When do shorts become unhealthy?
Is there a temperature below which I absolutely mustn't cycle in shorts, even if it's going to warm up later? I don't really like wearing trousers (though I'm cycling in them now, because it is below freezing at night and only upper-mid 30's during the day), e.g. if it's 40 degrees, can I cycle to college (1.5 miles) in shorts, if it will be 55 on the return trip, or do I need to be a bit more patient?
I wouldn't cycle in shorts anything below 50 degrees, and even that is probably on the low end of reasonableness.
Why take the risk with your knees?
If you're feeling kinda Homer Simpson though ("Don't you hate pants??"), invest in some leg warmers for those ~50 degree days and quality tights for when its colder.
TWilkins
Standard wisdom that I've always heard is that you should cover your knees at anything below 60 degrees. I'm not sure where that originated, but you see it in a lot of articles. The reasoning behind it is that all the ligaments and tendons in your knee are so close to the surface that they are easily impacted by the cold and become more susceptible to injury.
The bottom line for me is that I would prefer to be warm than cold, so I tend to overdress when the temps are "between" cold and hot.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Personally I just do what's comfortable. The faster you go, the more calories you burn in your legs. Offsetting that is the increase in wind speed that cools. Whatever feels good is what Isay.
you should cover your knees when temp is 'in the 50 degrees'. so yes below 60, should cover
it up.
no matter who says what, do it.
this will ensure your legs and nerve endings will last as long as you do, whet
you get old. if you try to cheat (like I see a lot of idiots running shorts in the 40's
and even 30's) those people will get deep vein thrombosis and other nasty leg
problems when they get old.
cover them early and cover them often
it up.
You gonna eat that?
From: Fort Worth, Texas Church of Hopeful Uncertainty
Bikes: 1966 Raleigh DL-1 Tourist, 1973 Schwinn Varsity, 1983 Raleigh Marathon, 1994 Nishiki Sport XRS
I've heard that 65 degrees is the cut-off point for wearing shorts alone vs wearing tights or leg warmers with your shorts.
Dave, why not try leg warmers?
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Using the 60 threshhold would mean I hardly ever get to wear shorts. The average July temperatures where I live are 56 for the low and 72 for the high, although the sun rises very early, so it will probably be warm enough by the time I get out. That rule would restrict shorts for every day wear to July/ August, with the range extended to June-September for an afternoon jaunt. The May high is 63, but there's be too much risk it wasn't above 60 all day. Personally, I would feel thoroughly miserable and hot cycling in a pair of trousers at 59 degrees.
Aren't the legs also where the heat powerhouse is? They're doing all the work. 60 is barely below room temperature, so combined with vigorous exercise will generate a lot of heat. Also surely sweat soaked trousers will remove heat more quickly than dry air thus increasing damage Please don't tell me the damage I did that morning I cycled in shorts at 35-40, because it would be 50-55 later.
Sorry to offend anyone on here, but 60 is nowhere near the region I was looking at when I posed the question. Can I have some more realistic answers please?
You gonna eat that?
DD: Don't ask a question and, when people give you their honest answers, come back with "Can I have some more realistic answers please?" If you're trying to justify a position to yourself or others, fine. But this is a question without a definitive answer, so just take opinions for what they are.
dd: Don't ask a question and, when people give you their honest answers, come back with "can i have some more realistic answers please?" if you're trying to justify a position to yourself or others, fine. But this is a question without a definitive answer, so just take opinions for what they are.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Using the 60 threshhold would mean I hardly ever get to wear shorts. ... Personally, I would feel thoroughly miserable and hot cycling in a pair of trousers at 59 degrees.
... Sorry to offend anyone on here, but 60 is nowhere near the region I was looking at when I posed the question. Can I have some more realistic answers please?
Where I live, I rarely wear just shorts. I almost always wear leg warmers or tights. But that's the thing ... we're also not suggesting you wear "trousers" ... get yourself a pair of knee warmers, leg warmers or tights.
Like these, for example:
https://www.mec.ca/Products/product_d...=1230931278385
Or these:
https://www.mec.ca/Products/product_d...=1230931278383
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
I've also heard that some cycling coaches require that knees be covered in anything below 70 !
Now is it something backed by science or just a myth started by cyclists who lived in a climate where 65 is genuinely considered cold?
I've seen conflicting information so I don't know.
To me 65 is pretty close to an ideal temp as far as strenuous outdoor activity is concerned so I'm a little skeptical. I can't imagine for example starting a marathon at 8:00 am wearing leg warmers when the temp is 60. That just seems ludicrous. Of course running is different than cycling but does the cooling effect of moving at 15 to 20 mph make that much difference at 60 ?
