Cyclist's tea cozy
Bikes: Two Robin Mather custom built tourers
Cyclist's tea cozy
I just wanted to share a great idea, that came to us courtesy of Ray (biketouringtips.com), who also posts here. We had the pleasure of meeting Ray and his wife recently and they gave us the materials to make the cyclist's tea cozy, out of heating duct insulation and velcro:
It helps you keep your tea warm, and you can cook pasta faster by just boiling the water, putting the pasta in and taking it off the burner and covering for a few minutes. It also doubles as a cool bag to keep things better in hot weather.
Brilliant! Thanks Ray
Bike touring webrarian
Friedel,
Julia was asking me how the cozy was working out. It looks like you've managed to get it put together and are using it.
I'd be interested in knowing how much, if any, fuel it saves.
Happy cycling.
Ray
Happy cycling.
Ray
Truly, this is one of the best little gadgets we've had the pleasure of using on tour.
Caffeinated.
Bikes: Waterford 1900, Quintana Roo Borrego, Trek 8700zx, Bianchi Pista Concept
That insulation is nifty.
I've also used it to cozy up a Nalgene bottle. Keept beverages nice and hot below zero, and is easy to regulate heat by just sliding the cozy.
for affordable housing
That's quite a nifty little gadget you've got there... mind posting up a quick tutorial? What did you use to hold it all together? Where did you get the insulation? Do these vans get good gas mileage?
The wrap is silver on the outside and white on the inside. The inside also has a sticky strip on it that I used to stick two plys of the wrap together so that all you see is the silvery outside. I created three pieces: One to wrap around the pot, one for the top and one for the bottom that I velcro to the sides to create a better seal. The top is simply stuffed inside. I think all of these pieces are readily apparent from the photo.
I sealed the ends with a kind of metal tape that was also available in the same section of the hardware store. But, I suspect that any kind of tape would work and that this sealing is not even necessary (given that the stuff I used could be stuck together using its own stickum).
I made it from three pieces so that I can fold it down to almost nothing when it isn't in use. If I made it all a single piece, I don't know that I could do that.
Since I have two different sized pots, I have made liberal use of stick-on velcro to allow me to adjust the circumference of the pot I can wrap.
It never occurred to me to use the cozy to keep something cold. I'll have to try that on my next tour.
If these directions aren't clear enough, do a google search for "pot cozy" and you'll get pages more of them.
Some people make the cozy out of closed cell insulating pads, like the kind people sleep on. If you have an old one of those, it will also work. Here's a set of directions for doing that: https://sourcetosea.net/how-to-make-a-pot-cozy/
I used the bubble wrap because it is lightweight, easily folds down to almost nothing, and I didn't have any of closed cell foam.
I hope this helps.
Ray
The Duke of Furl
Bikes: Cannondale T800
Why not post this here (a DIY thread) too: https://www.bikeforums.net//showthread.php?t=539304
I will post a full tutorial will pictures one day but could take a while. Thanks Ray for leaping to the rescue in the meantime. It's really not hard, only takes about 10 minutes to make. Just get the insulation, measure out the right size for a top, bottom and wrap-around piece for your pot (using two pieces of insulation back to back) and add the velcro to hold it together. A bit of duct tape seals the edges.
Bicycle Lifestyle
Bikes: Neil Pryde Diablo, VeloVie Vitesse400, Hunter29er, Surly Big Dummy
its called reflectix
https://crew445.org/philmont/potcozy.htm
there's a ton of this stuff, easy google search.
