No brazeons and Campagnolo style dropouts...
Survival of the Fitest
Bikes: 198? Univega Custom Maxima, 2009 Motobecane Fantom Cross Uno
I was at my LBS today (I'm sort of a newbie) and i was asking for advice on puting a rear rack on my 1988 Centurion Ironman frame that has no brazeons. One of the first things he asked me is "Do you have Campagnolo style dropouts?" I didn't quite understand what he was asking, I asked him to clarify, he described a angled, notch cut out....I said "no".
Then when I got home and looked at mine I thought "Oh...is that what he was talking about?"
(see pic)
If what I have are Campagnolo style dropouts, are there other options for me besides clamp on brazeons for the lower supports? Or are there other concerns? He also asked me what kind of frame material my bike was (Tange #1).
(see pic)
Ride em all
Bikes: Tandem,2 road bikes, 2 mtb
You can bolt through that little triangle in the picture. Just make sure you use washers so the bolt doesn't fall through the hole. Also you may have to use a low profile headed bolt to fit between your cassette (gears) and frame depending on the room. One of the miyatas we own has the same type of set up and my wife has travelled many miles loaded with that set up
Ooo ooo Ooo...I would PAY to see pictures of your wife's setup! I've been struggling with a rack setup for some time now and getting kind of frustrated.
hello
I like GTscottie's idea. Makes good sense.
One less car
Bikes: '08 Soma Groove (commuter/long distance tourer), '97 Lemond Zurich (road commuter/tourer),'01 Seven Axiom Ti, '03 Look KG381i, '01 Santa Cruz Superlite X
Sounds like you found out what Campy style dropouts are...
Simply solution, buy a (round) rubber grommet and stuff that into the triangle, then use a simple bolt and nut throught the rubber grommet and use that. I do that on my road commuter bike (a Lemond Zurich) with an n'ero pack/rack on it.
The only thing with this is on the drive side, you're going to have to find a really short nut and bolt so you don't interfere with the cassette. A too long bolt or nut may prevent you from using the smallest cog, if that affects you at all. I was lucky and found one that fits perfectly, however, one can either cut a longer bolt to size or find one that works.
You can buy a specific adaptor, I think Blackburn makes one but a rubber grommet from a hardware store also does the job...
Jay
Jay
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Another option would be to use Tubus QR Adapter. I'm not sure if it only works with Tubus racks or not though.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Jay
Jay
Fantastic! I just called one of the LBS and they have one of the Blackburn kits in stock, only $4 for a pair! Thanks a lot everyone!
What's the max load I can expect to carry on a setup like this (using the blackburn kit)?
One less car
Honestly, don't know, but I have commuted to work on my Lemond for about 1.5 years until I found a dirt trail and then started to use my MTB. I still use my Lemond with my grommets on occasion and I'll still run errands and do some grocery shopping on it. I would not be afraid to put 20-30lbs on the setup. Commuting wise, I don't think I ever had more than 10lbs in my bags but it would probably be better than alot of those seatpost racks and they usually only have a 25lb limit or so...
Worst come to worse, the rubber grommet breaks or so, but the frame is still there and if you do use a washer (you should) it wont come lose. Might also try to contact Blackburn to see if they have a professional opinion..
jay
jay
Bad news...I got the Blackburn kit, there's not enugh room between the inside of the dropout and the smallest cog for the nut/bolt to fit. And no, I can't just get a shorter bolt...the nut or the head of the bolt would have to be about as thin as a dime in order for it to work. Shucks. If i went with the clamps...how much weight can you expect to carry w/o danger?
The Rabbi
Quoted: 16 Post(s)
One less car
Sorry to hear that DL, here's a thought, I knew I was thinking this long time ago when I installed mine, but I didn't mention. Have you perhaps tried to thread the bolt the other way? Put the head of the bolt (skinniest head you can find) on the inside of the dropouts and put the nut on the outside? Therefore you might be able to find a skinnier head than a skinnier bolt.
Just an idea, since you wont be taking this on and off too much (are you?) it wont make it too hard to remove the wheel before taking off the rack.
What do you mean by the clamp? You talking about a P-clamp, something that will wrap around a seat or chainstay and you put a bolt into that? I think something like that would allow for a bit more weight, but that is just a layman's opinion. I've never had to use one so far and at this point, I'll never will cause any more bikes I'll buy will have brazeons for racks on them
Jay
Jay
hello
I would then go with khuon's suggestion (post #6) using the skewer mount. They also have very nice 'P' clamps shown on that same webpage. Either mounting system should work well, but after seeing how nice their clamps are, I personally would go with the clamps. The skewer mount is a bit of a hassle when time comes to removing your rear wheel to fix a flat. I have a skewer mounted rack on my mountain bike frame.
Originally Posted by seely
Last time I said that I think I got knocked out.
LOL
