help, having hard time to get cog onto hub
Old 09-22-08 | 08:32 PM
i just got a new EAI cog and im trying to install it on my hubs, it starts off fine then it basicky sticks when i try and thread it on by hand. how smooth is it suppose to go on the hub? i removed teh cog, all the threads look fine and not x-threaded. What do i do? should i use the chain wip to tighten it on?
infinkc is offline
Reply
Old 09-22-08 | 08:36 PM
pirate's Avatar
what hub? its not italian thread or something is it?
pirate is offline
Reply
Old 09-22-08 | 08:40 PM
andre nickatina's Avatar
not actually Nickatina
Pry bars.
The more the better.
andre nickatina is offline
Reply
Old 09-22-08 | 08:44 PM
its a bontrager race x lite wheel set. the dura ace lock ring screws on fine. first time screwing a fixed cog on it, has a freewheel on the other side.
infinkc is offline
Reply
Old 09-23-08 | 10:05 AM
iDrake's Avatar
Fully Flared!
Make sure you lube the threads of the hub first, if it still shows resistence DO NOT FORCE IT!
What kind of hub is it?
iDrake is offline
Reply
Old 09-23-08 | 10:13 AM
Sixty Fiver's Avatar
Bicycle Repair Man !!!
Bikes: See my sig...
Make sure your cog thread match the hub threads...
Sixty Fiver is offline
Reply
Old 09-23-08 | 03:05 PM
this is what Bontrager says their hubs are:
ISOTrack cogs are threaded 1.375" x 24 tpi, Just like a bottom bracket. ISOTrack lockrings are threaded 1.29" x 24 tpi LH, a left handed thread.Freewheel threading is the same as the ISO track cog just without thelockring portion.
so it should go on smooth, since EAI is standard.
infinkc is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
