Cable splitters for coupled tandems
I am not clear on how one replaces the brake and gear cables when there are splitters to aid disassembly of a S&S coupled tandems. For example you buy a Shimano cable with an end which fits into a Shimano brifter. The other end plain and normally, after fitting it to the derailleu or brake, you trim it for length. But how do you fit it into the cable splitter when you've got a plain cable end?
JayB
JayB
Thanks. Very clear diagram. Only thing I am not sure about is how the splitter connected to the bit which goes to the brake / gear lever without having a nipple to keep it from slipping.
JayB
JayB
On the bright side, you can use two normal-length derailleur (78") or brake (60") cables instead of the slightly more expensive and often times harder to find tandem length derailleur (120" - 160") or brake (108") cables.
Right, thanks gregm and TandemGeek. I think I've got it. Still not quite clear how the cable splitter thing grips the clipped off, slippery end of the cable with no nipple. Seems to have a tiny set screw.
A friend of mine told me that Co-Motion had recently introduced something called a "split cable bracket" for derailleur cables. Is this related to cable splitters for coupled tandems? Or is it something else entirely? Thanks again.
JayB
JayB
Thanks TandemGeek. Asked my friend and he said that he saw this "split cable bracket" mentioned on the Hobbes Tandem list. However, apparently it wasn't clear from that what it did / how it worked.
JayB
JayB
Originally Posted by TandemGeek
I'll have to ask.
It's simply replacing the downtube shifter boss-mounted cable stops & integrated barrel adjusters with a brake-cable like cable stop & and in-line cable adjuster (INCA).
This is what you would normally see; a boss-mounted stop with adjuster:
Or, another type of cable stop used by Co-Motion looks like this:
This is a slotted brake cable stop:
This is an INCA:
Thanks TandemGeek. As usual I got the wrong end of the stick. So the INCA will fit inside the new slotted brake cable stop or in front of it, rather than being integrated.
Kent Peterson from Co-Motion was kind enough to follow-up Dwan Shepard's original reply with a photo of the S&S front derailleur cable stop & in-line cable adjuster installation they are using:
Per Kent... "Here is a photo of the slotted cable stop with the in-line cable adjusters. This method makes packing a bike easier since you can now remove the bars and the cables come along with the bar. With the former method the cables stayed attached to the head or downtube and the possibilty of kinking a cable was greater."
So, now you know.
So, now you know.
That looks like the jagwire in-line barrel adjuster:
https://aebike.com/page.cfm?PageID=30...ils&sku=BR4049
Bought half of a pair (aka "one") from my LBS a while back... need to install it on the rear brake cable on my Trek T100, since the stock setup has no adjustment for the rear brake.
-Greg
-Greg
Bikes: Colnago C40 HP, Aegis Trident, Cannondale tandem
dude, as a lifetime safety professional I strongly urge you to have a pro handle this. You're unclear, and these are your brakes: a failure at the wrong monment may be unhealthy.
I've used the inline cable adjusters on two different Cannondale singles and had nothing but trouble. They didn't seem to hold there adjustment very well and caused "ghost shifting" with the rear derailleur. I replaced them with a solid cable housing and boss mounted adjusters and haven't had any problems since.
Bikes: Santos Dual Travel touring tandem, MSC Zion MTB-tandem, Santos SCC03 MTB, Santos STR01 trekking bike, Cannondale F500 MTB, Kalkhoff E-bike, Centurion Cross 4000 cyclocross bike (converted to road bike)
Wait a minute. Fog descending again: are these cable splitters as well as adjusters? That's what comment from Kent Peterson implies, no?
"Here is a photo of the slotted cable stop with the in-line cable adjusters. This method makes packing a bike easier since you can now remove the bars and the cables come along with the bar. With the former method the cables stayed attached to the head or downtube and the possibilty of kinking a cable was greater." This is what the message from Kent Peterson said. Further up, above the Co-Motion supplied photo is says the photo is of "the S&S front derailleur cable stop & in-line cable adjuster". So, I thought, if only for S&S and if it allows bars to come off with cable, must be they are splitters too. But you are saying the splitting happens somewhere else, right?
JayB
JayB
Wait a minute. Fog descending again: are these cable splitters as well as adjusters? That's what comment from Kent Peterson implies, no??
All these things do is replace the cable stops with integrated barrel adjusters that I provided photos of in an earlier reply to allow the use of the split cable stops. For example, on our travel tandem, I must remove the two screw-on cable-stops with a hex wrench to detach my handlebars/shifters/derailleur cables from the front 1/3 of my frame. On a Co-Motion, the cables can simply be pulled out of the stops; saves about 2-3 minutes (5 minutes if you're not fast with a wrench) when packing and Unpacking.
Bikes: 8 bikes - one for each day of the week!
Ok, so what are my options for splitters? I'm trying to get our tandem to pack down easier. I've got the new fork to install, but need to sort the shifters.
Originally Posted by dubbelop
I think they're adjusters only. The slotted cable stops (under the down tube) allow you to take out the cable housing so the cables are slack.
JayB
JayB
