Use the saw to slit and slice sections off of the seat post stub and break it out on smaller pieces.
Do this outside or with a lot of ventilation and use a "dust mask" while sawing.
Great idea Hillrider and thanks for the dust caution. Sadly, my Fierte only has a weep hole, not a slot. Got long handled nibbler anyone?
The mods changed this...
Okay, I've done this TOO many times...
Cut the post off about 1/2" to 1" above the seat clamp.
Take the hacksaw out of the saw and wrap one end in a towel.
Use this modified blade to cut the post by putting the blade down into the carbon tube.
Make vertical cuts MOST of the way through the post at even intervals around the tube.
-4 or 5 cuts does the trick
Once you've made all of the cuts, take a set a Channel Lock type pliers and crush the seatpost carefully.
The crushing will break the post free and you can pull it out.
This works EVERY TIME!!!!
Great State of Varmint
Liked 15 Times
Carbon in a vice would likely shatter into deadly, sharp shards. You can shatter it just tightening it. I often wonder why people buy seatposts made of carbon - myself included!
Do let us know what happens. We're probably next.
carbon post snapped
my carbon seat post cracked then snapped immediately at the top of the seat tube clamp so no chance to use a vice. My careful sawing led to pry and peel and successful removal. It left the bottom frayed portion. I did install an Al post but the left over piece in the seat tube rattles about just above the bottom bracket.
Quoted: 16 Post(s)
In any case, it's basically a non-metallic anti-seize compound.
Sci Fi
I wonder what the chemical reaction is between the steel frame and clear epoxy of the outer surface of the seat post (carbon fiber is buried in the epoxy).
Quoted: 16 Post(s)
^read the last 2 comments (carbon seatpost stuck in steel seat tube):
https://www.velonews.com/article/9023
It appears the reason 'no grease' is advocated is to lessen the chance of overtightening as if it was greased and had slippage (some have slippage even if there was no grease/lube present and torqued to the recommended setting..usually around 8 Nm) and crushing the carbon fiber which may lead to catastrophic failure and an emergency visit to the proctologist. You are going to get an argument either way - to grease or not - but almost all carbon seatpost manufacturers recommend removing the seatpost periodically, more frequently if you live in high humidity/wet and/or salt/near the ocean conditions.
Personally, if you aren't racing and don't need to save weight, stick to metal seatposts and/or use fiberglass sleeves or even paper as a barrier between dis-similar metals/alloys or carbon fiber materials if you are adament about not using grease/CF assembly paste/anti-seize/etc.
Thanks very much for your research. I still wonder chemically what happened.
Yep, I'm with you SciFi and back to Aluminum, grease and...a rattling left over piece of carbon. My LBS suggests laying the frame sideways and securing it (well below the replacement post) with a dab of epoxy. I still am dreaming of a long nosed nibbler.
Liked 1,096 Times
You can get a spray can of "foam in place" insulation used to insulate inaccessable areas by putting a thin nozzle through any small gap and the foam expands to fill the space. A squirt of this through the vent in the bottom of your seat tube above the bb shell should secure the stub in place and stop the rattle.
I'd try something like these to hold the piece of post: https://www.thetoolwarehouse.net/shop/SK-17851.html and then something like this: https://hand-tools.hardwarestore.com/...aw-600282.aspx to cut through the leftover post. In a completely different but somewhat related scenario, I used a combination like the above to saw through and collapse a piece of tailpipe that I knocked into the catalytic converter of one of my old cars.
