How does Titanium ride?
Old 07-30-04 | 01:26 PM
amahana1's Avatar
serenity NOWWW!
Bikes: custom surly SS, several others in the works
Ive been looking a building a new cross bike and have been impressed with Airbornes Ti Cross frame, but I have never ridden A Ti bike, just wondering what kind of ride Titanium usually gives the rider. What kind of frame life am I looking at with Ti, compared to steel. How does Ti handle loads like a trailer or panniers? I currently ride a Cannondale so I have plenty of experience with AL, and Have ridden a giant mtn bike for years and its cromo, so basically Ti is a total mystery to me... Any experience with this would be very much appreciated!!!!
amahana1 is offline
Reply
Old 08-03-04 | 03:28 PM
telenick's Avatar
1/2 a binding 1/2 a brain
20 Anniversary
Bikes: Serotta Ottrott ST, Titus RX100, Seven Sola 29er HT in the works
Ti tube sets like any other frame material can be tuned for stiffness or compliancy. That said, Ti generally has a more refined (maybe smooth is the word) "road buzz" than steel.
I have a ti road bike that will handle the stress of a trailer. I would imagine that most cyclocross bikes will also regardless of the frame material. But don't take my word for it ...ask the manufacturer if their CX frames will handle a trailer and if they're still under warranty if you do pull a trailer. Some bikes (ti or other material) cannot handle the "dish rag" twist that can occur with a trailer. So, it's not a material issue as much as how the frame is tuned to handle stress. Panniers present a different dilema. Panniers on the rear of a bike will require enough heel clearance for pedaling. Typically, you'll find that clearance on a touring bike but not a CX bike.
Seven makes a beautiful CX specific ti frame. I'm sure there are others as well.
seven cycles
telenick is offline
Reply
Old 08-03-04 | 03:32 PM
telenick's Avatar
20 Anniversary
From the web:
Titanium
Titanium tubing is widely viewed as the ultimate frame material. Just as all aluminum and steel are not the same, the quality and properties of titanium can vary greatly with each tube manufacturer.
If you look at the Periodic Table of Elements, you will find Ti below Al., indicating that Aluminum is lighter than Titanium. However, Titanium has superior mechanical qualities over Aluminum. In addition to having an excellent strength to weight ratio, Titanium has a structure which is resistant to fatigue and corrosion.
The simplest and cheapest titanium tubing is known as CP, or commercially pure titanium. This is just what it sounds like; a simple element drawn into the shape of a tube. The typical CP frame is extremely flexible. Although titanium can resist many more stress cycles than aluminum or steel, this excessive flex will quickly lead to a work hardened stress crack. Yes, even titanium can fail.
To improve the ride characteristics of a CP frame, some manufacturers introduce oxygen into the fabrication process. The oxygen embrittles the titanium and provides a degree of stiffness to the frame. The downside is that this process also shortens the fatigue life of the frame.
The best way to improve the property of Titanium is to mix in Aluminum and Vanadium. By adding 3% aluminum and 2.5% vanadium, you get 3-2.5 Titanium alloy.
This next point is important; all 3-2.5 titanium alloy tubing is not the same. How the tubing is produced greatly effects its strength and ride properties. Depending on the method used to draw the seamless tube, minimum yield strength can range from 75,000psi to 105,000psi. Additionally, by cold working the tube, the grain can be altered to better meet specific load requirements. Sandvik is one of the largest and oldest fabricators of titanium tubing. They control the production from the raw ore to the finished tube, and make all their titanium tubing to aerospace standards.
Steel
While the term "steel frame" covers anything from the stamped high tensile rig sold by mass merchandisers to the custom cromoly handbuilt, we'll limit this to the quality end of the range. Steel is appealing because it's durable, easy to work with and repairable.
Basic components of 4130 cromoly steel are Chromium, Molybdenum, Manganese and Carbon. The ratio of elements combined with extrusion techniques is what makes a quality steel tube different from others. If made properly, a 4130 CroMo frame can last a lifetime. Unless a quality steel frame is pushed beyond its maximum yield, it should not fail. Yield strength of "standard" CroMo is @760N\mm2 compared to 3-2.5 Titanium's 792N\mm2.
Steel is durable and can be comfortable and efficient. Springs are made of steel as the material can retain energy and expend it back. A steel frame does not absorb the force of a pedal stroke or the impact of a water bar, it stores it. The gathering of force is what makes a frame comfortable and the return of that energy gives a steel frame a lively feel.
telenick is offline
Reply
Old 08-03-04 | 05:32 PM
late's Avatar
20 Anniversary
Hi,
I have a Carpe Diem. When I was researching it, I came across an English review that said it wasn't all that great for cyclocross racing.
I use it as a road bike. It has compromise geometry. If you want a 'one bike does it all' bike....that's a good choice. If you want something hardcore cyclocross..... you might want to look for a CX specific design.
Oh yeah, the ride is firmer than I had expected. A classic Ti ride is almost cloud like. None of that here, the ride is firm and fast.
late is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