"You're not just telling us what we want to hear?"
"No, sir, no way."
"Cause we just want to hear the truth."
"Well, then I guess I am telling you what you want to hear."
"Boy, didn't we just tell you not to do that?"
"No, sir, no way."
He's from an area where I'm guessing people routinely wear shorts for physical activity when temps are below 60. Take football or "soccer" for example. To say that wearing shorts below 60 is bad for one's knees runs counter to his experience, -not just his wishes.
Okay just to throw my 2 pennies, cents, whatever in on this. It does go against what I would:
a)like to hear. the 65 threshhold means I can almost never wear shorts as it gets below that first thing in the morning and hasn't passed 65 by the time I go out to college.
b)It seems to throw common sense right to the winds and beyond. I have been treated for dehydration, with headache and vomiting on a day where the MAXIMUM temperature was 65. I'd set off into 45 in shorts and t shirt that morning. I had the same again (but slightly less severe) after a long ride where the MAXIMUM was 61, let alone the 45 odd when I set off. If I'm having to be treated for dehydration after wearing shorts and t shirt on a day the HIGH barely scraped 60, and drank 2 litres of fluids during the day, what good is wearing trousers going to do. I thought trying not to sweat was important too. Is it some kind of sado-machistic machoism to see how long you can physically bear to be in long trousers, or do you all live in places where the overnight winter low is in the 50's during a cold snap. Sorry to disappoint you all, but the answers are way off what I would have expected. What I really want to know is when they become dangerously unhealthy, eg. putting myself at risk of getting sick, becoming hypothermic, etc.
Sorry to be so blunt but I have a mild ASD, so shorts, versus trousers is a sensory issue and the thought of having to wear long trousers all year is horrifying. I would look stupid coming into college with knee warmers, just because it was warm instead of hot and sunny in the morning, so jeans instead of shorts would be the only way.
Yeah, so? Join the club.
Wearing leg warmers or tights has nothing to do with dehydration ... it has to do with protecting the ligaments in your knees.
And you can remove knee warmers and put them in your pocket.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Gios Compact Pro 10 Chorus, Gios single speed, Pedal Force RS2 10 chorus, CAAD5 10 Centaur, Diamondback dirt bike, Fuji Fixed Gear.
Your body secretes a fluid in the joint for lubrication called bursa. When it is cold this process does not work as well so during extensive exercise in the cold the joint will actually wear out faster because it gets less lubrication. There are not a lot of muscles surrounding the knee joint to keep it warm. Most of the muscle mass is above or below the knee so it may be more vulnerable to the cold.
Just asked my brother who's a doctor and he says runners can safely wear shorts down to 40 and cyclists to 45. Suspected it must be in that area. When hiking, the temperature feels 20F warmer than standing, and cycling is more vigorous still, so probably more like a 25-30 degree difference running across, so 45 would feel like 70-75.
Sorry to disappoint you guys but I've talked with a qualified doctor, and the little "60-65" joke's over. I'd thought this was meant to be a sensible forum.
lol
I find that my knees are more comfortable covered up around 60F. Whether it is proper or not I do not care. Whatever a random doctor says matters not to me. What matters is how my legs feel.
My rough guide. It changes with the wind and how energetic I feel.
60F: knee warmers
50F: Leg warmers
40F: Lite tights
32F: Lite tights with leg warmers
25F: Heavyweight tights
10F: Heavyweight tights with long johns. I rarely ride at this temp.
60F: knee warmers
50F: Leg warmers
40F: Lite tights
Common sense has been evident in the posts that responded to Dangerous Dave. In initiating the question, he was seeking a precise measure, "... a temperature below which I absolutely ...". There is no precise measure which is why there is a variability in responses including that of Dangerous Dave's brother/doctor. Along with air temperature, consideration must also be given to wind, hence wind chill. The posters who suggested knee and leg warmers are obviously accustomed to the concept of layering of clothes. When temperatures vary greatly during a day, the prepared cyclist/commuter will have a layer of clothes to respond to the situation. Pictures of cyclists together during cool/cold temperatures invariably reveal a variety of clothes for reasons that individuals react subjectively and differently to the weather.
There seems to be a bit of a cultural element in this. Runners and cyclists have significantly different cut-off points. I'd say there are some cyclists here who cover their knees at 60 F, most do by 55 F and pretty much all by 50 F. But for runners, the same things probably happen at 50, 45 and 40.
For what it's worth, if I get to select a "perfect" temperature for strenuous outdoor activities, I'd go for something between 55-60. 65 is hot.
