pedal crank
pedal crank
Everytime my left foot passes 12 '0' clock on the pedal crank I get a
'clik' noise - anyone advsise as to what the problm is
many thanx in anticipation
(Grouchy)
check to make sure the front derialleur cable isn't hitting the crankarm. also check to see it the derailleur cage itself isn't hitting the crankarm. and that the chain isn't hitting the derailleur cage. if it's not any of those it's most likely bottom bracket related.
a few questions:
1) does it happen all the time?
2) does it only happen under pressure? (since you said it happens at 12 o'clock, i'll assume no, but still, answer!)
3) can you feel it click through your feet, or up through the frame through your booty?
a few questions:
Quoted: 2368 Post(s)
Liked 1,761 Times
4) Does it happen standing and sitting, or sitting only?
Also check that it's not something silly like a shoelace hitting the downtube or crankarm, the end of the derailleur cable hitting the crank arm, etc.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Another thing to check is for a bent tooth on the chainring. Barring all that, you might want to consider taking it into a shop to see what they say.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
JRA...
Bikes: trek 520 & 736, DeRosa Professional, Fuji Professional, Raleigh International 3-speed, Saronni (any info people?), Humber 3-speed, Raleigh Sports, Carlton Grand Prix coming soon!
My guess is your left hand crankarm needs a tightening or is damaged from riding loose, or the fixed cup of your bottom bracket is is loose. but best have someone with some knowledge look at the bike up close.
I was just trying to think how to ask a question with a similar problem, except my bike was new, & it's on the right side. Had already thought of pedal bearing, bottom bracket, & derailleur cage, thanks for the extra ideas.
