Frame dents
Old 05-21-09 | 02:11 PM
Frame dents
I just bought an old road bike frame with the intent of converting it into a fixie. I have 3 fairly large dents in the frame though. Should I bondo them strictly for cosmetics or are they too large and will they affect the integrity of the frame? What are my other options? It IS a steel frame...
File Type: jpg
File Type: jpg
File Type: jpg
Rmcolvin16 is offline
Reply
Old 05-21-09 | 03:34 PM
15 Anniversary
Bikes: '20 Scott Addict RC 30, '13 Trek Soho Deluxe, '91 Greg Lemond Maillot Jaune, Mid '70s Cuevas
Those dents are functional- they allow for more tire clearance (on the insides of the chainstay) and clearance for a chainring (on the outside of the chainstay.)
cuevélo is offline
Reply
Old 05-21-09 | 03:36 PM
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
the dents were put there by the manufacturer.the inner ones are for more room in there for different tires sizes,and the outer one is for the chainrings so they don't rub on the frame.in other words it fine just go ahead buildup the bike and repaint it if that your plans.
bikeman715 is offline
Reply
Old 05-21-09 | 03:48 PM
Is he referring to the manufacturer-crimped tubes or is he referring to damage dents? At least, I think I see three dents that are a form of damage. One is on the seat tube (look for circular paint feature).The other two are both on the right side chain stay (as if bike were dragged across a hard surface).
If I am reading the photos correctly, I would first have the frame alignment checked - dented tubes usually mean some degree of geometric deformation, especially the chainstay. If the geometry is good, you can consider cosmetic repair of the dents.
Mike Mills is offline
Reply
Old 05-21-09 | 06:32 PM
damage or manufacturer?
There is not a dent on the seat tube... just those two bottom tubes. Not sure what those are called. So you think that would be from the manufacturer?
Reply
Old 05-21-09 | 07:25 PM
JanMM's Avatar
rebmeM roineS
20 Anniversary
'Chainstays'
JanMM is offline
Reply
Old 05-21-09 | 07:46 PM
AEO's Avatar
AEO
Bikes: Bianchi, Miyata, Dahon, Rossin
those crimps are pretty normal on all bikes.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Reply
Old 05-21-09 | 11:15 PM
20 Anniversary
those are definitely part of the design (in case you needed more confirmation).
tFUnK is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
