CREE XML XM-L T6 LED Bike Bicycle Light
Bikes: Schwinn Empire XL
Has any body got one of these light?
The add says that it will out put 1000 LM
I like to hear any input on thses lights. I found one for $40.86 and was thing on getting it.
I found it on Amazon at https://www.amazon.com/Bicycle-HeadLi...3475655&sr=8-2
And went ahead and order it too. So I'll let you know how good it is.
Good luck with it. I have a CREE LED headlight (Dinotte XML-3) and I love it. It's brighter, yet smaller than my old lights. Lights sure have come a long way in the past 10 years or so.
https://www.dealextreme.com/p/mj-808e...-4x18650-57100
I rolled the dice and ordered 4 for me and my bros to use night mountain biking. They're awesome, not as many features (that I don't use) or quite as nice a beam as the more expensive options, but really bright, reliable and with good runtime. Order an extension cable if you're going to run it on your head, the stock one is crazy short.
I wouldn't use the bright or blinking setting, and would tilt it down a bit, on MUP's after/close to dark. It's irritatingly bright when shined right at ya.
You'll have to order helmet mounts, or do like I did and make some out of aluminum tubing and velcro straps.
I paid about $75 each, they arrived quickly and stank like a Chinese plastic factory for a few days.
Well, I certainly put the wrong item on my wish list. Found it yesterday on another thread
https://www.amazon.com/Lumen-4-Mode-1...pr_product_top
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
That's one of the Magicshine clones. I've got the Magicshine they claim to have 1000 lumen output, and it's a great light.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
But performance claims are funny things. They get people to order things without any real guarantees or proof of performance. And shipping costs are usually so close to the item cost that most people won't return them.
Quoted: 139 Post(s)
Liked 33 Times
They are quoting the specs of the LED. It takes a certain voltage and current to obtain that light output. There's also a drop in light output from the lens on a light. About 10% IIRC. Then there is beam pattern. If you have a very, very narrow beam, you can light up a penny from a mile away! But that's not useful. The other extreme is the light is spread out over a very large angle. That's not useful because you want more of the light to be focused where you are going. Want to talk about the reflectors in the flashlight? If you read specs on the multi hundred dollar bike lights, they will provide more stats that better indicate what you are buying. And the light will have been engineered to be a useful cycling product. This, in addition to a warranty, contribute to the higher cost of these lights.
Bikes: Too many to list here
Yes, the light listed is a knock off of magic shine. Not saying that its not going to be good, but at least magic shine has a decent reputation for an inexpensive light. Im interested to see how this light is. IMO i would have just spent the extra $25 and got a magic shine for many reasons including easier to find replacement/backup batteries, and other accessories such as extension cable or Y connector. Yes cree LED's are of good quality usually and are known for being excellent and inexpensive, yet like the post above me, it is all about the quality of the reflectors under the lens that determine how well the lumen output is dispersed
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
I own a similar light
I also bought through Amazon - felt safer than ordering through a unknown Chinese website. The light I bought claims a 1300 lumen output. While probably not 1300 lumens it's crazy bright on a full battery. The light does dim slightly as the battery discharges and it will discharge even while off if you leave the battery plugged into the light. The light itself works fantastic and has a good bright beam - not too wide, but not a spot either. The charger works well too. It has around a 3 hour run time on high.
I've owned it through December and am very pleased with it's performance and value. If they skimped anywhere, it may be on the battery. No problems yet though!
For anyone considering these lights, Deal Extreme has all the parts and accessories you will need. Cheap and quick in my experience as well. If it's like my light, and the packaging is to be believed, it IS the MagicShine light.
PatrickGSR94
12
06-03-12 03:53 AM
