Who currently rides on a bumbike/loctite/suicide setup?
Just curious, thats all.
All of my working, rideable bikes are both fixies, and use the bumbike/suicide/loctite method... No problems so far..
So how many people here ride fixed bikes not using a track hub, but rather a substandard method instead?
I have one bike currently running w/ loctite and a BB lockring. I run a 92" gear on it and skid often. I have, in over 10 years of riding fixed off and on, never had a problem w/ this setup. YRMV
Play all day
Bikes: 80's Fuji Fixie Conversion, Voodoo Bizango, 80's Performance mountain bike converted to single speed
I've been riding a suicide hub for a couple months now with loctite and BB lockring. I haven't had any problems at all. I lucked out with my chainline. It's near perfect (maybe 1mm off) with the chainring running on the outside of the spider. I figure that if I ever want a new cog, I can just get an old wheel at the local thrift shop and make another suicide hub
. I take pride in it, hehe.
SuperstitiousHyperrealist
Bikes: unknown road conversion, half built Benotto track
While I have never done it myself you can chalk up the omniscient/omnipresent Sheldon Brown as part of this group. According to him, his setup is working fine.
There are a lot of people who will ***** on this setup although it is proven to work. I have NEVER heard a horror story from people who run it.
My $.02
My $.02
just MEMBER
I was running one for a while. I could never bring myself to put the loctite on though. Fear of commitment I guess. Still though, I used the chain-wrapped-around-the-bottom-bracket-shell-then-turn-rear-wheel-in-the-direction-to-tighten-the-cog-and-crank-like-a-mofo, method.
This was the wheel I learned how to skid and skip on, which means there was a lot of practice. No problems. I switched to a track hub for peace of mind.
i buy vinyl
ok can somebody fill me in please. what's the diff between the "thread, locktite, and lockring" method, and the "track hub" setup mentioned in the first post. i thought that's what a track hub was?
icthecat - nice description - that should be in a fixed gear faq or something.
I run the suicide hubs, no problems. I don't skid, though - run with a front brake. I have my cogs and BB lockrings JB welded into place (permanent, to my knowledge).
im building one right now, i asked for some advice here and some people mad me fell like a a$$. but thay can f off
I have two bum wheels and a regular track wheel. When I wanted to pull the 14 cog off one of the bum wheels, well, I still can't remove it. Maybe I'll just keep it there... The bum wheels are doing rain bike duty - out of principle- but I've never had a problem.
This is good info. I'm planning on this set up for a beater/polo bike. Although I will never run brakeless on such a setup.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Originally Posted by rwan
Agreed. I run loctite/BB on my commuter and whole deal is rock solid.
As in TOO rock solid. It makes sense to have a track cog just so it is easier to switch cogs. Loctite is akin to welding.
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
Just a hint, loctite can be released with the gentle (or not so gentle) application of heat! If you ever need to change your mind, just use a heat gun or propane torch to heat up the joint a bit. The expansion of the cog combined with the thermal destruction of the loctite should let you remove it. Even the 'permanent' loctite will succumb to this treatment.
If you end up having to use more than a gentle shot of heat from a heatgun, check your bearings afterwards, since you may have cooked the grease out.
peace,
sam
peace,
sam
Did it for a year with no problem and I am going to put that wheel on the Yamiguchi with no front brake.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Ended up run my Bonti's that came with the Fillmore that way on on side (fixed/free). 18T with bottom bracket lockring, no loctite, no problems. Of course, it was "farmer's tight". Don't skid much (emergency stopping procedure #1) and use the front brake when needed.
For the record, my red-locktited cog refused an (albeit weak) attempt to unscrew it a few weeks ago. I ended up changing my chainring from 42 to 53 to change my gear, t'was easier that way (not the gear, the change).
無くなった
Bikes: I built the Bianchi track bike back up today.
I must have been doing something wrong. I was running the track hub and spun it off. Turns out I needed to have a suicide hub. Who knew?
