What Kind Of Road Bike Do I Have Here?
Old 07-19-09 | 06:33 PM
JohnnyGalaga's Avatar
Intergalactic Excellence.
I bought this bike used about 6-7 years ago and after a 5 year hiatus, I dusted it of today and went for short stroll. Unfortunately, it will not downshift the sprocket. The crank works though, so I'm basically down to a 3-speed. Any idea what year this bike was made ?
I forgot what I paid for it. Everyhing on it says Shimano RSX and the frame has CR-MO 4130 on it, whatever that means. The wheels are 700 x 23c. I've tried searching the internet and can't find any information on this bike. When I search for GT Force, all I get are mountain bikes. How much is this thing worth? Is it considered any good? Thanks.
JohnnyGalaga is offline
Reply
Old 07-19-09 | 07:02 PM
Panthers007's Avatar
Great State of Varmint
First analyze the concept of a 'bicycle.' It is actually a frame & fork with a collection of components that are supposed to work in harmony with the frame & fork. Now this bicycle has been sitting around for 5 years. And you're having difficulty with the rear-derailleur (RD) not shifting. And I'm not surprised.
During long-term storage, the grease and oil and dirt and grime can form something that works best as a glue - not a lubricant. So I would suggest a thorough cleaning of both front and rear derailleurs. WD-40 will work well for dislodging grime - just don't use it as a lube. As the cable-housing has likely become internally affected by the grime - get new housing. And new cables as well. The brake-cables look good from here, but I'd replace them as well - to be safe. Once both derailleurs are clean, add one drop of good oil to every moving part - bolts, pivots, springs, etc. Then replace the cables and housing. Here are instructions for doing the adjustment on these components:
https://www.parktool.com/repair/readhowto.asp?id=64
https://www.parktool.com/repair/readhowto.asp?id=75
https://bicycletutor.com/adjust-rear-derailleur/
https://bicycletutor.com/adjust-front-derailer/
Or: Bring it to a shop you trust and ask them to do this for you.
Your old bike looks to be in fine condition. Get it fixed-up and ride it before you think of selling it. Looks like a nice bike!
Panthers007 is offline
Reply
Old 07-19-09 | 07:32 PM
It felt pretty smooth when I rode it today and I was able to upshift the rear derailleur but then I couldn't shift back down. It sure was a heck of a lot faster than my 40+ pound Diamondback Outlook with 26" x 1.95" Armadillos that I often commute on. LOL.
Thanks for the advice!
Reply
Old 07-20-09 | 05:58 AM
BlazingPedals's Avatar
20 Anniversary
Bikes: Trek 7500, RANS V-Rex, Optima Baron, Velokraft NoCom, M-5 Carbon Highracer, Bacchetta Quattro, Catrike Speed
It's a late-90s, back when GT was a good brand. Lube the derailleur cable and adjust it up, it should be fine. RSX stuff was about the same level as Sora is now, I think. Not fancy but perfectly functional. It's probably not worth a lot, simply because of its age and old componentry.
BlazingPedals is offline
Reply
Old 07-20-09 | 07:38 AM
Gitane Fix(at)ed
Bikes: Nice Gitane Fixed Gear, Cheap and cheerful rigid MTB, Wonky commuter, A fully 105 road bike with a pipe steel frame
The bike seems to be in a very good condition. I.e. not used.
You should really clean up & relube the moving parts.
BTW, you still have small plastic adjustment indicator (the tape-like thingie with red band) on the front RD. Remove-it.
As for the downshift, maybe it's just the RD/cable, but it could also be the brifter. Do not disassemble it, but try to flush with some WD40 or something.
DarkCloud is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
