Hub snapped off in freewheel
Too many bikes
Quoted: 5 Post(s)
Ebay lot. How would you get this out?
Seller doesn't know:
Someone paid a lot for this so I am guessing they know how to get it out.
https://cgi.ebay.com/ws/eBayISAPI.dll...m=250356606982
I don't have a clue. Lot of money just to get the cogs.
Now for the bad news. In the second picture you will see the butt-end of an American Classic freewheel hub which broke off during a ride, after I had attempted to remove the freewheel
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Send it to cudak888! He loves challenges like this. My guess; dissolve it with the appropriate chemical.
Bob
Bob
Plastids
You might be able to take a 6" piece of 1/2" all-thread, put two jam nuts on one end, feed it through the hole in the hub from the left side (in side, frame side), thread a couple of nuts on the free end of all-thread, and use the nuts to clamp down on what's left of the hub. Clamp all-thread in bench vise and use a freewheel tool to remove freewheel.
Alternatively, drill and tap a series of hole in what is left of the hub, screw it to a plate or bar, put plate in bench vise, use freewheel tool to remove freewheel.
If neither technique works, go get a beer, sit down and stare at freewheel until you think of something else. Beer fixes almost anything.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Disraeli Gears
There's a tool called a "screw extractor" that's a tapered shaft with a barber pole of splines up it. You jam it inside, twist to engage the splines deeper and deeper, until the friction of the exterior threading loses to the friction of the tapered splines biting into the inside diameter of the thing being removed. This presumes right hand thread, I think, so should be OK for a freewheel. And I think that they come large enough.
Take your choice: $15 to $60 at Sears for sets.
Screw Extractors
Screw Extractors
Great State of Varmint
Liked 15 Times
What's the name of that stuff that is used to remove stuck stems from headtubes? Or some other high-penetration oil. Soak it for a day in that. Find something metal about the same size that will fit through the freewheel. And beat it with a 2-pound rubber-mallet. Or is it actually engaging the threads of the freewheel??
Bizarre!
Bizarre!
Freewheel Medic
Liked 2,196 Times
Ole, PB here!
Bob
Bob
Quoted: 413 Post(s)
Liked 109 Times
Dremel with the proper cutting bit. It would tale no more than 5-10 minutes.
$31? I guess its time to sell me freewheel stash.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
